Question about Pentair MINIMAX MODULE, IGNITION CONTROL
I have a Minimax CH 200M the pilot is fine I replaced the probe last year but heater doesn't come on. I started it and it cycled one time but won't come on again
  • 2 more comments
  • Darrell Dobbs May 11, 2009
    That Link is broken but it gave the message to go to propools.com. What am I looking for when I get there? Do I need to purchase a manual or something? I need a little more guidance if you will. Thanks, Darrell
    If you were sending towards a manual I did find a troubleshooting guide that said the pressure switch might be defective. There is only one and is there someway to bypass or test to insure it is defective before I buy one? Let me know, Darrell
  • Darrell Dobbs May 13, 2009
    I replaced the switch but that didn't resolve the issue. Still won't light the burners. Any other suggestions?
    I replaced the pressure switch. Still won't light the burners. Any other suggestions?
  • 15,935 Answers
Pool heaters are exposed to the elements all year round, and it is common for the thermocouples to tarnish.
The thermocouple converts the pilot flame into energy and the regulator opens when it senses this miniscule amount of energy.
This is a safety feature so gas does not spew out of the regulator without a pilot to ignite it.
Clean the thermocouple with fine grit sandpaper, and adjust the pilot so just the tip of the flame is touching it.
Here are a few more troubleshooting guidelines for your pool heaters:
• The heater will not ignite.
If you are having a problem simply being able to ignite the heater and getting it to work properly, there are actually many things that you can do to try to remedy the problem.
One of the very first things you need to check in order to avoid spending a lot of unnecessary time is to make sure the switch is turned on. If it is turned on, you should move on and check the thermostat to make sure it is turned up to the desired temperature.
If this appears to be in working order, you then should check to make sure that the pump is running with a clean filter that has less than or equal to 16-psi on the pressure gauge. You may also want to check to make sure the gas valve is in the proper position and that the pilot light is lit.
You also should check that the plumbing and valves are all open and that the bypass has not only been installed, but also that it is properly adjusted. If you have checked on all of these things and still do not know what to do, you may want to contact a technician to take a look at the pool heater for you.
Thanks for using FixYa!!
Posted on May 14, 2009
    Novelist:
  • 130 Answers
The switch needs replacement is sure but the exact schematics is not provided by the company.
click this link directly
http://www.scribd.com/doc/2197090/MiniMax-NT-LowNOx
thanks.
keep updated.
Posted on May 12, 2009
  • 413 Answers
Sir i request you to go to following LINK
Posted on May 11, 2009
How remove a pilot generator from a minimax ch 200m
shut off gas supply. undo gas line union. remove wiring from gas valve. undo burner tray support screws. slide burner tray out. remove pilot generator leads from gas valve. pull out pilot generator from pilot assembly. then re assemble
Aug 17, 2014 | Pool & Spa
Why is water dripping on burners of pentair minimax ch 200m?
bad heat exchanger or you have condensation this happens when the temperature delta is too high
May 21, 2014 | Pentair Minimax CH Heater
Pentair MiniMax CH 200 won't shut off
check temp sensor on control if one attached if no control check heater temp sensor
Jun 13, 2012 | Pentair Minimax CH Heater
I have a Pentair Minimax CH 250M pool heater. When I opened my pool, the heater started up fine and heated the pool initially. However, since the initial heater it has not come back on, and the pool is...
Do you have 24V at the brown wire of the gas valve? If you do then it is probably a bad gas valve.
If you don't have 24V on the brown wire it is probably the ignitor.
Jun 04, 2011 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Pentair Minimax CH Propane Millivolt Ignition Heaters error E05 what is it?
If you are firing, and then going off and getting an E05, your igniter is to blame. It may be glowing but it's getting weak. The diagnostic goes further but that is usually the fix.. With inactivity, the igniter is always to blame. You really need to fire it off weekly to make it reliable and make sure that your heater is serviced at least one time a year to keep all the internal components operating as designed.
  • PILOT ASSY LP MV CH150 IID
  • Manufacturer: PENTAIR WATER POOL AND SPA INC
  • Manufacturer Part #: 471291
  • Description: Propane pilot assembly for heaters with millivolt ignition.
  • Retail Cost: Approximately $65.00
Dec 08, 2010 | Pentair Minimax Ch 200,000 Btu Propane...
Do not know how to start pilot light
There should be instructions on the inside of the heater access door. Make sure you are comfortable working with gas heaters. Make sure the shutoff valve supplying gas to the heater is on. Turn the gas valve to "pilot", press and hold it while attempting to light the pilot. Once the pilot is lit, continue holding the gas valve knob down for about 30 seconds. The pilot should stay lit once you release the knob. If the pilot stay lit, turn the gas valve to "on". Replace the heater access door and make sure you have proper water flow and attempt to light the heater. If it will not light, or the pilot will not stay on, you will probably have to replace the pilot generator. It provides voltage to run the heater and after time it wears out and produces less and less voltage. A millivolt heater runs on less than one volt so any power loss can be a problem. If you are able, test the pilot generator with a multimeter to see if you are getting at least 500mv when the pilot is on. If not, you should replace the pilot generator or even the entire pilot assembly. Hope this helps...
Sep 27, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
Pentair Minimax 250M
how many times it blink will tell you what is wrong check at the codes. unplug thermostat check fo homs 10 k around is fine at 80 degrees pressure switch require a by pass but DO NOT RUN THE HEATER WITH A BY PASS ANY CONTROL!!!!
Jun 17, 2009 | Pentair 250k Minimax Ch Ng Mv Heater
Pentair MINIMAX MODULE, IGNITION CONTROL Logo
111 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
