Doesn't change cycles, first spin and rince cycle doesn't work at all
My kenmore washes excellent, but it does not advance to the next cycle...furthermore it does not work if I advance it to the initial spin, but I can set it to the final spin (no rince is working)
  • 43 Answers
Sounds like you have a bad timer Does it spin on final cycle? (Spin Cycle)
Posted on May 12, 2009
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
Will not rince at end of wash cycle
If ur machine have additives cycle, check whether the solenoid valve (for opening water inlet to the additives' tray) is working or not. You can check this by listening to the sound of water during additive cycle. If it is not working, you have to replace the water inlet valve unit.
Nov 19, 2012 | Bosch Washing Machines
Kenmore front load washer goes through wash and rince cycles but will not spin
These are symptoms of a broken door lock and switch assembly and the only viable solution is replacing the said assembly if no issue is found with the wire harness connections. The machine will not advance to the spin cycle unless the door lock spin switch is activated. This is a safety feature to prevent the door from opening and avoid injuries during the high-speed cycle. Replace the door lock and switch assembly and it should solve the problem. Click on the link below for the detailed instruictions on how to replace the door lock and switch assembly. The part number for the door lock and switch assembly of your machine may be different but the instructions still apply.
Replacing the Door Lock and Switch Assembly on Kenmore Front-Load Washing Machines
Mar 05, 2011 | Kenmore Washing Machines
Washer beeps at the end of each cycle,must be advanced manually
Hi Steve just read your posting.Now when it starts to beep a series of lights will light up.Starting from left to right they are numbered 1st on the left=128 next is=64 next is=32 next is =16 next is= 8 next is = 4 next is = 2 next is = 1. So the lights are numbered from left to right 128--64--32--16-- 8-- 4--2--1. now with this information look at the lights that are lit add up the value of the lit lights and reply back and i will look in my service manual and tell you what part or parts are faulty. hope this helps.
Jun 03, 2010 | Fisher and Paykel GWL11 Top Load Washer
My Kenmore Washer 110.92281100 won't stop
I purchased a new timer, installed and solved the issue.
May 13, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Rince and spin cycle don't work
Fo;;ow the instructions in this video and replace the direct drive coupling.
Apr 01, 2009 | Kenmore Washing Machines
Doesn`t finish cycle
Thanks for the information !
Sep 19, 2007 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
563 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
