Lid switch The lid switch is broken and i removed the two screws that hold it in place but i cant figure out how to disconnect the wires
    President:
  • 1,136 Answers
Hi, You will need to take the two screw holding the control panel down. The control panel will raise up on a hinge and then you can see the lid switch connection.
Please let me know If I have helped or I can assist you further.
Thanks
Vic
Posted on May 11, 2009
It does not spin - error
Hi
Open the lid and reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced.
Examine the lid switch for wear. Replace a worn lid switch by first using a screwdriver to remove the top of the machine. Remove the cabinet holding the old switch in place by unscrewing the two console screws, tilting the console back, removing cabinet clips, and unlocking the lid switch block. Unscrew the mounting screws, and disconnect the ground wires before removing the old switch. Insert the new switch in it's place.
Look for excessive glazing or cracks on the sides of the belt. If these signs appear, remove the old belt by tipping the washing machine over on it's side, and unscrew the clamps securing the pump coupling with a screwdriver. Place the new belt over the transmission pulley, and then over the motor pulley's nearest edge, slowly turning the motor pulley to pull the belt around and into the pulley.
Replace the washer's motor by firmly grasping on the metal slip-on connectors holding the wires in place, allowing you to pull the connectors apart. Use a screwdriver to unscrew all of the screws holding the motor in place, and remove the old motor. Insert the new motor in its place. Secure the new motor to the machine with screws, and reconnect the motor's wiring harness.
Replace the washer's pump by removing the service panel on the back of the machine with a screwdriver and disconnecting the washing machine drain line and the rubber pump outlet hose. Remove the fasteners holding the pump to the bottom of the machine, along with the drive belt from the pulley below the pump. Replace the old pump with a new one, and reinstall the drive belt back on the pulley, reinsert the fasteners and reconnect the rubber pump inlet and discharge lines.
However there are various reasons as to why a washing machine won't spin. Also check this bellow link to troubleshoot your issue:-
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help#itdoesntspin
May 03, 2011 | LG Washing Machines
Fills with water then does nothing. won't agitate or spin. I checked coupler and it is fine.
The problem is with the lid switch. Disconnect both hot and cold water line from the water inlet valve. Mark the hot and cold so you don't get them mixed up. There are 2 philips head screws at the back of the machine, holding down the console to the cabinet. One in each rear corner. Slide the console forward slightly and tilt back. There are 2 metal clips that hold the cabinet and top to the back panel. Use a screwdriver and pry both clips up. ( pay attention on how to put the clips back). Disconnect the harness to the lid switch. Now stand in front of the cabinet and tilt forward towards you while pulling forward. Cabinet should slide forward. Once the cabinet has been separated fro the back panel, lift the lid up. On the right side of the lid you will see 2 screws. remove screws. (theses are the screws that secure the lid switch to the top). Now go to the back of the cabinet at the opening and look in the corner where you just removed the 2 screws, You will see a green ground wire screwed to the cabinet. Should be a 5/16 screw. (not 100% sure). Remove screw. there are 2 small clips holding the tubing for the wire harness in place. Popping both clips out should release the lid switch. Now disconnect harness holder from the top of the cabinet by pressing in the plastic clips at the side. Pay attention to the direction of the plug. Put the new plug in the same direction as the one you removed. Once you have inserted the plug and it snaps back into place, thread the tubing back behind both metal clips and clip those back in place. Secure the ground wire back to the cabinet. Now mount the lid switch back to the cabinet. You can do this with the lid up. Secure both screws into the lid switch. Close and open the lid to test the lid switch. You should hear a clicking sound. Now its time to put the cabinet back on.
Standing in front of the cabinet, tilt it forward towards you and line it up with the base frame. Tuck the front bottom lip on the cabinet under the lip of the base. Make sure that the tabs sticking up from the base lines up with the bottom of the cabinet. Be patient, may take you awhile to get the cabinet back in position.
