Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
No ice or water through door, no light on touch pad
I own a GE arctica refrigerator Mld @# PSS26MSRESS no/ice or wtr through door, no lights on pad, have replaced the touch pad still nothing.
while under warr ice maker was replace not making ice fast enough but this problem with the dispencer in door not working started about two weeks ago.
can you help????
SOURCE: GE Monogram ZISS480DMCS Ice Maker Problem
The water solenoid valve should have 120v going to it. (You will need a multimeter to chk this). You will need to also chk. for proper ground when verifying the 120v. If you get 120v on each of the pin clips, then your plug is not properly grounded, which means that you need a new ice maker circuit board. This is located in the in dispenser (front panel opens).
Posted on Jan 24, 2008
  • 1073 Answers
SOURCE: GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Posted on Apr 12, 2008
  • 1122 Answers
SOURCE: GE Profile Arctica Icemaker
YOU CAN PULL THE FRONT COVER OFF TO SEE IF THE GEAR WHEEL IS BROKE,OTHER THEM AT CALL YOUR LOCAL APPLIANCE PARTS STORE AND YOU CAN GET A NEW ONE FOR AROUND $70,THANKS-MIKE
Posted on May 29, 2008
fridgetech
  • 473 Answers
SOURCE: Kenmore Elite Bottom Freezer Refrigerator
This first thing I would do is remove the panel on the back of the fridge to access the control board. It should be about half way up on the left hand side if you are looking at the back of the fridge. There should be four 1/4" screws to remove. In the middle of that board there should be a reset button. Press that button then let me know if that worked.
Posted on Nov 30, 2008
  • 219 Answers
SOURCE: GE Side by Side Refrigerator dispenses ice but no water
if the light is not coming on i would say that board needs replaced and it just pops right out
Posted on Mar 19, 2009
GE Profile Arctica ice dispenser switch quits working
I came across this problem recently , and found the main control board was bad . Check this site first , to see if it can be covered under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
It was covered under warranty , at the previous customers residence .
Nov 20, 2009 | GE Profile¿ Arctica® Energy...
GE Profile Artica - Water & ice dispensor not working.
This could be as simple as the door switch or as complex as the dispenser control board. I would try the door switch first. When the door is close it turns on the dispenser controls. If the contact is defective in the door/light switch then this happens. Unplug remove the door switch and mark wire locations. 1 Powers the lights and the other powers the dispenser. and one is the power itself. Sea Breeze
Jul 26, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice Maker won't produce ice through the door
You either have a bad interface board ( touch board ) or a bad main control board . You would have to go into the test procedure from the touch board to determine which is bad . The more I think about it though , I tend to lean towards the main control board . Once you get into the test mode , 0 and 4 would test communication between the 2 boards .
Jul 18, 2009 | GE Profile Arctica Stainless Steel Top...
My ice maker will not work, Ge profile Arctica.
Here you go...my dad had the same issues...Good Luck!
http://www.youtube.com/watch?v=sW2yqQjEcLI&list=HL1329704348&feature=mh_lolz
Jun 23, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Water/ice dispenser
hi george i will try to help firts i want you to try this. pull off the bottom grill or kick plate and make sure that the wire harness is connected and not loose they get loose a lot on this brand. now if they are look at the water line conector but the bottom hinge disconect it for there and close the door and ask for wtr at the lever if you get water the you have frozen line inside door if no water then check the resevour inside the refrigerator and make sure is not frozen if it is ok then if you model hasa mother board at the back repl when both ice and wtr go out that is usually the problem i see it every day ok take the model number with when you buy the part sothey can give the right board ok.
Oct 15, 2008 | GE GSS20IEP Side by Side Refrigerator
Apr 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
164 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Lawrence Oravetz
okcchemist
Level 1 Expert
