Question about Canon CanoScan 4200F Flatbed Scanner
Scanning slides with anoscan 4200F
When scanning slides, the scanner scans 2 or 4  slides OK and  then starts scanning part of the slide mount on the left, and cutting off the corresponding amount on the right. If I leave it for a day or two it will scan 2 or 4 slides OK but then starts scanning the mounts again.  The local agents attitude is "buy a new scanner"!!!   The scanning on the platen gives no problems.
  • 657 Answers
Re: Scanning slides with anoscan 4200F
Have you tried checking for a firmware update from the manufacturer?
Posted on Oct 13, 2007
0 characters
3 Points
My scanner is not work!! the error code is # 2,178,0!!! canner model is 4200f. pls help
Make sure if your scanning documents that the white plastic shield is on and if your scanning film this need to be removed. Make sure you also selected the proper item that you are scanning.
Mar 28, 2011 | Canon CanoScan 4200F Flatbed Scanner
Can I scan slides with Canoscan LiDE600F
Yep, The Canoscan LiDE600F is capable of scanning slides, however it is not possible to scan them in their mounts. If you dismount the slide, you can scan them using the film strip holder. This is not an elegant solution and you would have to remount your slides to use them as originally intended.
May 05, 2010 | Canon CanoScan LiDE 600F Flatbed Scanner
Black and white photos from many years ago now have a blue-green hue on them when they are scanned. it started after I scanned old slides.
Did you make changes to the scan type when you scanned the slides? It sounds like you have the scanner set to do a negative image as a slide would need.
Check the preferences for the scan type.
The scanning manual is available on Canon's Website.
Mar 17, 2010 | Canon CanoScan 4200F Flatbed Scanner
Slides scan as negatives
this scanner usb cabal no didact tell me bored problam ya cabl problam 6600E
Feb 04, 2009 | Canon CanoScan 4200F Flatbed Scanner
Pictures scanned with Canon 4200f show streaks
when scanning photos and especially magazines, don't go to low on the dpi (at least 300) and select DESCREEN as well as grain correction: HIGH
Dec 31, 2008 | Canon CanoScan 4200F Flatbed Scanner
Scanning 35 mm slides
Jul 28, 2008 | HP Scanjet 4470c Flatbed Scanner
I have a CanoScan 5200F
Because the slides are see through which means you will need a special add on for the scanner for it to support slides. If you have this already then make sure that it is fitted on properly so no light can get in the compartment where the slides are held during the scan
Jan 12, 2008 | Canon CanoScan 4200F Flatbed Scanner
Scanning for video
After the first scan through select the zoom in functionality to just scan the area you want to zoom in. That way the scanned image will be much bigger and better quality.
good luck
Dec 09, 2007 | Canon CanoScan 4200F Flatbed Scanner
Scanning slides with the Epson Perfection 1250
To be honest, I have no idea of how you were able to scan larger transparencies in the past. The scanner and its software were never designed to do this and there is no workaround.
Feb 04, 2007 | Epson Perfection 1250 Photo Flatbed...
Canon CanoScan 4200F Flatbed Scanner Logo
306 people viewed this question
Top Canon Scanners Experts
 Mike M
Mike M
D. E. Hev
Mohan Sriraman
Mohan Sriraman
Are you a Canon Scanner Expert? Answer questions, earn points and help others
