Question about Smartlink (I56KSPF00) Modem
Software windows not detecting my modem
    Habit-Forming:
  • 188 Answers
MAY BE MODEM NOT SUPPORTING TO U R OPERATING SYSTEM( WINDOWS) OR U R HARDWARE IS NOT SUPPORTING TO MODEM..
best regards & best of luck..
even u can mail me at my mailing add- sigma_shiva1@yahoo.co.in
Posted on Oct 13, 2007
  • SHIVAJI YADAV
    SHIVAJI YADAV Nov 06, 2007
    hey dude.....u did not make any repley....for u r problem solution ...
    hope it is solved.......
    Was this solution helpful? Show your Appreciation by rating it:
    pls vote for me man..& IF U R PROBLEM IS SOLVED RATE MY SOLUTION AS SOLVED
DFM 562IS (DFM-562IS) Modem: SIR PLEASE SEND ME ITS ALL FEATURES.......
Product ID 3409 Brand D-LINK Vendor Code DFM-562IS Description 56K V.92/V.90 Software-based PCI Modem
The DFM-562IS is a software modem card. It plugs into a PCI expansion bus slot of a desktop PC. It supports voice, fax and data transmission/reception. It's a high-performance CONEXANT-based modem card, and can be used to connect to the Internet, and for fax and voice communication.
Key Features
High speed External Data/Fax/Voice
Plug and Play Installation
ITU-T V.92/V.90/K56flex Auto Detect
Fax Mode up to 14400bps Transmission Rate
Technical Specifications
Data ITU-T V.90/V.92
K56flex
ITU-T V.34, V.32bis, V.32, V.22bis, V.22
Bell 103 & 212A
V.44, V.42bis & MNP 5 (Data compression)
V.42bis & MNP2-4 (Error correction)
V.80 (H.324 video conferencing interface)
FAX V.17 (14400bps FAX)
V.29 (9600bps FAX)
V.27ter (4800bps FAX)
Voice With voice support via sound card application
System Requirements Requires CPU with MMX support
Operating Systems:
Windows 98,
Windows ME,
Windows 2000,
Windows NT 4.0,
Windows XP
Manufacturer D-LINK Warranty 2 Year Manufacturer's return to base Link D-LINK DFM-562IS Internal PCI 56K Voice/ Data Software Modem
May 03, 2010 | Computers & Internet
I can't get windows XP to see/detect my Ademco cia modem. Is there a driver needed
According to my web search you need Ademco Compass Software V 1.5.8.0. Part # CMP1580ADCD
See: http://www.alarmsuperstore.com/ademco/ciamodem/ciamodem.htm
I hope this helps
Apr 24, 2010 | Ademco CIA Modem
Windows XP doesn't detect SBC SpeedStream5100 Ethernet ADSL Modem
in order to the ethernet port to work under the safemode enviroment, you must choose the option for "Safe mode with networking" if you choose "safemode" only the only the drivers the OS needed to boot will be loaded.
Hope it helps!
Feb 19, 2010 | Computers & Internet
Whenever i am connecting the lg lxu-800 usb modem in my computer it is asking for the device driver software.Although i have the cd,still it is not getting detected.
  1. Disconnect modem from computer by taking out the usb lead from computer
  2. insert modem cd in cd/dvd drive and run install
  3. Install the driver from the cd
  4. follow directions onscreen the restart computer if necessary
  5. plug modem back into usb port
  6. now when windows detects it it will find the correct drivers
Welcome
Jun 22, 2009 | Computers & Internet
Computer modem and dial tone
Hello Mikenrgrsvll
This problem can be due to the software not handling a certain dial tone rather than a specific hardware fault. Around the world there is a variance in the signal quality of the dial tone which causes a report of no dial tone detection. Disable the dial tone detection to prevent the system from trying to detect a dial tone.
Disabling dial tone detection for modems:
Windows XP
  1. Click Start
  2. Select Control Panel
  3. Click Switch to Classic View to change the control panel view
  4. Click Phone and Modem Options
  5. Select the Modem Tab
  6. Select the installed modem (Example: Lucent Technologies Soft Modem AMR)
  7. Click the Properties button
  8. Select the Modem tab in the Properties window
  9. Click Wait for dial tone before dialing to remove the check from the checkbox
  10. Select the Advanced tab
  11. Add X3 to the Extra initialization commands field in the Extra Settings box
  12. Click OK twice
  13. Select Switch to Category View to change back the control panel view
  14. Close Control Panel
if this does not work trying re-installing modem drivers.
hope this helps, have a good day.
May 04, 2009 | Acer Aspire One PC Notebook
Modems not detected with Windows XP install
According to the specs this is the driver (Toshiba Software Modem) you need to install to enable your modem.
Post your results, especially if this doesn't fix your problem.
Apr 01, 2009 | Toshiba Satellite A135-S4527 Notebook
Modem device detection
Could be a daffy modem, did you totally reinstall windows?
Nov 21, 2008 | Dell Inspiron™ E1505 PC Notebook
What modem do you choose in step 2 when setting up winfax pro with your cell phone as a modem
If WinFax is asking you to select a type, its probably because it didn't detect a fax modem.
Make sure your modem works in Windows first If you can dial out of your computer using your cell phone using Windows, and your modem supports fax class 1 / 2 / 2.0 , then it MAY work.
Oct 13, 2008 | Symantec WinFax Pro for PC
Hdd wd raptor 74 gb serial ATA
does the machine recognize the hard drive ????
Windows software doesn't care what hard drive you have, as long as the machine can detect it and mounted.
Sep 06, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Smartlink (I56KSPF00) Modem Logo
90 people viewed this question
Top Smartlink Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Michael Galve
Michael Galve
pankaj rautela
pankaj rautela
Are you a Smartlink Computer and Internet Expert? Answer questions, earn points and help others
