Question about Whirlpool GD2SHGX Refrigerator
Kenmore 106-55539400 will not make Ice
My ice maker has a light sensor that shines a red beam across the ice bin (located on door), however, the red light just blinks. The refrig was without power for about one month, so I know the line is not frozen, nor nothing is obstructing it from making ice. The water dispenser on the door is working fine. I have replaced the filter, reset it and it is showing "good". I have also pressed the "Ice Acceler2" button, but NO ice. what else can I test? If I need to replace, how do I do it?
It sounds like your optic card. My friend fixed his by looking at this site.
http://www.anyonecanfixit.com/icemaker_optics.htm
Posted on Jun 03, 2009
My whirlpool conquest side by side frig purchased in 2008 has a red blinking light in the freezer the ice maker is not working at all.
The blinking light goes to the ice maker on/off sensor. This is actually a real easy fix. The sensor is bad and needs to be replaced. If you look at the blinking light you'll notice there are two screws holding that section in. Directly across from that is another white piece held in by one or two screws. Whenever you close the door the beam is complete and the ice maker will turn on. To order the parts, find your model number, which is normally located in the refrigerator side, and then call any parts distributor ( i use appliance parts depot), and tell them you need the ice maker sensor kit. Thecost shouldn't be more than $50 I think. Hopefully this helps and let me know if you have any other questions.
Dec 06, 2010 | Refrigerators
No ice production what does the red light mean
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
The red light is a sensor that check the ice level... make sure that nothing is blocking the beam so that it thinks the bin is full...
heatman101
Oct 27, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Kennmore refrigerator is not making ice,but water
The control light flashes to indicate the infrared beam is being blocked. The flap on the opposite side blocks the beam when the door is open to prevent ice from being dropped on the floor rather than in the ice bin. If you pushe the flap in so it's flush with the liner (use care not to block the hole) the light should go from flashing to on in a steady state. If not, your electronics are bad and would need to be replaced. If the light does glow steady, then the problem is with your ice maker, water valve or ice maker fill tube.
Dec 23, 2009 | Refrigerators
Ice Maker will not stop making ice
the beam is defective. Its called an optic eye it does tell the IM that the bins full and cuts power to IM when beams dont see each other.
Nov 04, 2009 | KitchenAid (KSRD22FKST) Side by Side...
The Kenmore Ice maker makes no ice. This is a side by side unit. The freezer is very cold. The water solenoid is not faulty, but is not turning on so the problem must be in the electronic ice level...
Good chance the water line near the ice maker motor is frozen. Thaw out the freezer for about 6 hours - move your frozen stuff to the refrig - ot should be OK - then back again after thawing. This alnost always works.
Aug 10, 2009 | Refrigerators
No Ice is being made. Water is being despensed at the door but it seems that no water is going to the ice maker. Have good water flow to the pump.
Is the ice maker turned on?  The on/off switch is located on the top right side of the freezer compartment.  The manual says that there is a sensor beam that passes from one freezer wall to the other to shut off ice making when the bin is full.  Check to make sure nothing Is blocking that signal beam and that the bin is correctly installed.
May 30, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker not working
In my freezer, there's an infrared beam positioned over the top of the ice bin. If the bin is full of ice, it blocks the beam and no ice can be made. In addition, when you open the freezer door, a small (2x3") door opens in the freezer to block the beam, again to prevent ice from being made while the door is open. Is anything blocking the path of this beam from one side of the freezer to the other?
Mar 15, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Press and hold the flapper in dont block the optics there is a light beam that goes across and you will see a u shaped notch in your ice bin on the door this determins when the bin is full when the beam is blocked it thinks the bin is full ..After pressing and holding the flapper in what does the red light do keep blinking ?? if so how many time before there is a pause and repetes if it stays on solid i need to know that too
Jan 28, 2008 | Kenmore 53703 / 53706 Stainless Steel Side...
Ice maker has ice in it but will not dump in bin!
before i would worry about the lights flashing lets pull the front cover off of the icemaker and verify that the drive gear is not broken.
on the bottom of the icemaker is 1 screw. remove that screw then just slide the entire icemaker out of the refrig so that you can access the front cover. if the gear is broken just replace the front motor module pt# 8201515
if the gear is fine then located in the toe grille of your refrig is a tech sheet that will help you troubleshoot red light blinking.
Dec 17, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Optical sensor or valve problem
Your ice maker has an automatic shutoff. The ice maker sensor passes a beam from one freezer wall to the other, automatically stopping ice production when the storage bin is full. When you open the freezer door, you should see a red light on the top right freezer wall.When the freezer door is open or the ice storage bin is removed, the sensor cover or "flipper door" on the left wall of the freezer stops the ice maker from producing ice by blocking this sensor, When the beam is blocked, the red light on the right will blink twice. This is normal operation. as for the blink twice and pause I'm still checking on that. Make sure the water flow is coming from the solenoid valve located on back and bottom of refrigerator to the ice maker. Check the solenoid to see if the magnetic field is pulling the internal plunger open when ice maker ask for water. That can be checked with a multi meter at the wireing going to the solenoid and if the ice optics are telling the tray to fill voltage should be present. Insure that water supply is not restricted before it comes to the solenoid , like a bent line or clogged piercing valve.  Check that an ice cube is not jammed in the ejector arm of the ice maker. Remove jammed ice from the ejector arm using only a plastic utensil so the ice maker is not damaged. Call toll free in USA and a trained consultant will be happy to assist you. 1-866-698-2538
Oct 22, 2007 | Whirlpool GC5SHEXN Side by Side...
Whirlpool GD2SHGX Refrigerator Logo
415 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
