Question about Nokia 6600
Without Memory card Ph. Formatting of Nokia Mobile Phone
How to format Nokia 3220 Mobile without help of Machine? By code only Answer as soon as possible at my mail ID - alok12@zapak.com
I m In trouble last few month as per technician PF ic is working correctly.
  • buntyavtar Aug 18, 2008
    hi i have a nokia 3220 and i need its formatting as it switch off after a conversation of 2-3 min.
    thank you
    mailavtar@gmail.com
  • 4 Answers
Answer from::::::::::::::::: [VJ]'s
1. Switch off the phone.
2. Hold down the following three bottons:
Green(call answer) button, (*) button and (3) button.
3. While holding these buttons, press the power button and switch on the phone.
4. When the message 'Formating' appears on the screen, release all of the buttons......
Posted on Mar 05, 2008
    Sergeant:
  • 452 Answers
Reset default code is 12345, you got this option in settings of h/s
Posted on Oct 13, 2007
  • gizmo plus Oct 20, 2007
    for formatting your handsset you have to dial the no *#7370#   than it will ask a code from you than you have to give the code as 12345 which is the default code for nokia..,
SOURCE:
How to unlock my memory card password?
Delete some unnecessary files in your phone memory like images and videos. Go to your phone gallery and delete some of those. And if you want to use the memory card as phone message storage then go to Messaging - Option - Settings - Other and then Memory in Use, select your memory card.
But if your phone is infected with a virus then you need to format your phone. One sign of infection is your phone keep sending a message randomly from your contacts without your consent.
Use these code and enter it to format your phone:
*#7370# and then the default code is 12345
Take note: Make sure you back-up your contacts or any other important inside your phone.
Hope I make it clear and does makes sense.
Sep 30, 2012 | Nokia mobile C2-00 Dual SIMbiosis
I have a Nokia 6233 unfortunately the memory card unlocked and I don't know the password so I need a solution for that but without formatting the memory card I'll be pleased if you help me as soon as...
Hi ,
Follow the following steps to unlock the memory card
  • To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer, click here to download.
  • After finished downloading, install it to your mobile phone.
  • Insert the mobile memory card into your mobile phone. Remember, don't access the memory card through phone at this moment.
  • Run FExplorer and open the following location C:\system.
  • From the location C:\System, you will see a file named as mmcstore. Rename this file asmmcstore.txt.
  • Copy the file mmcstore.txt. and paste it to your computer. Now, open that file in notepad.
  • When you finished the above steps, you will find the password of that file.
  • With this password u can open ur Memory card
This has worked for one of the user . click here to view
For any quires write back to me .If yo are satisfied with my answer please vote for me(with atleast 3ups) . thanks in advance
Nov 23, 2010 | Nokia 6233 Cellular Phone
I have format my nokia 2730c mobile after formatting memory card has been locked. it asked password. but i don't put any password. how can i open my memory card?
Go to a mobile repairing shop.....ask them to unlock the card but if you don;t want to lose your data then copy all the data using your phone usb and then give them the card they will unlock that after unlocking it will be empty...now you can again copy your data to your card......
Oct 20, 2010 | Nokia 2730 Cell Phone
I can`t remove virus from my mobile a nokia3230
if your phone is still in warranty bring it to your nokia care
they will remove it for you without any cost...
if not try to download anti virus for your phone
i hope this helps
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you resolve your problem
Aug 17, 2010 | Nokia 3230 Cellular Phone
My nokia 5300 camera is not working.As soon as i open a camera mode it says camera on standby and operation failed
Switch off the phone, remove the memory card and boot again without the memory card. Now try accessing the camera, hope it's working now. I would suggest you to scan the memory card or format it (i recommend formatting the memory card so that it'll not fail).
If the problem persists even without the memory card, reset your phone's settings to Factory Default by going to the Settings > Restore Factory (open the settings, press up key once, you'll see the "Restore Factory") using the code 12345. Your phone will automatically restart. Now try again with camera.
If both the above methods don't help out, your only option is to flash the phone or update the firmware. But I don't recommend do these yourself, a small mistake or incomplete will damage the phone or will create more problems. You can visit any service center or any mobile repairing center and get it done with a small fee.
Good luck.
Thanks for using FixYa.
Aug 10, 2010 | Nokia Cell Phones
Not formatting to nokia 3110c mobile
to remove password,update phone online with card in phone.format memory card with a card reader,remember to back up data.if this doesn't work maybe the memory card is bad.try formatting another memory card with phone to confirm.
Jun 17, 2010 | Nokia 3110 Cellular Phone
Sending viruos from my mobile without my bluetooth is on and any others mobile bluetooth is on. even my bluetooth is hidden condition, iwant solution this problem thanks
dear customer thax 4 choosing fixya....
ur problem with sending virus ven phone without on it.....
it clearly says tat it is because of virus.....
so first u hav to format ur phone...n memory card tooo. to format ur phone press *#7370# n dail ur security code to format....
but u hav to format ur memory card tooo.....with out formatting dont insert ur memory card to phone....
Dec 24, 2008 | Nokia 6600
Want to unlock nokia n70 memory card without formatiing
Post your IMEI code of your phone and i will generate it to master code.
Sep 11, 2008 | Nokia N70 Cellular Phone
Nokia 6600 Logo
300 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
ASHRAF CA
ASHRAF CA
