Question about Refrigerators
Stops cooling, need to unplug, plug back in and it works for a little while
I have a Frigidaire Refrigerator model mrt21braw0. It stopped cooling the other day, the fridge and freezer were about 60 degrees, but is sounded like it was running. I unplugged it. Next day, I plugged it in, and turned it back on. It cooled great, the freezer was about 10F within about 1/2 hour. But when I came back about 3 or 4 hours later, it sounded like it was running, but everything was warming up again. The freezer was no longer frozen... Is this a thermostat problem? I cannot figure out how to get the cover off to test the thermostat, even - I removed 2 screws I can see, but it still does not pop off... Any help would be greatly appreciated!
  • bbiales May 13, 2009
    Ok, so that is actually the temperature control I wanted to test. I'm not certain the best way to access the thermostat for the defroster - do I have to remove the back cover inside the freezer? Or can I get to it through the panel in the back where the power chord and other wires go in?
  • bbiales May 22, 2009
    Ok, I spoke with a repair man the other day. I didn't mention in my post, but this is a 13 yr old machine. And I had heard some odd ticking noises the weeks earlier. When I described all symptoms, that it worked great for an hour or two, but then, even though all sounds like it is working (the compressor is humming, fans are running, air feels cold) but the freezer goes back up to 30-40 degrees, he feels that the compressor is most likely shot, and that my best solution is a new one. I had decided if it was the compressor I would not fix it. So it is going away :-(
    Thanks for your help.
  • 159 Answers
If the motor runs it cant be the thermostat then it is low gas inside the system and it must be cold after 30min
Posted on May 22, 2009
Frigidaire side by side FRS26HF7BW0
You need to have a look at the=> 5303918476 Defrost Control Board Anytime a refrigerator stops cooling and has one of these ADC boards I am suspicious of its failure. Part location 23 HERE I am here should you need me, Thanks John Tripp Appliance 911
Contact Me Here
Mar 12, 2014 | Refrigerators
Frigidaire side by side refrigerator and freezer not working
Hi on most cases if your freezer or fridge stop working correctly at some point by not cooling or freezing right. It my be backed up by ice in your unit. which will prevent your fridge from venting or draining on to the pan. I think the condensor or little look alike radiator will be frozen up. Most cases the drain area will be back up with ice preventing your freezer from working properly. Need to remove items from freezer and try to fix it by adding warm water to the drain area or call a profesional for help
Dec 04, 2013 | Frigidaire Refrigerators
My model 106.53206202 compressor stops working about every six months. The interior light lights so there is power. I unplug the power cord and when I plug the power back in the compressor works fine. ...
I think the defrost timer/control board is hanging up...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 09, 2011 | Kenmore Refrigerators
Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Stopped cooling
Best to unplug the refrigerator now and let compressor cool. The internal overload will be damaged if power remains on and trying to start. We need to test the compressor and start components before you buy anything, Let me know Sea Breeze
Aug 18, 2009 | Frigidaire FRS26R4A Side by Side...
Stops cooling (fridge and freezer) then starts again
if turning the temp control up and then back down turns it back down, you might start with the thermostat. unless you have a local shop you like i recommend. http://www.appliancepartspros.com/partsearch/
Aug 17, 2009 | Frigidaire FRS26R4A Side by Side...
Freezer and refrigerator doesn't cool properly
Sounds like a main control board bad . A model number would help .
Jul 18, 2009 | GE Profile Arctica Stainless Steel Top...
Refrigerator side stops cooling
Drain stopped up.
Take out the bottom drawer in the freezer, look at the back wall and you should get a partial view of the bottom of the cooling coils. Directly below these coils is the drain area. You may need a light to see the drain hole. If this area is covered with ice then a hair dryer will help clear this so you can see the drain hole.
I have some O2 tubing that I put down the drain to clear any cloggs. Also, I seal the top of the drain hole around the O2 tubing with tape and use the air from my lungs to clear the drain tube. Pour a little water down this drain hole to make sure it’s clear.
Dec 17, 2008 | Frigidaire FRS26R4A Side by Side...
Warm Fridge
the defrost timer/ board is getting stuck in defrost and when you unplug it and plug it back in it resets the defrost timer/control board. you may need to replace the defrost timer/control board.
Jun 19, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
LG refrigerator not working
Check and clean the condenser. Unplugging the system allows it to cool off. when you plug it back in it will cool until the heat rebuilds if not rejected through the condenser. Make sure the condenser fan comes on when the compressor runs. A faulty fan motor will cause the same type of problem.
May 19, 2008 | LG LRTBC1825T Top Freezer Refrigerator
Refrigerators Logo
832 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
