Question about Dryers
Hi My name is Ray and i have maytag commercial electric dryer model LDE19CS but the problem is i need to increase the time cycle,from 48 to 60 minutes. How i do that. I need manual
  • rajkol123 May 15, 2009
    Thank you Ray
  • Dryers Master
  • 8,220 Answers
You either change the timer motor or you change the
Timing cams. Contact Lobright manufacturing in Queens village new york 888 - 829 - 0009
I do not know if my friend Bob Pinkney is still there but ask for him and tell him JW said hi. Ask him to send you a catalog. In it you will find all sorts of laundry matt stuff plus those cams and motors.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 15, 2009
Having problems changing the time per quarter on my maytag commercial dryer
you need to change the wheel on the side to make the time longer or shorter.You can get these wheels and an appliance parts store
Sep 19, 2011 | Maytag MDE16CS Electric Dryer
I have a Maytag MED5770TQ Electric Dryer. The drum is getting noisier and noisier and sounds like it will break if we run it again.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 22, 2011 | Maytag MED5770TQ Electric Commercial Dryer
HiMy name is Ray and i would like to increase the drying time on a maytag commercial dyer model lde19cs
i just got off the phone with Maytag Commercial Laundry customer service, because i needed to know how to adjust the run times on this dryer model. here is what i learned:
there are slots in the timing cam into which fit a white pin for adjusting the run time. the letter settings on the cam are set at 12 minutes apart:
E = 12 minutes
D = 24 minutes
C = 36 minutes
B = 48 minutes
A = 60 minutes
if your dryer is running 48 minutes, that pin is likely in the 'B' slot. remove the pin. the built-in stop at the 'A' position is for 60 minutes.
May 28, 2009 | Maytag Dryers
Dryer is warm but not hot
Is the model number listed here or can you find the complete model number? May need cycling thermostat or gas valve solenoids. Let me know if I can help, Sea Breeze
Mar 22, 2009 | Maytag MDG16PD Gas Commercial Dryer
Maytag Dryer working but not heating up.
possible air flow problem,, check exhaust hose and sure not clogged up needs air flow, if long dry times repl/ coils/ only on gas models /if electric./ repl/ hi limit thermostat,// and safety thermostat ,,u need 240 volts 120 to turn on dryer and another 120 to heat ......
Nov 30, 2008 | Maytag PYE2300AY Electric Dryer
Timmer Maytag Commercial Dryer
the maytag timer for MDE10 should be a multi vertical slide in type. If so under the keyed panel on the top of the dryer, is an electric control with a grey knurled knob facing the front of the machine.
This grey knurled knob is the time set.
The knob rotates clockwise (from front) under motor control while the dryer is running, and jumps back to starting position under spring control when the slide is pushed in.
There is a single grey stud moulded into the front of the knob, that is the sixty minute mark, and a number of slots before the stud, that take a nylon peg. they are 6 minutes apart 54 48 42 36 30 minutes. Inserting a nylon peg in the slot at 30 minute will do what you want.
Most service guys drop the peg in the bottom of the control when they remove it, makes it easier to find, next time, so if there is not a peg in any slot, examine the floor if the enclosure, A short nut n bolt will accomplish the same result if the peg is not there.
If the original multicoin push in has been replaced with a newer single slot device I dont know how the change is made, none of my dryers are that new.
Feb 24, 2008 | Maytag MDE16CS Electric Dryer
Maytag coin op dryer timer programming for mde-16cs
The maximum run time on this machine's timer is 54 min. There is an adjustable peg on the white plastic index wheel which you can adjust anywhere from 30 to 54 min. For example peg in position E is 30min, D is 36min, C is 42min, B is 48min or for 54 min you have to remove the adjustable peg completely, but don't lose it in case you want to change the time in the future. If it is already in the Max "A" position and shuting off early you might have to change your torsion return spring. Hope this helps
Jan 06, 2008 | Maytag MDE16CS Electric Dryer
I need the coin programming instructions
what sort of coin acceptor is it? single slot? multiple coin slide in? write me at my email: srf12980@localnet.com.
Sep 12, 2007 | Maytag MDE16CS Electric Dryer
Dryers Logo
102 people viewed this question
Top Dryers Experts
