Question about NexxTech N500D 5-Disc
Lcd display is not in synk the first 3 dashes are higher
Than the last 4(- - --_ _ _ _ )
    Genius:
  • 1,148 Answers
TRY BLOWIN IT OUT WITH A AIR COMPRESSER
Posted on May 15, 2009
How to clear the usage counter?
From Samsung site:
1. Press MENU # 1 9 3 4 in sequence rapidly. The LCD panel should now display TECH.
2. Press MENU, and then press ENTER. The LCD panel will display Tech Mode.
3. Press the left arrow (<) button once. The operator panel will display NEW CARTRIDGE.
4. Press ENTER. The operator panel will display [YES].
5. Press ENTER. The toner warning message should be gone.
6. To exit TECH MODE, press MENU # 1 9 3 4 in rapid succession, as if you were dialing a phone number. The operator panel should no longer display TECH.
Oct 18, 2014 | Samsung 5pk - Scx-4521 Scx-4321 Scx-4521d3...
I forgot the securitty code of my phone 1110.
You just use following links to get that code-
· http://www.giveawayoftheday.com/restriction+code+nokia+2700+2/
· www.unlocks.co.uk/enterrestrictioncode.php
· www.unlock-free.com/nokia-master
· http://www.syednetworks.com/general-nokia-secret-codes-for-all-phones
or
#7780# reset to factory settings.
*#67705646# This will clear the LCD display (operator logo).
*#0000# To view software version.
*#2820# Blue tooth device address.
*#746025625# Sim clock allowed status.
*#62209526# - Display the MAC address of the WLAN adapter. This is available only in the newer devices that support WLAN
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
OR
ENTER CODE WITH OUT SPACES
Remove sim first, press #
Press * 3 times fast for (p)
Press * 4 times fast for (w)
Press * 2 times fast for (+)
Verify code before pressing the last #.
"Code error", don't try again!!
"Phone restrictions off", it's unlocked!!
i got from this websitehttp
://forums.afterdawn.com/thread_view.cf...
not my work its sum 1 elses
May 09, 2011 | Computers & Internet
Toner not reset
Mar 01, 2011 | Samsung SCX 4521F All-In-One Laser Printer
How to reset the scx 4521
6. To exit TECH MODE, press MENU # 1 9 3 4 in rapid succession, as if you were dialing a phone number. The operator panel should no longer display TECH. www.nakshatraworld.com
Dec 08, 2009 | Samsung SCX-4521 All-In-One Laser Printer
Compaq TFT 8020 Display Problim
have you tried going to menu and setting back to factory defaults? also, disconnect power cable and leave unplugged for 1 minute. Plug back in then see if problem is still there. Otherwise, something is wrong with the monitor that will need serviced or exchanged.
Jun 24, 2009 | Compaq TFT8020 (White) 18" LCD Monitor
IBM T30 LCD replaced - now LCD display not right resolution
Yes you can do that by trying to set the sesolution settting.
Step for setting up screen resolution
1.Click start-->Settings-->Conteol Panel-->Display
2.Under Display Properties window click the last tab name settings
3.Below you should be able to see Screen Resolution
4.Try to adjust the resolution here.
** Please try to reduce the resolution ...or sometime add more resolution
takecare.
Apr 29, 2008 | IBM ThinkPad T30 2366 Notebook
My P35 S-611 not show VGA video
Check the refresh rate of the LCD, may be too high. Try at 60hz first.
Set the display to 1024x768 or 800x600 then go higher... allowing it to revert back to previous mode if nothing shows.
(some/most CRT monitors cannot display widescreen format)
Set at 60hz using a CRT (you will see flicker on CRT) - then switch to LCD
Apr 18, 2008 | Toshiba Satellite P35-S611 Notebook
Problem with the vga cable
Put the connector infront of you and take biger size to top and smaller to down then count the pins like this-1=red,2= green,3 =blue(count the pins right hand side to left hand side),4=ground,5= blank,in lower row 6=red ground,7= green ground,8=blue ground,9,10,11=blank,12,15= in command section,13=horizantal synk,14= vertical synk.Hope this solution works otherwise i am always for help you.
Mar 31, 2008 | SAMTRON 55V 15" CRT Monitor
NexxTech N500D 5-Disc Logo
Top NexxTech Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Pieter Vleeshouwers
Pieter Vleeshouwers
Willem.
Willem.
Are you a NexxTech Audio Player and Recorder Expert? Answer questions, earn points and help others
