Question about Dual Electronics CECT P168 Cellular Phone
I cant receive pictures on my i9
When friends try to send me pictures my phone it asks if I want to download them and when I click yes a message appears saying something like "gprs not subscribed." how do i subscribe it? does anyone know what to do?
  • 1 more comment
  • vaultdiva
    vaultdiva May 13, 2009
    dunderground i have t-mobile
  • Anonymous May 23, 2009
    i did all this n it stilll says gprs not subscribed now what
  • vaultdiva
    vaultdiva Jun 22, 2009
    thanks
  • 193 Answers
You didnt tell me what cellular provider you are using. i am going to post the link for att look at my other posts i have answered this for t mobile as well. here is the link.
http://www.fixya.com/support/t2194697-phone_download_pictures
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact prestorose@aol.com Pay Pal only, will send out First CLASS Mail in padded envelope. If interested I will send Pay-Pal invoice that can be filled out and returned with instructions. Guaranteed safe transaction.
Posted on May 12, 2009
  • dunderground May 13, 2009
    MMS Messaging:
    1.) From the main screen tap the SMS Text icon.
    2.) Tap MMS on the Messages menu.
    3.) Tap MMS settings on the MMS menu.
    4.) Tap Server profile on the MMS settings menu.
    5.) Tap either SIM1 or SIM2 on the MMS settings menu, whichever SIM you are setting up
    at this time for MMS messaging.
    6.) Scroll down the list until you come to Profile 8. You can use any profile if need be, but
    profile 8 is usually the first not already filled.
    7.) Tap on Profile 8. Tap Edit profile.
    8.) Tap just below Rename profile, then tap on the Edit button at the bottom of the screen.
    9.) Clear the current text, then tap in the following text between the quotes
    “T-Mo MMS”
    Tap the Options button at the bottom of the screen.
    Tap the Done button.
    10.) Tap the area below Homepage, then tap on the Edit button at the
    11.) Clear the current text except for &ldquoHTTP://”, then tap in the
    following text between the quotes after the HTTP://
    “216.155.174.84/servlets/mms”
    12.) Tap the area below Data account, then tap Select at the bottom of
    the screen.
    13.) Tap GPRS on the Data account menu.
    14.) Scroll down the list until you come to T-Mo MMS, the data account
    set up under the Data Account Services section. Tap on T-Mo MMS
    to select it.
    15.) Tap the area below Connection type, then tap Select at the bottom of
    the screen.
    16.) Tap on HTTP, then tap on OK at the bottom of the screen.
    17.) Tap the area below Proxy address, use the numeric keyboard at the
    bottom of the screen to tap in the following numbers,
    “216155165050”. The result should look like 216.155.165.050 under
    Proxy address.
    18.) Tap the area below Proxy port, use the numeric
    keyboard again to tap in the following numbers
    “8080” to replace the current 0 value. Then tap OK.
    19.) The areas under both User name & Password should
    remain BLANK. If they are not blank, select each,
    and Edit them by clearing all text.
    20.) Next tap the Done button at the bottom of the screen.
    21.) A Save? question box should pop up. Tap the Yes
    22.) Tap the Activate profile button on the T-Mo MMS menu screen, and you should be
    taken back to the Select profile screen where a big green check mark will be beside the
    newly saved T-Mo MMS profile
    Data Account Services:
    1.) Setting up regular data account services for MMS & T-Zones access.
    2.) From the main screen tap the Service icon.
    3.) Tap Data account on the Services menu.
    4.) Tap GPRS on the Data account menu.
    5.) Choose any of the profiles in the current list and tap the button.
    6.) You are now on the Edit screen.
    7.) Tap the area just below Account name, then tap Edit at the bottom of the screen.
    8.) Tap in the following text between the quotes
    “T-Mo MMS”
    9.) Tap the area just below APN, then tap the Edit button
    10.) Tap in the following text between the quotes
    “wap.voicestream.com”
    11.) Both the User name & Password areas should remain
    BLANK. If they are not blank, then tap on each one
    and Clear what is in them so they are both blank.
    12.) The Auth. type should be set to Secure. If it is not, then tap on the area and use the
    arrows to move the selection so it has Secure, then tap Done.