Slide the back panel forward back in place. make sure it tucks into the back of the cabinet. Once its in place, now you can reinstall the two metal clips that secure the back panel to the cabinet. reconnect the harness to the lid switch. Tilt the console back down into place inserting the tabs on the side into place on the cabinet. Once in place slide the console backwards into place. You can now put the 2 screws back that hold the console to the cabinet.
That should do it. Plug the washer back in and start using.
Feb 14, 2011 | Roper RAS6233KQ Top Load Washer
How To Repair a Washing Machine That Won't Spin?
Instructions: 1)Open the lid and reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced. 2)Examine the lid switch for wear. Replace a worn lid switch by first using a screwdriver to remove the top of the machine. Remove the cabinet holding the old switch in place by unscrewing the two console screws, tilting the console back, removing cabinet clips, and unlocking the lid switch block. Unscrew the mounting screws, and disconnect the ground wires before removing the old switch. Insert the new switch in it's place. 3)Look for excessive glazing or cracks on the sides of the belt. If these signs appear, remove the old belt by tipping the washing machine over on it's side, and unscrew the clamps securing the pump coupling with a screwdriver. Place the new belt over the transmission pulley, and then over the motor pulley's nearest edge, slowly turning the motor pulley to pull the belt around and into the pulley. 4)Replace the washer's motor by firmly grasping on the metal slip-on connectors holding the wires in place, allowing you to pull the connectors apart. Use a screwdriver to unscrew all of the screws holding the motor in place, and remove the old motor. Insert the new motor in its place. Secure the new motor to the machine with screws, and reconnect the motor's wiring harness. 5)Replace the washer's pump by removing the service panel on the back of the machine with a screwdriver and disconnecting the washing machine drain line and the rubber pump outlet hose. Remove the fasteners holding the pump to the bottom of the machine, along with the drive belt from the pulley below the pump. Replace the old pump with a new one, and reinstall the drive belt back on the pulley, reinsert the fasteners and reconnect the rubber pump inlet and discharge lines.
thank you and hope this helps
Feb 09, 2011 | LG WFT1071TP Top Load Washer
Lid not turning washer on
Sounds like a lid switch problem most likely. When closing the lid, slowly lower it and listen/feel for a "click" when the lid is about 3 inches from being completely closed. If you don't, then you have a broken lid switch.
The model of washer you listed, TAWS800JQ, has two different possible lid switches and you get to them differently.
To get to the lid switch, you need to remove 2 screws that hold the control console in place. There is 1 on the left and 1 on the right of the console. They can either be on the front side and easy to see, or on the back side. Loosen those screws so that the console is free and you can flip it up and backwards out of your way.
One type of lid switch can be seen on the left side after you flip the control console up and back out of your way. There is just a little clip that holds it in place. The lid needs to be raised in order to remove the lid switch. Unplug the wiring harness and replace.
The other type, do this:
Then use a flat blade screwdriver to remove the brass spring clips on the left and right side of the washer that hold the front/sides/top on. Unplug the lid switch in the middle of the washer top and then you can remove the wrap-around cabinet. The lid switch is under the top and is held in place by clips and 2 screws.
May 29, 2010 | Estate TAWS800JQ Top Load Washer
Mine wont spin
Your problem is more likely a broken lid switch. To test for this, lift the washer cover and look for a small hole in the washer top where the cover was. Push a toothpick gently into the hole and press the piece of plastic you see in the hole downward and listen for a soft clicking sound. If you don't hear a click or the plastic tab is not in the hole replace the lid switch.
Unplug the washer. Check the actuator on the lid that operates the lid switch to see if broken. Open the console of the washer. After removing the screws, the console will lift up and hinge back. Disconnect the plug going to the lid switch. Picture. Check the lid switch [lid closed] with an ohm meter from the wire plug-in leading to the switch. If no continuity, replace the lid switch. You will need to remove the cabinet to replace the switch. There are only a couple screws holding the lid switch assembly and a ground wire connection to the cabinet. Reassemble the washer and test the operation.
