Question about Lands Phones
I want to program phone # so my retarded brother can use 1 # to get through.
  • anniessj May 11, 2009
    It is a GE phone. There is no other manufacturer on phone.
    Sergeant:
  • 296 Answers
Hi
sendin you a site regardin how to program phone.
http://support.sprint.com/doc/sp11325.xml
plzz chek it thoroughly to get your phone programmed.
hope you will b helpfull.if you r satisfied,plzz do rate this answer.
all the best.
thankyou.
Posted on May 11, 2009
Mfc1475pw/all in one/how to install
I was looking for one hour some drivers, coudn`t find even on original website this model, try to install some different model, sometimes it works, sorry I can`t help you. Or you can download some portable program to find the driver, just download and unpack, turn on the printer and open this program
http://www.tactools.ru/iobit-driver-booster-pro-1-1-0-551-final-datecode-26-11-2013-portable/?utm_source=rss&utm_medium=rss&utm_campaign=iobit-driver-booster-pro-1-1-0-551-final-datecode-26-11-2013-portable
http://www.brother-usa.com/Support/Default.aspx?PGID=2#.UrCdobTCemp
Dec 17, 2013 | Brother FAX 930 All-In-One Thermal Printer
I have a f150 04 and the code p0012 came up fills like your on a bull when driving intake retarded bank 1 is what came up on the scanner
P0012 A Camshaft Position - Timing Over - Retarded (Bank 1 A P0012 DTC trouble code may be caused by one or more of the following:
  • Incorrect camshaft timing
  • Wiring problems (harness/wiring) in intake timing control valve control solenoid system
  • Continuous oil flow to VCT piston chamber
  • Failed timing valve control solenoid (stuck open)
Jun 13, 2011 | 2004 Ford F150
Ml350 replaced a/b cam position sensor reset computer & and erra codes p0016/p0016 check engine ligth is reset car drives with light off when engine is turn off and started the light goes out if you...
P0010....'A' Camshaft Position Actuator Circuit (Bank 1)
P0011....'A' Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0012....'A' Camshaft Position - Timing Over-Retarded (Bank 1)
P0013....'B' Camshaft Position - Actuator Circuit (Bank 1)
P0014....'B' Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0015....'B' Camshaft Position -Timing Over-Retarded (Bank 1)
P0020....'A' Camshaft Position Actuator Circuit (Bank 2)
P0021....'A' Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0022....'A' Camshaft Position - Timing Over-Retarded (Bank 2)
P0023....'B' Camshaft Position - Actuator Circuit (Bank 2)
P0024....'B' Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0025....'B' Camshaft Position - Timing Over-Retarded (Bank 2)
I think your sensors are pattern parts and the readings /resistances are not the same as the original parts ,try some bosch units is my first suggestion ,
Nov 02, 2010 | Mercedes-Benz ML350 Cars & Trucks
How do i set the timing on a 95 yz 250 yamaha
Here is the master thread for you:
http://www.thumpertalk.com/forum/showthread.php?t=673641
and some info to start:
Table of Indicator Readings to Advance Specs.
.027 5 degrees advanced
.022 4 degrees advanced
.018 3 degrees advanced
.014 2 degrees advanced
.010 1 degree advanced
.007 Stock Setting
.004 1 degree retarded
.002 2 degrees retarded
.001 3 degrees retarded
.000 5 degrees retarded (the limit of travel of my stator)
-.001 7 degrees retarded (the 3 to 5 and 5 to 7 jump are correct due to rod angle)
-.002 8 degrees retarded
Jun 17, 2010 | 2003 Yamaha YZ 250
I have a Brother IntelliFax-4100e fax that speed dial button 04 needed to be changed when we changed our phone system to include a 9 at the beginning of the number. Did that, it was 'accepted', but still...
go into menu, then to fax (hit set) then one touch speed dials (hit set) then hit the 04 one touch button and it should show you what is programmed. You can hit number 1 to change, type the number with a 9 in front of it(ie. 9+1+area code+7 digit number) then hit set and program a name for the number, hit set until the fax beeps to accept the change. You can test it with a blank cover sheet. That's how I have mine at work set up and it works fine. Hope this helps.
Jan 29, 2010 | Brother IntelliFax-4100e Fax
P 1383 cougar 2000
P 1383 Variable Cam timing over-retarded (Bank 1) meaning the comprehensive component monitor (CCM) monitors the VCT position for over - retarded camshaft timing . The test fails when when the camshaft timing exceeds a maximum calibrated value or remains in an retarded position.
Cause :
* Cam timing imprperly set * Continuous oil flow to the VCT piston chamber
* VCT solenoid valve stuck open.
* Camshaft advance mechanism binding (VCT UNIT)
Hope that helps
Jul 08, 2009 | 2000 Jaguar S-Type
After 4 rings our fax machine picks up automatically,
Your owner's manual will tell you how to program the MFC. There is one on the install disk, too. If necessary, you can get one by Googling your machine.
Mar 28, 2009 | Brother MFC 7420 All-In-One Laser Printer
Program Fax-930 brother machine so it answs fax call on 6 rings
Here is the users manual for that;
http://www.fixya.com/support/p170643-brother_fax_930_all_in_one_thermal/manual-1604
Mar 16, 2009 | Brother FAX 930 All-In-One Thermal Printer
I need a phone number to call tec support
The phone number for customer service at Brother International is: 1-877-Brother (877-276-8437).
You can also attempt to contact tech support through a variety of other options, provided to you at the Brother International website.
Hope this answers your question, and please do not forget to rate my solution.
Jul 17, 2008 | Brother Office Equipment & Supplies
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
