Question about Sharp Televison & Video
I'm can't find driver for monitor Sharp SH-2100D
I'm can't find driver for monitor Sharp TFT color LCD TV
model: SH-2100D
I cannot pay now.
Posted on May 20, 2009
Neither picture is displaying on moniter nor sound is coming (DELL TFT moniter)
Which is a dell tft or compaq crt monitor ?
The Dell 1504FP is a flat panel LCD monitor that has a viewable area of 15 inches.
The monitor, which uses TFT technology, is designed to be used in a home or office and displays video at a resolution of 1024 x 768 pixels.
Over time, you may encounter problems using your Dell 1504FP monitor or it may cease functioning altogether.
Fortunately, there are variety of ways that you can repair the monitor to get it back up and running.
Shut down your computer and press and hold the power button on the side of your Dell 1504FP monitor if your monitor has a blank screen.
Unscrew the VGA video cable that connects the monitor to the computer.
Power the Dell 1504FP monitor back on and wait as it launches into the Self-test Feature Check.
During this period of time your monitor will make settings changes to ensure that it functions properly with your computer.
Firmly screw the VGA cable back into the rear of the monitor to ensure optimal video quality. Power both the monitor and computer back on and wait for your computer's desktop to appear.
Power off your Dell 1504FP monitor if the screen is dirty.
Wipe down the monitor using a dry microfiber cloth to remove any dust particles or smudges that have accumulated on the screen over time.
Power the monitor back on when you are complete and resume using it.
Press the "Auto Adjust" button on the right side of your Dell 1504FP monitor if the display is blurry and images appear out of focus.
Unplug the monitor's power cord for thirty seconds if the problem persists.
Plug the monitors power cord back into the rear of the device and power it back on.
This will reset the monitor and your display should now be focused properly.
http://support.dell.com/support/edocs/monitors/1504fpis/en/trouble.htm
Troubleshoot a TFT Monitor
TFT monitors can suffer from many potential problems, ranging from simple screen brightness issues to disconnected inverter or LCD cables.
These can cause video- and backlight-related failures on your TFT monitor.
Fortunately, you can attempt to repair these problems, even if you have no experience fixing a TFT monitor.
The only tool you will need is a Phillips screwdriver, although opening your TFT monitor will likely void its warranty.
Check the brightness settings on the TFT monitor.
There are dedicated adjustment keys on the bottom face of the TFT monitor.
If it is a screen incorporated into the design of a laptop, you'll find monitor adjustment keys on the top row of the laptop's keyboard.
A TFT monitor that has its brightness turned all the way down will appear to be almost completely dark.
Ensure the TFT monitor's power cable is still plugged in, if it is an external monitor. In the case of a laptop, make sure that the power cable is plugged in or that the battery is properly charged.
Disconnect the TFT monitor from the power source. If the TFT monitor is an external model connected to a computer tower, disconnect the video cable as well.
Remove the battery from your computer if you are using a laptop.
This is an important safety measure.
Turn the laptop over and slide the battery release mechanism over.
This mechanism is just below the horizontal outline of the battery on the underside of the laptop.
Remove the screws on the bezel of the TFT monitor.
The bezel is the plastic piece surrounding the TFT screen.
The screws will likely be covered with plastic seals for aesthetic purposes, so pop these seals off with your fingers and remove the screws using a Phillips screwdriver.
Pry up on the bezel gently and remove it.
Start at one corner and work along the bezel's perimeter with your fingers.
There will be small plastic latches between the bezel and the rest of the computer you'll need to disengage.
Check the TFT monitor's inverter cable.
This black cable lies at the bottom center of the monitor and should connect to a socket on the inverter board, which is the green color horizontal strip that lies just below the inverter cable.
If the cable is loose from the board, the TFT monitor's backlight will fail. Pull up on one side of the socket and slide the cable back in, then press firmly down on the socket to lock it down.
Remove the metal brackets on either side of the exposed TFT monitor if the inverter cable fix does not solve your issue.
There will be two to three screws in each bracket that must be removed using your Phillips screwdriver.
Pull the TFT monitor carefully away from the rear casing of the display to reveal the LCD cable. This cable runs from the back of the TFT screen and should be connected to a socket in a similar fashion to the inverter cable. If it is disconnected, lift up on the socket, slide the LCD cable back in, then press down on the LCD socket to lock it back down.
NOW FOR SOUND
if you can get a screen
Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers
If your computer came with a motherboard disk the drivers could be on it
or you might download slimdrivers.
Rather doing a driver hunt
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
Note: it will find all of your outdated drivers
This is a free driver solutions
which will automatically search for and find the correct driver
You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
It might take some time being free
Aug 09, 2013 | HP COMPAQ 7540 CRT Monitor
Fuzzy screen on Gateway FPD1975W TFT LCD Monitor
With the pixels acting up and the monitor having the same problem on any computer that its connected to. The screen itself is bad and since there are no replacement screens for that monitor, you would have to buy a new monitor or get it replaced if its under warranty.
Jun 02, 2010 | Gateway FPD1975W 19" LCD Monitor
I had envision 19'' but image is not too sharp
What is the model of this monitor? You need to find out the native resolution of this monitor, then set your PC video resolution to that numbers for best picture.
Apr 19, 2010 | Envision 19" Widescreen Flat Panel TFT LCD...
Colors are off on various web pages--red links are blue--pictures and game screens are okay though --Windows XP Pro--TFT LCD Color Computer Display
install the drivers of display new if persist then insert AGP card in AGP slot of grade 8X because that is not problem inbuilt display card does not support games and movie
Mar 05, 2010 | Sony SDM-HX73 17" Flat Panel LCD Monitor
How do i open a Dell TFT monitor model 1505?
poginga, Try visit to YOUTUBE for video clips "lcd monitor disassembly" and or "lcd monitor repair" to get basic idea of how to !!! DO NOT USE SHARP BLADED INSTRUMENTS OR YOU WILL END UP IN THE LOCAL "ER" TRYING TO EXPLAIN THE BLOOD GUSHING OUT FROM YOUR BODY" 12fixlouie
Feb 22, 2010 | Dell E152FPc 15" TFT LCD Flat Panel...
ISH819 LCD MONITER WITH TFT?
This link, is to the User Manual for the Envision H 819 TFT LCD monitor,
http://www.technostation.com/user-guide-owners-manual/Envision/Envision++H819+LCD+Monitor
Under the User Manual heading, you will see ->
2009-04-08 12:20:36
To the right of that is -> cache <- in blue. Click on -> cache
The Envision user manual, plainly states that the Envision H 819 monitor, is a TFT monitor.
[18.5" (47.0cm) TFT Color LCD Monitor]
May 17, 2009 | Envision 19" Widescreen Flat Panel TFT LCD...
Connection diagram for pillow tft lcd color monitor
Need diagram for:
On Flap:
XF000FSCG5P
7 inch TFT LDC Digital Ca...Car Reaf View Camera Combl
Now
On Top:
12V-24V
Pillow TFT LCD color monitor
Apr 11, 2009 | Car Audio & Video
Discolouring of monitor
There are several reasons for this most likely is the vga cable from the video port has undergone stress (sharp bending or crushing) this damages the cables inside and causes one or more of the colors to not display, usually red and or blue. odd it seems the green always is left unharmed when I see this...weird.
If you can I would replace the cable from the monitor to the computer. if the cable is sealed in then you may be able to find a replacement at a service center. and they could replace it for you
Apr 30, 2008 | ViewSonic 19'' 1280x1024 TFT LCD BLACK: 's...
Televison & Video Logo
88 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
