Question about Sony DAV-HDX500 System
I remove all the speaker wires but still the Push Power Protector still flashes on the screen. What should I do? Aside from consulting the nearest Sony dealer.
3 Suggested Answers
SOURCE:
welcomejee
  • 10594 Answers
SOURCE: why does push power protector keeps flashing in
This is an error massage and comes when home theater got some internal problem specially in amplifier output section that can have defective output IC etc.
It is not user level repair and requires qualified tech for fix.
Thanks.
Posted on Sep 14, 2009
dmftrucker
  • 1922 Answers
SOURCE: IT DISPLAYS PROTECTOR PUSH POWER
its in standby, try it again, if it does it repeatedly theres a problem in the switching power supply not letting it power-up to save components
Posted on Oct 18, 2009
MY SONY HBD-DZ810 HOME THEATER IS CONSTANTLY SHOWING PUSH POWER PROTECTOR
The "PROTECT" and "PUSH POWER" messages will flash alternately when the protective device of the amplifier has been activated because a strong signal was input, or if there is a short-circuit detected. Press the POWER button on the unit to turn off the system, and check the following items after "STANDBY" disappears.
1) Are the + and - speaker cords short-circuited?
2) Are you using only the specified speakers?.
3) Is anything blocking the ventilation holes of the system?
You may also refer to the following link for additional troubleshooting steps.
PROTECT and PUSH POWER flash alternately on the amplifier screen
Dec 20, 2012 | Sony DAV-HDX500 System
When home theater is turn on, protector push power is flashed on thee screen. player will not function further. volume level is 9. currently can't be turn down.
Protector means there is a short circuit somewhere in either the speakers, the wiring or inside the unit itself....you can try disconnecting all the speakers and then turning on the unit...if the protector goes away, then you have a bad speaker or bad wiring to the speakers....if the problem stays, then there is a faulty circuit in the receiver itself and will need to be serviced
Feb 05, 2011 | Audio Players & Recorders
When I turn on my Home Theater Sony Model hcd-hdx576wf this message appears, "protector, push power". what I can do?
Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
1. Check the speaker wires and speakers for proper connections.
2. Reduce the volume level. IMPORTANT: If the receiver is played back at maximum volume level it may enter the protect mode. Maximum volume listening will cause the receiver to run very hot and may drain the output capacitors.
3. Disable the surround sound option if both the A and B speakers are being used simultaneously.
4. Ensure the top of the receiver has proper ventilation to keep it from overheating.
5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Some receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the owners manual for specific information.
6. Unplug the AC power cord for about 1 to 2 hours to reset the output transformers.
Dec 17, 2010 | Sony Televison & Video
It flashes the word - protector
Hiya,
Disconnect all speakers at the receiver and power it back on. If it stays on, check all speaker wires and speakers for shorts (touching wires). If it cuts out, it needs to be serviced.
Regards
Mike
Mar 24, 2010 | Sony STR-DE625
"Push Power'' and ''Protector"
my sony bravia is KLV-32S400A. i tried to stop the dvd playing and turn off the home theatre, but the tv is still on. suddenly there was a loud blast sound and the home theatre shows PUSH POWER PROTECTOR.
please help what should i do with it?
May 13, 2009 | Sony DAV-HDX500 System
Protector push power - dvd home theater system
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Jan 20, 2009 | Sony STR-DE875 Receiver
Protector flashing
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Oct 05, 2007 | Sony STR-GA7ES
Sony DAV-HDX500 System Logo
51 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
