SOURCE: Dome light in 1994 Chevy Cavalier will not turn off
Check the plunger switch.Most of them just snap in to the side of the dash.Un plug wires to see if light goes out,could also be your dome light switch.
SOURCE: 2002 Chevy Cavalier won't start. The service light
this is a common problem with the passlock system im sure like everyone else you will have to get a new ignition cylinder/switch
SOURCE: 98 chevy cavalier turns over but won't start
i know industry jargon can be confusing, but lets try this. if it turns over but won't start, it could be your ''ignition module'' that sits on top of the vave cover on the motor or it might be the fuel pump or filter. make sure when you crank the engine that the key is all the way turned or it may not always make a proper contact to activate the ignition module. iv'e seen this before & had to change the ignition switch & all worked ok after that. i would need to know engine lt size to give you more details on the matter. please get back to me.
try locking your car with the key and unlocking it with the key, leave it for 30 second or so between the locking and unlocking , the car thinks some one has tampered with it
