Question about Tefal Aquaspeed 170 Iron
HOW TO DISMANTLE A TEFAL ULTRAGLIDE EASYCORD 60 IRON
I HAVE REMOVED ALL 3 VISIBLE SCREWS SECURING THE BACK PLATE AND UNCLIPED THE TOP FROM THE BASE BUT THERE SEEMS TO BE SOME OTHER FIXING THAT IS SECURING THE TOP TO THE BASE. ANY SUGGESTIONS?
JOHN G
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Tefal Express 1750 has water dripping from it when using steam
That means that water is not heated properly and does not produce steam.
Try a complete descaling, often this happens because the water reservoir and heating element is covered with scale.
Posted on Feb 17, 2009
clyde2j2
  • 137 Answers
SOURCE: how to clean my iron
Put a tablespoon of vinegar in a glass of water and pour it into the water tank let the iron set for about an hour pour the water out and rince real good the sediment should be gone if not use sometning stronger like diluted "LimeAWay".
Posted on Mar 24, 2009
How to dismental a tefal Fv3530 steam iron
You should find some screws around the body, maybe it is hidden with a plastic plug
Mar 14, 2013 | Tefal UltraGlide Easycord FV4256 Iron
Replace worn electrical cord
Terminal block is fastened/secured with body by a screw but before removing the terminal block from body, make sure that the iron element terminals are also disconnected. this can be done by opening the screws on other side of the cord terminals-3 in number as also in the cord. Otherwise the terminal block would not come out fully.In any case you normally do not need to remove the terminal block.
Apr 05, 2012 | Tefal Irons
Where do I obtain a tool to unscrew the screws on my Tefal steam Iron?
buy a set of security bits from an electronic supplier.Can be bought in sets of 24 most used tamper proof bits that will fit into a multi screwdriver.
Aug 06, 2011 | Tefal UltraGlide Easycord FV4256 Iron
I need descaling instructions for Tefal Ultraglide easycord55...Mislaid instruction booklet....Thank you
thank you solved de scale instructions for Tefal Ultraglide easycord 55, found manual on net....
Jan 09, 2010 | Tefal UltraGlide Easycord FV4256 Iron
The auto stp security light is on and the iron does not heat up i have a tefal ultra glide iron
i'm not quite sure what the STP security light is but on my iron a security light comes on when the iron is idle. It shuts the power to the iron when no movement has happened mine is about 5 mins.
Sep 16, 2009 | Tefal UltraGlide Easycord FV4256 Iron
Red light on
element is shot,take it back or send it back for repair
May 31, 2009 | Tefal UltraGlide Easycord FV4256 Iron
Tefal steam iron not heating up properly
That is probably because the contacts to the element at the base of the iron are broken.
To disassemble you have to remove the casing, then remove the steam pump at front top of iron and then undo the safety screw mounted on the front of the base plate.
Apr 22, 2009 | Tefal UltraGlide plus 1656 Iron
Red light on
Per the owner manual, you shake the iron to "wake it back up".
The safety cycle initiates after it sits over 8 minutes on it's heel, or on it's sole plate or it's side side for more than 30 seconds. The light shoul dbe blinking when it is in the safety mode.
If you can't wake it up, then return it if it is still under new warranty.
Jan 30, 2009 | Tefal UltraGlide Easycord FV4256 Iron
Tefal Aquaspeed 170 Iron Logo
342 people viewed this question
Top Tefal Irons Experts
Billy Detlefsen
Are you a Tefal Iron Expert? Answer questions, earn points and help others
