Question about Philips 43P8341 43" Rear Projection Television
Colour convergence on a projection TV
Hi. Philips projection TV 43PP7445. My television's red colour is not sincronized with the other two colours. The error varies on different areas of the screen. Adjustment as per the manual makes very little difference. Can you help please?
  • bernz bonds Jan 10, 2013
    mine replaced the convergence chip. tried to adjust in the menu using the remote but not works. fyi. hope this will help.
  • Philips Master
  • 1,525 Answers
Hello it sound like convergance chips may be the problem
shaun
Posted on May 11, 2009
    Filmmaker:
    Uploaded 5 video answers.
  • 41 Answers
If you have tried to adjust the convergence on your TV within the menu feature then typically you do have a convergence problem. Check out this video to be sure...
Posted on Oct 08, 2012
Tv picture settings for rear projector tv want colour settings for my tv
If you cannot align RED, BLUE, or Green your TV has a convergence failure. You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 20, 2011 | Philips 43PP9202 43" Rear Projection...
Im having colour problems with my phillips 43in hdtv blue and red lines across the screen tried to aligne but didnt help any ideas wat i can do
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 24, 2009 | Philips 55PP9363 55" Rear Projection...
Colours on the right side are unbalanced
run auto convergance from the menu it might be called touch focus on that model
Nov 21, 2009 | Toshiba 42H83 42" Rear Projection...
Philips rear projection TV component identification, what is it
They adjust FOCUS and Screen settings---they have nothing to do with convergence---if you have not touched them---do not---they are not real easy to reset correctly.
What is wrong with the set and what is the model number?
let me know and I will try to assist you
SD TECH
Oct 04, 2009 | Televison & Video
Problem with a colour display on Hisense tv
If your picures are all purple it means that the green colour is missing. TV colour is made up by mixing Red, Green & Blue. Removing Green leaving Red & Blue makes purple. Study the green colour circuit for a fault and confirm that the green gun inside the tube is working.
Aug 31, 2009 | Hitachi 60SBX78B 60" Rear Projection...
My television red colour is not sincronized with the other two colours. Adjustment makes no difference. The degree of error varies on the screen. Any help? reynier.vt@mweb.co.za
Hi, this will occur when your convergence board or chip is malfunctioning. This particular device(board) controls the collaboration procedure that regulates the RGB streams.
When the board or convergences chip becomes unstable, this will cause the issues you are experiencing at this time. Simply replacing the chip or the board will fix this issue.
Please rate and god bless:)
May 11, 2009 | Philips Televison & Video
Philips nr.43pp7445/69
I don't understand you language but I think you need both convergence amplifier IC's replaced. I hope this helps.
Aug 17, 2008 | Philips 60P8341 60" Rear Projection...
Hitachi 43FDX01B (convergence) problem
hi i have same prob iv bin told its a convergence chip an thay r £150 ! thay go bout evry 6 years an its comon .. any way there coming 2 fix mine 2day so ill let u know if it sorts it out my mail is mjoutlaw@hotmail.co.uk thanx
Jan 30, 2008 | Hitachi 51F500 51" Rear Projection...
Philips 50PP920217F remote/color
Requires convergence amp IC replacement ( two) and check
resistors in vicinity of IC's....fairly technical repair....Please read
some of my convergence solutions and let me know if you want
step by step instructions............................T.
Jan 23, 2008 | Philips 50PP9202 50" Rear Projection...
Colour problem on rear projection tv
This might be something really simple... In a large number of DPTV310 chassis, of which this TV is, the yoke connections where put in place with black electrical tape just below the retaining rings. Job is to loosen the rings, remove the tape and push the yoke back in place and tighten down retainer.. Be careful not to throw off the tilt of the yoke. The adhesive on the tape, over time, gets hot so many time it becomes slippery and allows the yoke to fall away from it's position dulling the look of the image (or focal length) causing the problem you're describing here... It also throws off the convergence - so in attempting to converge it just looks worse. Good Luck Bill
Jun 10, 2007 | Philips 60PP9352 60" Rear Projection...
Philips 43P8341 43" Rear Projection Television Logo
301 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