    13.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen.
    14.) Tap Back button on the bottom of the screen. Tap Back button again on the bottom of
    the screen. You should now be on the Services menu.
    15.) Tap WAP on the Services menu.
    16.) Tap Settings on the Internet services menu.
    17.) Tap Edit profile on the Settings menu.
    18.) Tap either SIM1 or SIM2 on the Edit profile menu, which ever SIM you are setting up
    19.) Scroll down the list until you come to Profile 8. You can use any profile if need be, but
    20.) Tap on Profile 8. Tap Edit profile.
    21.) Tap just below Rename profile, then tap on the Edit button at the bottom of the screen.
    22.) Clear the current text, then tap in the following text between the quotes
    “T-Zones”
    23.) Tap the area below Homepage, then tap on the Edit button at the bottom of the screen.
    24.) Clear the current text except for &ldquoHTTP://”, then tap in the following text between the
    “wap.myvoicestream.com”
    25.) Tap the area below Data account, then tap Select at the bottom
    of the screen.
    26.) Tap GPRS on the Data account menu.
    27.) Scroll down the list until you come to T-Mo MMS, the data
    account set up earlier under the Data Account Services
    section. Tap on T-Mo MMS to select it.
    28.) Tap the area below Connection type, then tap Select at the
    29.) Tap on HTTP, then tap on OK at the bottom of the screen.
    30.) Tap the area below Proxy address, use the numeric keyboard at
    the bottom of the screen to tap in the following numbers,
    under Proxy address.
    31.) Tap the area below Proxy port, use the numeric keyboard again
    to tap in the following numbers “8080” to replace the current 0
    value.
    32.) Tap the OK button on the bottom of the screen.
    33.) The areas under both User name & Password should remain
    BLANK. If they are not blank, select each, and Edit them by
    clearing all text.
    34.) Next tap the Done button at the bottom of the screen.
    35.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen.
    36.) Tap the Activate profile button on the T-Zones menu screen, and you should be taken
    back to the Select profile screen where a big green check mark will be beside the newly
    saved T-Zones profile.
    37.) Tap the On/Off button once to exit to the main screen.
    38.) If you ONLY want MMS and T-Zones access without the full internet connection,
    you can now skip down to the MMS Messaging section and continue setting up MMS
    messaging; otherwise continue below at step 39 to set up a second data account service
    which will be used for your internet connection.
    39.) Setting up a 2nd data account service for full internet access.
    40.) Tap the Service icon on the main menu.
    41.) Tap Data account on the Services menu.
    42.) Tap GPRS on the Data account menu.
    43.) Choose any of the profiles, other than T-Mo MMS, in the current list and tap the
    button. The profile right under it would be fine.
    44.) You are now on the Edit screen.
    45.) Tap the area just below Account name, then tap Edit at the
    46.) Tap in the following text between the quotes
    “T-Mo Internet”
    47.) Tap the area just below APN, then tap the Edit button at the
    48.) Tap in the following text between the quotes
    “epc.tmobile.com”
    49.) Both the User name & Password areas should remain
    BLANK. If they are not blank, then tap on each one and Clear
    50.) The Auth. type should be set to Secure. If it is not, then tap on the area and use the
    51.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen.
    52.) Now that you have set up a second account service for internet use we can adjust the
    WAP settings for T-Zone to use this faster and less restricted internet gateway.
    53.) Tap the On/Off button once to return to the main menu.
    54.) Tap the Service icon on the main menu.
    55.) Tap WAP on the Services menu.
    56.) Tap Settings on the Internet services menu.
    57.) Tap Edit profile on the Settings menu.
    58.) Tap either SIM1 or SIM2 on the Edit profile menu, whichever SIM you are setting up
    at this time for SMS messaging.
    59.) Tap T-Zones on the Select profile menu.
    60.) Tap Edit profile on the T-Zones menu.
    61.) Tap the area below Data account on the Edit profile menu,
    then tap the Select button at the bottom of the screen.
    62.) Tap GPRS on the Data account menu.
    63.) Find and tap on T-Mo Internet on the Data account menu.
