Question about ViewSonic VP140 Monitor
Lcd problem i have view sonic VA1703WB the screen appear a very bright screen it loks white screen...whats the problem for this? please help me.
3 Suggested Answers
SOURCE: Horizontal lines are appearing and moving acrosss the screen of my View Sonic E50C Monitor...
What is wrong with your monitor is that the Horizontal section is going faulty, the lines you are seeing are the Horizontal Retrace lines, usually invisable in a working unit. It is often a faulty capacitor(s) OR a Diode breaking down.. in the area of the Flyback Transformer. Probably time for a new one unless ya can fix it yaself.
Posted on Jul 30, 2007
  • 159 Answers
SOURCE: View Sonic VX910 LCD Monitor - Power Supply Board
I have been repairing them through ebay due to the fact that they are not available to buy right now.
They've been out of stock for what seems like forever !!
Posted on Oct 20, 2008
SOURCE: AOC LM 720 Flat Panel LCD Monitor
try to check the capacitors
Posted on Jan 08, 2009
0 characters
1 Points
Fading colour
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 07, 2014 | ViewSonic VA1703wb Monitor
I have view sonic VA1703wb lcd & the problem is screen is blinking all capacitores r ok but still this problem so any one have a solution of this problem ?
The only thing you can try is turn down the brightness, this will address some monitor issues, if this fails the inverter transformers should be suspect.
Mar 05, 2012 | Computer Monitors
Va1703 wb blinking problem
That is a sure indication of a failure in the power supply board. The problem is that Viewsonic used two different power supply boards in the va1703wb model. If you want to do the repair yourself you should be able to. If you can open the unit and send a picture of the power supply board to us at we would be glad to show you what parts need to be replaced to rebuild the board and get it back up and running.
Feb 15, 2012 | ViewSonic VA1703wb Monitor
The view sonic VA1701WB display is totally white on the screen during up the computer and i check the CPU is booting up but at the same time monitor screen is totally white please reply the reason.
It can be due to:
Dead T-CON board on the LCD panel assembly due to blown fuse or just dead board.
Dead power supply on the logic board that supplys the power to the T-CON board.
Learn more here:
Basic LCD monitor troubleshooting guide:
Failed TV and Monitors:
Oct 19, 2010 | ViewSonic VA1703wb Monitor
In my View sonic CRT monitor E71f 17",there is a curve appearing on the upper side of the screen and there is some space between the display and the screen, please help. thanks
It's time to responsibly recycle your old CRT monitor, and spend about $100 to buy a new 17" or 19" LCD screen, rather than spending any money at a qualified TV/video technician, trying to trouble-shoot the problem.
Oct 17, 2010 | ViewSonic E70f 17" CRT Monitor
View sonic va1703wb model no: vsa11534 serial no: qfcko70600651 is it warranty please tell me because my mointor was no display
Follow the following steps:
To obtain warranty service, email
To obtain warranty service, the following will be required :
The original dated sales receipt (include reseller name, address, phone #, product model, product serial number, and your name if applicable)
Your name
Your company name
Your shipping address (no P.O. Boxes accepted)
The serial number of the product
A description of the problem
Feb 03, 2010 | ViewSonic VA1703wb Monitor
Monitor brightness contrast problem
Turn Off auto-adjustment screen
Jul 29, 2009 | Proview PL19Wb Monitor
Problem with View sonic monitor
Hold down CTRL+ALT and hit the up arrow.
That should rotate your screen.
Aug 07, 2008 | ViewSonic VX924 19" LCD Monitor
Monitor won't display resolution properly after Windows Update
I was having the same problem. Believe it or not I fixed it by unplugging the monitor, and when I restarted my PC I again had the 1440 × 900 option.
Nov 06, 2007 | ViewSonic VA1703wb Monitor
ViewSonic VP140 Monitor Logo
18 people viewed this question
Top ViewSonic Computer Monitors Experts
Kirk Augustin
Kirk Augustin
john h
Are you a ViewSonic Computer Monitor Expert? Answer questions, earn points and help others
