Question about Mitsubishi WS-65611 65" Rear Projection Television
Remotes do not work and front panel will not allow me to select input or change volume
The remote will not work at all, power, volume chanel etc.  I can power up the tv from the front panel but I can not vhange channel, volume or select alternate input such as DVD.  I can move the selection icon over the device but it wont select it.
  • redwoodrich Dec 18, 2007
    I have the WS-65611. Last week the A/V select wouldn't go away while
    continuously scrolling through the devices, rendering the remote useless. At first I believed a button was stuck on the remote or TV. I used the A/V reset the first few times this occured. Now it won't go away. I now can no longer select other inputs as the TV was the last selected. The remote does nothing, the (scrolling) A/V selector icons will not go away. The main reset does not correct the issue. Any clues?
I figured it out. It is, in fact, the front panel board. Disconnecting it sloves all issues. A contact in one of the tact switches must be stuck or giving an abnormal resistance value to the system. Once disconnected, the remote works correctly. I'd rather replace the entire board than try fixing/replacing a tact button only to have another fail in the future. I've heard this has also been an issue with the power button.
Posted on Dec 19, 2007
SOURCE:
What code do I need for GE universal remote for Ario tv model 3269?
Universal remotes only cover the most basic functions (on/off, volume, channel) - they do not allow for menus , input selection, etc.
And code data, if available, is gotten on the web site for the universal remote. U can try attached site for remotes that might work for you. MCM Electronics Home and Pro Audio Video Security and Test Equipment
Nov 21, 2015 | Ario HC3269 32" LCD TV
I have a toshiba theater view sd tv but my phillips universal remote input button won't work and allow me to get to video one in order to play dvd player
Universal remotes offer limited functionality such as volume changes and channel changes, muting. Often, there is no working input function with those remotes and you have to get the original one for that to work. Ouch.
Jun 28, 2015 | Toshiba Televison & Video
Chanel button changes input
Try 124 code, might work for combo unit.
Aug 19, 2012 | Innovage Jumbo Remote Control
How to change input on tv without a remote
Which TV do you have? Some will have an Input or Source button on the front panel. A few will have an option to change the source from the menu. Both of these options require the front panel lock to be inactive.
A few older TVs allowed you to find the A/V input by pressing Channel Down on the front panel buttons until you passed channel 2 (or Channel Up until you nearly reached Channel 2). This option wouldn't work if the A/V inputs had been deleted when someone minimized going through unused channels.
If the Source or Input button was only available on the remote, you will need a universal remote that includes this feature. These cost a bit more than the lowest end remotes. Then you will have to try all of the codes to find the one that makes the Source button work with your TV. (Several codes may work for On/Off but not the change input.) The Universal remotes that can be programmed from a computer (USB connection) will be the easiest to set up. Remotes.com may have a replacement original or substitute remote for your TV that should work for all of the TV functions.
I hope this helps. Please add a comment with the TV make and model for specific options for your particular TV.
(low end TVs usually only had the Source/Input button on the remote.)
May 12, 2012 | Sony Televison & Video
My HDTV, 42", won't turn off, change
Check the tv manual control buttons right side of the tv bazel frame tv facing u,see if u can used the buttons like power, chanels - + or volumes - + from it.If u can, mean the tv have problems with is remote control.Change new batteries for the remote,still no response from the remote.Mean the remote is dead.Try website like Remotes.com to buy an exact remote or very close it.
Jan 17, 2011 | Sylvania LC420SS8 LCD TV
We lost the remote and we are trying to hook up our Wii to the front panel box. How do we change the input to the front panel without the remote
On the side of the TV there are a set of buttons. An Input button is next to the Menu button and will let you access the different sources connected to the TV. For the front panel input, look for the source labeled Front. (There are also volume control and channel +/- buttons.) The button order is Input, Menu, Vol -, Vol +, Ch -, Ch +.
If you want, you can get a substitute remote that is guaranteed to match the original remote's features here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=32V524T&uuid=12935850039140 .
I hope this wants.
Dec 29, 2010 | RCA 32V524T TV
Remote not working anymore for my LG 42PQ20. Ive tried changing
call LG if you think the TV is not accepting the signal from the remote the TV may have a fault in it. If you have any universal remotes try programing them to control the TV if they work but the other does not it is remote.
Mar 15, 2010 | LG 42PQ30 42 in. Plasma TV
Insignia NS-PDP50 Plasma TV - Remote Sensor failure
Change batteries.Reboot everythings.Tv unplug,replug couple mins later.Ur Directv box,push off/on for new update software.After that sould work.Rate me after u done this.
Jan 02, 2010 | Insignia NSPDP50 50 in. HD-Ready Plasma TV
With the JVC D-series TV do you need a Remote Control to turn on the input screen?
No. Almost all TVs can be turned on manually.
However, those of us who are TRUE couch potatoes would NEVER rise from our seated positions to do ANYTHING manually when there are remotes that allow one to do the same thing from a comfortable distance!!!
If you look on the right side or across the bottom front of the unit, you will see the various buttons for power-on, volume, channel selections, etc....
Jan 01, 2010 | JVC AV-32D305 32" TV
Mitsubishi WS-65611 65" Rear Projection Television Logo
175 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