    64.) Tap the Done button on the bottom of the Edit profile menu.
    65.) A Save? question box should pop up. Tap the Yes button at
    66.) Tap the Activate profile button on the T-Zones menu screen, and you should be taken
    67.) Tap the On/Off button once to exit to the main screen
Cannot receive or send picture messages.
FAQ - I cannot send or receive multimedia messages (MMS ...
www.microsoft.com/en.../faq/?...singleTopic&topi...
Microsoft CorporationI cannot send or receive multimedia messages (MMS) on my Lumia phone. Restart your phone with SIM card inserted, and retry sending a multimedia message ...
messaging - MMS sending and receiving pictures no longer ...
windowsphone.stackexchange.com/.../mms-sending-and-receiving-pictur...
Feb 4, 2014 - MMS sending and receiving pictures no longer working on Nokia Lumia. up vote 2 down vote favorite. In early 2014 I installed "Update 3" (8.0.10517.150) and the "Lumia Black" software ... "Can't send message Try again".
Can't send or recieve picture messages - Windows Central Forums
forums.windowscentral.com/nokia-lumia.../299901-cant-send-recieve-pi...
Jul 30, 2014 - 7 posts - ‎5 authors
I have had several friends try to send me a picture message, and i myself have tried tosend a picture message, and i'm just not able to receive ... Not sending Picture messages
Jul 22, 2013
Not able to receive MMS on Nokia Lumia 920 on AT&T
Jul 1, 2013
Can't receive or send MMS
Jun 7, 2013
Cannot Send or Receive MMS (T-Mobile)
Apr 21, 2013
More results from forums.windowscentral.com
Nokia Lumia 930 - Troubleshooting - You can't receive ...
Jan 12, 2016 | Nokia Lumia 930 Smartphone RM-1045
I cant send or receive picture messages anymore my phone shows its sending then they never get sent it has unable to send
DEAR FRIEND, THE REASON WHY YOU CANT SEND AND RECEIVE PICTURE MESSAGES IS BECAUSE YOUR PHONE HAS NOT BEEN ACTIVATED WITH THE GPRS SETTINGS. SO KINDLY CONTACT YOUR SERVICE PROVIDER FOR BETTER ASSISTANCE.
Feb 22, 2011 | Nokia C3 Cell Phone
The problem that i am having is I have an I9 eyephoen I got from China and my carrier is t mobile everything works fine i can make and receive calls and get sms messages but not my mms messages which are...
You must make sure if this is supported by the phone- the MMS- and if the frequency is correct to the network youa re in.
Please consult once again with your network T mobile to confirm if this model works.
Sep 24, 2010 | Cell Phones
I can't send/receive picture messages on my LG VX9400
Friend,go to your network provider then ask them to let your GPRS be open so that you can receive picture messages.
Apr 26, 2009 | LG VX9400 Cellular Phone
Cant receive pictures or send
No, but you will need a working GPRS connection to receive MMS messages. This is the same like you need for internet services. Check if GPRS is available. If you need settings for it, find them here.
Feb 13, 2009 | Dual Electronics CECT P168 Cellular Phone
Cannot send pics as message
usually to receive picture messages..you have to send one picture message...
if you cant send mms...check with your service provider if you have free mms included in your contract..if you have then they should be able to give you a solution as to how to activate it...but usually one should be able to send mms
Nov 29, 2008 | Sony Ericsson W350i Cell Phone
Cant resieve picture messages
Review your message service and MMS settings.
The best thing to do is calling your phone operator (Vodafone, Orange , telecom, 3, etc.) and following step by step instructions from the online operator, so to ensure that you enter the right settings.
Sep 10, 2008 | Cell Phones
I cant send or receive picture and video messages!!!!!!!!
cantact your network provider and ask for a sim update and a gprs install message this will solve the problem
Jul 19, 2008 | LG enV VX9900 Cellular Phone
My Phone Can Take Pictures And Make Videos But It Won't Send Or Receive Them
Sounds like you will need to contact your Service provider to add the Pic message feature to your account.
May 24, 2008 | Cell Phones
Dual Electronics CECT P168 Cellular Phone Logo
629 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
