Question about Yamaha iiyama 17NE1-S e-yama 17" LCD Monitor
E-yama monitor "out of range"
Moved monitor to another pc but screen displays message "out of range"
Help
I HAVE THE SAME PROBLEM AS ABOVE BUT ONLY HAVE XP
Posted on Nov 10, 2009
The fix was pretty easy in the end.
Instructions are based upon Windows XP Pro OS.
Re-boot computer but inerrupt start-up by pressing F8 (option will vary between computers)
Select SAFE mode but with VGA option in order that the screen will actually display.
Once fully loaded click:
Start
Control Panel
Appearance and Themes
Display
Settings
Using the mouse cursor adjust Screen Resolution sliding scale until the ratio matches your monitor e.g. 1280 x 1084
Then click Apply and OK (important to do it in this order otherwise changes will not be saved)
Reboot as normal and the monitor should now display correctly.
Posted on May 12, 2009
Get rid of "Out Of Range" message on e218c1 monitor.
The device driving the monitor is exceeding the horizontal and vertical frequencies that the monitor can display .....thus the "out of range". The specs for this state that the Horizontal Freq. is 80Khz and the Vertical Rate is 75hz. If you are driving this monitor from a computer running Windows, reboot the PC and use the F8 key to put it in SAFE mode. This will cause the video driver to default to a rate that the monitor can handle. Then go into the screen resolution settings and reset them. The native resolution of the monitor is 1680x1050 at 60 Hz. Exceed that and you'll get the "out of range"
Sep 10, 2014 | Envision Peripherals 22"" envision e218c1...
HPL1506 The input signal from pc display foe few seconds and goes off error recommended setting - 1024 x 768 - 60Hz
It can be that your PC video resolution is set higher than 1024 x 768 @60Hz for the monitor to display correctly.
Spec: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00485268&lang=en&cc=us&taskId=101&prodSeriesId=1130384&prodTypeId=382087
Try this per HP:
HP Business Monitors - What Do I Need to Do When the Message Sync out of Range Displays on the Monitor? ISSUE: What do I need to do when the message Sync out of Range displays on the monitor? When the video card signal exceeds the frequency allowed for the monitor, the following error message may occur: Sync out of Range SOLUTION: To avoid the message, lower the resolution or vertical frequency of the video card. Reboot the system and use the VGA mode to force the video card driver to lower its resolution. Follow these steps.
  1. Shut down and restart the system. For consumer systems such as HP Pavilion desktop PCs, push the Power button once. For commercial systems such as HP business desktop PCs, hold down the Power button for five seconds.
  2. Immediately after seeing the HP/Compaq logo screen, press F8 at system startup to initiate the bootup menu.
  3. Scroll down to highlight Enable VGA Mode , and press ENTER .
  4. After Microsoft Windows completes its bootup process, access the Display Properties and select a desired resolution, which is compatible to the connected monitor.
May 20, 2010 | HP L1506 15" LCD Monitor
Analog out of range display on the screen
try the lcd monitor on another PC, if the same message pops out, your monitor needs reprogramming of its A/D board, bring it to a LG service center..
if it works fine on another PC, try to boot your PC on VGA mode..
May 10, 2010 | LG 22" FLATRON LCD Monitor
Frequency out of range 11khz/ 119khz message
The PC is sending out the resolution that is too high for the monitor to handle, you need to set the resolution of the PC to be the native resolution of the monitor and set the refesh rate to be at 60Hz.
Jan 12, 2010 | Envision H191W Monitor
My ViewSonic computer monitor keeps displaying a Vga Not Support Message upon booting then the message Out Of Range comes up on a completely dark screen. Need Help
It sounds like the computer is trying to use a resolution that the monitor cannot handle. Boot into safe mode by pressing the f8 key during boot up and select safe mode. Once booted, right click on the desktop and select properties. In settings lower the resolution by moving the bar to the left and reboot.
I would move it all the way down, you can then move it up a step at a time once you are in normal mode again.
Hope this helps
May 02, 2009 | ViewSonic VA721 17" LCD Monitor
Showing message out of range
Your monitor settings within windows are set too high for the monitor to display... When computer first boots.. be ready and press the F8 key...
Enter safe mode.. Reset the display properties in control panel to 800 by 600 for a start. Setting the resolution too high past the monitors ability will give you that message.. Most monitors are able to display 1024 by 768 just fine.. Out of range.. means the display settings within windows are out of the monitors range of ability to display the screen resolution you have set... Good luck!!
Feb 18, 2009 | Dell Dimension 8200 PC Desktop
Need a replacement LCD
Yes you can go to any tv engineer tell him to replace crt (picture tube) if he agree then purchase new picture tube and replace it if only cabinate is brocken then replace cabinate take care that the reparing cost will not exceed monitors cost if you are a engineer then while reparing yoke coil connect properly it can fit only right not reverse
Oct 31, 2008 | iiyama E-yama 17NE1 (Silver) Monitor
Can you help I have just treat myself to sky hd my monitor has a dvi socket on the back so I got a hdmi to dvi connector the problem is the monitor displays a out of range message ! any ideas ?
Hi...there,
Your screen resolution settings are to high...plugged into another monitor right click and go to properties and click on settings to resettings by moving the bar back to 1 or 2 knots from your monitor.
Oct 19, 2008 | BenQ FP91G+ 19" LCD Monitor
Display monitor
Assuming that there is no hardware fault, this is indicative that your PC's Screen Resolution and/or Screen Refresh Rate are higher than what the monitor can display.
To correct, start your PC in Safe Mode, go to Display Properties (right click on any clear area of your desktop, click on Properties, click on Settings tab, move Screen resolution towards left or 800 X 600 and lower Color quality to 16 bit) and lower down all settings (including Advanced/Monitor/Screen refresh Rate). Reboot.
Once in Normal Mode, do the same again and increase settings one step at a time and click OK/Apply. In the event that the display disappears again, hit escape and/or revert back to last known good setting(s).
Hope this be of help.idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 19, 2008 | ViewSonic (CO21)
Out of Range message on monitor after T5300 finished booting. No Image.
The out of range refers to the screen resolution size of your pc as apposed to the monitor. It is unable to operate at the set refresh rate and screen res.
Jan 31, 2007 | HP T5300 (dc643a#abu) Network Terminal
Yamaha iiyama 17NE1-S e-yama 17" LCD Monitor  Logo
624 people viewed this question
Top Yamaha Computers & Internet Experts
Tony
Carlos L. Burgos
Carlos L. Burgos
Matthew Spark
Matthew Spark
Are you a Yamaha Computer and Internet Expert? Answer questions, earn points and help others
