Connecting a PC to TV with RGB Cable
I bought a RGB cable and I connected my PC and TV. I can't get a signal. I have a Gateway 500s with a Nvidia Ge Force 6200 and Lg 42pG20 tv.
  • 2 more comments
  • keith_jacobs May 11, 2009
    The cable we have is a VGA monitor cable. AWM E101344 style 2919. There are no yellow or red plugs.
    I found where I can disable my current monitor but I can't find anything about sharing my monitor or monitor 2.
    I found that I had my video card set up only to allow one display. I changed it and now I have monitor 2 on my settings. I unchecked extend my windows on this monitor and the window closed . Unsure what to do now.
  • 393 Answers
Depending on your computer you should be able to right click on a blamk area og your desk top
and get a menua allowing you to go into your settings
then click on display settings
look for a help menu and it should help you step by step to set this up better
Posted on May 11, 2009
    Brigadier General:
  • 3,917 Answers
You need to place the
Yellow with Yellow port
Red with Red Port
White with white port
from the gateway 500 to the tv. You should at least get the audio. If by twisting or turning the cable outputs you fail to get any audio or video then you need to check with Dell whether the LG is compatible.
Thanks
  • e-Guru
    e-Guru May 11, 2009
    OKie .
    There are three possible solutions for this issue:
    • Disable the dual monitor setup. You can do this by following the directions below:
      1. Right click on your desktop and select Properties.
      2. Select the Settings tab.
      3. Select the Monitor labeled 2.
      4. Uncheck the option to Extend my Windows desktop onto this monitor.
      5. Click OK.
    • Drag the application/window from the unshared window to the shared window.
    • Click on the Stop Sharing button, then click the sharing button again and select the other monitor. ( LG TV for you ).
  • e-Guru
    e-Guru May 11, 2009
    Okie ,
    In this case did u install the drivers for Nvidiea Ge Force card. If its installed then it should show both the VGA ports.
    Thanks
I have a toshiba satellite p755, it use to be able to hook up to my HD TV with the HDMI chord but now its not connecting..whats the problem?
Make sure all connections Power ,HDMI and any other connecting leads have secure dust free connections also check each lead for any kinks / bends .
Connecting a Toshiba Satellite Laptop to a TV is an ideal way to enjoy videos, photos and other media on the laptop on a much larger screen.
Satellite Laptops can be connected to TVs using VGA, S-Video and even HDMI, though the TV has to have compatible inputs as well.
Connect the RGB cable or S-video cable to an open input on the TV.
Depending on the type of TV, it may or may not have a RGB input.
S-video may have to be used instead.
Connect the 1/4 inch to RCA Y-cable into the TV using the same input as the VGA or S-video cable.
Connect the other end of the VGA or S-video cable and the audio cable into the laptop.
The video ports are on the sides of the laptop.
The audio cable should go into the headphone jack of the laptop.
http://www.svideo.com/compaq1700.html
Aug 09, 2013 | Computers & Internet
LCD TV display shows pink flickering screen when using DVI > RGB cable
it's easy man when it shows u the walpaper it'sin the extanded desktop so it only shows u a part of the desktop while the other is on ur pc monitor
u need to go whereu can change the resolution and mark the selection *make this as main screen * for both vga and lcd tv done u will have clone desktop on both
Feb 09, 2013 | Nvidia Computers & Internet
Dear Sir, We have Toshiba REGZA 24PB1E LCD TV. I want to test our Gigabyte PC GA-G41M-Combo MB with VGA port (15 Pin Connector) Pls let us know how to connect & get the solution ASAP. For...
Hello
With either the PC IN or HDMI connection, you can watch
your computer's display on the TV and hear the sound from the
TV's speakers.
When connecting a PC to the PC IN terminal on the TV, use an
analog RGB (15-pin) computer cable and a PC audio cable.
To use a PC, set the monitor output resolution on the PC
before connecting it to the TV. The following signals can be
displayed:
Format Resolution V. Frequency
VGA 640 × 480 60Hz
SVGA 800 × 600 60Hz
XGA 1024 × 768 60Hz
Other formats or non-standard signals will not be displayed
correctly.
Note:
The PC audio input terminals on the TV are shared with the
HDMI-1 analog audio input terminals
Some PC models cannot be connected to this TV.
OK.
Mar 24, 2011 | Toshiba REGZA 47HL167 TV
I have a Fujitsu-Siemens Amilo PI 3540 Laptop. I am awaiting delivery of a LG 32LH5000 TV. I would like to connect the two. Before I go and buy a cable I would like to figure out which one will be the...
I suggest you wait until the TV arrives before getting too concerned with which cable you may need. The instruction manual that comes with the TV will explain exactly what kind of cable you will need and what types of signals it is compatible with.... Those cables are not cheap (unless you GET a really cheap one, which I would recommend against) and trying to decide now without all of the parts and pieces in place is futile.
Jan 07, 2010 | Fujitsu Siemens Computers & Internet
Connecting pc
Did you change the input on your tv to the corresponding input that your RGB cable is connected to?
Mar 19, 2009 | Sharp LC-32SB24U 32 in. LCD TV
No signal on HDTV
Your graphics card is probably too old to support HDTV signal (720p, 1080p)
Dec 04, 2008 | Nvidia GeForce FX 5200 Video Card Graphic
Connecting PC to TV
sorry guys sound is not ment to be transmited through a rgb cable its just for higher quality video you can use a the red and white RCA inputs to get sound to your tv but you need a headphone jack -rca cable or if you tv has a headphone jack just buy a cable with one headphone jack on both ends
hope this helps
May 17, 2008 | LG 32LC7D Television
Trying to use rgb input
Cable TV: Connect the LCD TV to the cable with CATV and Digital cable. Preset the cable TV channels into memory with Auto Scan function when using a cable TV system. Make sure you set the INPUT SOURCE properly (TV, VGA, S-Video, etc)
Mar 10, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Pc to tv
Same problem for me too!
Dec 21, 2007 | LG 42LG30 42 in. LCD HDTV
Connecting PC to sony SXRD with RGB cable no display?
How are you connecting the PC to the TV (ie which input and what type of cable are you using?)
Aug 12, 2007 | Sony KDS-R50XBR1 50" HDTV
Televison & Video Logo
272 people viewed this question
Top Televison & Video Experts
Electro Med Services...
