Home | Xerox | WorkCentre M15i Laser Printer | LDAP lookup fails on Xer...
Xerox WorkCentre M15i Laser Printer
Problem for Xerox WorkCentre M15i Laser Printer
LDAP lookup fails on Xerox WCP4150
By smh102580 on May 11, 2009
We have a Xerox 4150 that we use to scan to email a lot. Out of the blue, we get the following alert:
"15-400 The LDAP server connection failed during a scan-to-Email operation. Inspect the LDAP settings and have the System Administrator check the LDAP server. Scan-to-Email is degraded, printing and all other machine services (if installed) are unaffected"
The LDAP settings are all correct, and nothing has changed with the machine. Any ideas?
Comments:
May 12, 2009
- I already did that and we are at the latest level.
Solution #1
posted on May 12, 2009
Not Rated)
tryit
Rank: Guru  Xerox Expert
Rating: 89%, 1262 votes
I would check your software version. Several of the older versions had a lot of LDAP problems.
You can print out a system report and find your Firmware level, then go to Xerox.com, go to Drivers and Downloads and see what the new version. Current firmware level is 10.100.46.000 . follow the instructions.
Was this helpful?
Yes
No
Popular Solutions for Xerox WorkCentre M15i Laser
Questions and Unsolved Problems for Xerox WorkCentre M15i Laser
Do you recommend Xerox WorkCentre M15i Laser Printer?
Answer
Answer
When the computer is turned on it says updating 3 of 3 updates zero complete. Then it does nothing... (More)
Answer
i need a meter reading for a konica magicolor 2400W. How do I do this?
Answer
I enter CREATE PDF FROM SCANNER. Select XEROX M15WORKSERIES. ERROR MESSAGE : CANNOT BE SET TO THIS... (More)
Answer
I have problem in my printer it is not accessing the order threw the my pc
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Xerox WorkCentre M15i Laser...:
Top Printer Experts
Rank: Guru Guru
Solutions: 1447
Experience: Self taught, Keep up with the manufacturer's service manuals, Beta Tester
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