Unplug washer, remove the two console screws and tilt console back, remove cabinet clips, unlock lid switch block and then remove the cabinet. Remove the lid switch mounting screws, disconnect ground wire and remove lid switch assembly. Compare old switch to the new one. If the plastic sleeve of the new switch is longer, break off at the score mark. Pull wire partially out of sleeve before shortening sleeve. If the sleeve had to be shortened, the wires must be looped to take up the excess wire. Use supplied wire tie from the new kit. Install new switch assembly. New lid switch
Pay VERY close attention to assembling case back onto base so that sides engage tabs in base.
Sep 21, 2009 | Whirlpool Washing Machines
How do I remove the cabinet on a direct drive washer. I have a bad lid switch.
The following link explains step-by-step how to replace a lid switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
You will need to remove the washer casing from the frame for better access to the switch. Once you disconnect the lid switch connector plug from the timer, push in on the release tabs of the white connector plug located on the washer casing and push it down through the hole it is installed in. Now reach under the washer top and remove the switch from the washer casing. Disconnect the ground wire and remove the screw(s) that hold the switch in place.
If you have the type of lid switch that is mounted near one of the lid hinges, this type unplugs and the mounting screw is removed, along with any ground wire.
If you have questions, or need additional assistance, please post back with your complete model number (located on a nameplate around the wash tub opening) let me know. I hope this helps you.
Sep 08, 2009 | Washing Machines
Whirlpool
If the motor makes no noise in the spin cycle only, it sounds like you need a lid switch.
Unplug the machine. Remove the end caps on both sides of the console by putting a flat screwdriver in the top of the end caps from the back and gently prying up. Remove the two Phillips screws holding the corners of the console down. Lift the console and gently fold back. Unplug the lid switch. That's the 3-wire quick disconnect below the timer. (If you have a high price model, you'll have three hoses under a plastic cover on the left. disconnect those hoses before going further.)
Using a flat screwdriver remove the gold clips holding the cabinet to the back. Place the blade of the screwdriver in the indentation closest to you and tilt the handle of the screwdriver back.
Open the lid. Lift and tilt the entire cabinet toward you. Look down through the hole to the front bottom edge of the cabinet. It is hooked under the front edge of the washer frame. Remove the cabinet and place it in a position you can work under it.
The lid switch is held in lpace with two Phillips screws on the right edge of the hole. There is also a 5/16 in ***** holding the ground wire to the cabinet. Install the new switch using all the clips and screws that were holding the old switch in place.
Pick up the cabinet, hook it under the front of the frame, and tilt it back into place. Push the sides of the cabinet in as you are tilting it back to make sure the hooks in the frame (back, sides) line up with the cabinet. You can know it's in place when the edges of the cabinet line up evenly with the edges of the back.
Re-install the gold clips. Hook them into the back panel, put them into the slots in the cabinet, and push down until they snap into place. Re-connect the lid switch. Lower the console. Replace the screws. Replace the end caps - bottom first, then snap them in at the top.
Happy washing!
Mar 11, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore Series 70 Washer Model 110
That would be your lid switch that has went bad.  Remove the console caps, then remove the two screws that hold it down (sometimes these screws are in the rear of the console)  Rotate the console out towards you gently, then fold it up and over the top of the unit.  You see 2 gold colored hold down clamps on top, and either side of the unit.  You will also see a wire and disconnect going down through the cabinet on your right hand side.  Disconnect these wires (be sure unit is unplugged) and rotate the whole cabinet towards you.  You remove the two screws that hold the switch in place and a 5/16" screw underneith that holds the ground wire.  Unclip the connector from the rear top of the cabinet and remove the switch.  Be sure to bring your whole model number 110.************** when you get the new part, there are two of these, and they look the same except the wire ends are different.  Good luck    Jim
Oct 16, 2007 | Washing Machines
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
