Question about Hotpoint Ovens
Candy CPCA 270 FFK thermostat location
Does anyone know where the thermostat can be found in a Candy CPCA 270 FFK fridge freezer? It is not immediately obvious in either the fridge or the freezer.
Candy FPP609X oven not heating up
8888 usually means the clock needs setting as it has been disconnected from the mains.
Oct 07, 2017 | Candy Ovens
I have candy fst201 built in oven with no instructions, has anyone got any to download?
http://www.instructions-online.com/index.php/oven-candy-fst-201-1-x-stainless-steel-32532-manual
Feb 27, 2015 | Candy Ovens
CANDY OVG505 3N Instruction for installation Oven gas
Where is the owners handbook that should be with the oven? If you don't know what you are doing with gas appliances get an engineer. Go to a Candy main website for a download manual. try www.candy-domestic.co.uk click on "service" at the top, find manuals and there is a copy for OVG 505 2N. I don't know if its any help or not. If not try your Candy main web page.
Dec 05, 2014 | Ovens
Candy F254/3X heat non stop at full temperature
The thermostat is faulty and is stuck 'on'. Call an electrician or service person.
Feb 23, 2014 | Candy F248P Electric Single Oven
Ref/freezer not cold , even at coldest setting. Seems bottom oo fridge/frrezer colder than the top.
I have had a similar experience. Ice may accumulate inside the cabinet, adjacent to the thermostat, even on "frost-free" models. This can be especially troublesome if your home or climate isespecially humid. The ice tricks the thermostat into thinking everythingis cold enough, so the cooling unit simply does not turn on, and when it does come on it only refreshes the ice. Your first thought may be to defrost the fridge. You will have to empty the fridge, then leave it unplugged for a day or two. Be prepared for the melt water, it may run out of the cabinet and flow onto your floor. If this does not help, you will probably want to call a service tech, as fridges do wear out. But do your homework, new refridgerators have come way down in price, and there are incentives in many jurisdictions to encourage you to replace older units with newer, more efficient units. You may find it is a better idea to purchase a new one. I hope that this is helpful, Rob.
Jan 01, 2011 | Ovens
CANDY OVEN
It will be the oven element that has failed, you need to fit a new one.
It is located at the rear of the oven compartment.
Feb 22, 2010 | Candy F248P Electric Single Oven
Oven not heating but fan working
Candy Oven not heating? How to replace a Candy fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for candy element How to Repair Home Appliances
Jan 16, 2010 | Candy Ovens
Water works but icemaker does not. the freezer barely cools
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Nov 11, 2009 | Ovens
Ovens Logo
101 people viewed this question
Top Hotpoint Ovens Experts
Colin Stickland
Colin Stickland
Charles T Nevin
Charles T Nevin
Jacques Valiquette
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
