Question about Garden
Not enough pressure
I Have a Craftsman Pressure Washer Model 127-676400 /1400psi. It runs Continually with low pressure.I cleaned the filter and have lots of pressure at the source. Whats my problem.
See if your rpm change when you pull the trigger. i just bought one my self at a garage sale and, it has same problem, no pressure. then i noticed when i pull the trigger, rpm doesn't change. if i accelerate rpm manually i get the pressure i need. so if you have this kind of problem, then maybe you need to ask different question. hope this helps. god bless. ...i don't know the what the problem solution is, i need to findit out for my self too.
Posted on May 30, 2009
Adjusting high and low water pressure
Clyde, Trouble shooting pressure washer links below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Pressure Washer FAQ Low or No Flow Briggs Stratton
DIY Pressure Washer Repair Help Troubleshooting Sears PartsDirect
Troubleshooting Your Pressure Washer
Common Pressure Washer Repair Problems Pressure Cleaned
Jun 27, 2016 | Craftsman 2500 PSI Briggs & Stratton...
Power washer runs until air filter is put back on
Have you replaced the air filter? Without the air filter the engine is getting enough oxygen to support combustion. With the air filter it does not get enough oxygen. If you have not replaced the filter it sounds like it is time to replace it. If you have been "cleaning" the old filter and reusing it, small particles may be lodged in the filter, reducing the airflow. Is it a pleated paper filter or a oil dipped foam filter. If it is a foam filter, have you cleaned it? If you replaced it was it a store replacement or a piece of foam you obtained and made it fit? Foam can be closed cell or open cell , both look similar but closed does not allow airflow and open does .
Jul 16, 2014 | Homelite Pressure Washer. Honda 2700 psi...
Diagram of a craftsman power washer
The only filter on the detergent pickup is usually at the end of the hose you drop into the detergent. To clean the line and syphon attachment only requires a little pressurized air to blow out any debris that may be in the line. Make sure you are using the black, soap tip on the pressure gun when trying to use the detergent syphon system. If you are using any of the high pressure tips there will be too much back pressure in the line for the syphon to work.
Aug 30, 2012 | Craftsman 2500 PSI Briggs & Stratton...
I have a Craftsman compressor Model # 919-15292 2. The compressor stopped building pressure because air was continually being released through the unloader valve. I have replaced the unloader valve,...
you must have wired the new pressure switch incorrectly .when the pressure switch opens it will release the head pressure so your compressor must be running with the pressure switch contacts open should be 4 connections 2 marked motor which is from your compressor and 2 marked line which is your power coming in
Jun 15, 2011 | Craftsman 33 gal Air Compressor 6 hp...
Craftsman Pressure Washer 2.3 GPM 2550PSi
if there is a fuel filter running completely out of fuel sometimes allows all of the bad stuff in the fuel tank to plug the fuel filter (if it has one). press the primer bulb until you can hear fuel, then it should start.
Jun 02, 2010 | Craftsman 2500 PSI Briggs Stratton...
Pressure washer stalls off choke
Probably the carb's low/mid speed circuits are clogged real bad. The only fix I know if they are as bad as you describe is remove and soak/clean carb, and this may not work as some of the circuits are as fine as as human hair, and the solvent may or may not work. Then it' replacement time.
Sep 14, 2009 | Briggs & Stratton Garden
Power washer will not draft
craftsman 2000 psi, model 020211, starts up and runs good just lost pressure?
Jun 09, 2009 | Briggs & Stratton Gas Pressure Washer...
Pressure washer wont run unless choke is on
I have a Karcher pressure washer w/ a 5hp Honda engine. It only will run while the choke is pulled out and only runs at about half the rpm's. When the choke is pushed in.. it coughs, sputters and shuts off. Can you tell me how to fix this....
May 12, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
329 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
