Question about NorStar M7324 Telephone
Each time my coworker tries to press any button it calls another extension in the office.
  • awilliams432 May 11, 2009
    Well, for now I just replaced the phone and it is working fine. I believe that it was the phone and it is in need of some cleaning so I might just be stuck. Thanks for your help.
  • 192 Answers
Sounds like a stuck button...
Look for the individual that the telephone set keeps calling and see if the button is depressed a little.
You can unplug the phone, and do what I call the rake, rake over the buttons, looking for any buttons that are pinched on the corners.
You may have to take to button off that is causing the issue, and clean it if it is sticking if the rake does not fix it.
Posted on May 11, 2009
How do I see what extension is mine?
press intercom and call any coworker and ask them "what ext am I?" I'm not sure if that model will display the ext.#
Jan 26, 2015 | Panasonic KX-T7731 Corded Phone
How do we unrestrict long distant calls nortel t7316e
i got this from Nortel expert and it works:
- press feature **266344
- user ID: 738662 Press ok
- Password: 266344 Press ok
Terminal & Extensions will appear
- press Call Timer button 1 time
write your extension or the extension you need to configure
or press find till you find the extension you need
- press Ring Again button 4 times
Restrictions will appear on the screen
Restrn Filter will appear
- press Ring Again button 1 times
Filters will appear
Normal 02 will appear ( it can be any 2 numbers)
- press CHANGE which appears on the screen
Type 00
and then press the end call button
Jan 12, 2012 | Nortel T7316E 2-Line Corded Phone
My message button is flashing on my Toshiba DKT2020SD phone, telling me i have a message. When i press the Msg button, it it calls another phone extention in another office and i hear that it is on speaker...
This is what I wrote up for our inhouse manual on telephone administration for this phone:
Problem: An employee pushes the Message button to receive a message but it calls someone else's desk. This is caused by whichever extension the phone forwards to when pushing the Message light. For example: if the person at 333 pushes their blinking message light and it forwards to 316 that means that the person at 316 most likely tried to call 333, got a busy signal and accidentally pushed the Message button before hanging up thus setting 333 to call forward to their extension when they got off the phone.
All phones on our system should have this feature turned off, but if it happens this is the two step process to resolve the issue:
Solution: First, push the Message button to figure out which extension it is forwarding to. Take note of the extension and hang up. With the hand set NOT picked up, dial #409 and Release. You may have to do this multiple times to clear the call forwarding because it needs to be done for each incidence that the person accidentally set up call forward. Finally, in the management software go to Station > Station Assignments. Select the extension # that the Message button was forwarding to (the one you noted above). Under the Basic tab at #41 Active Message Waiting select Disable. Select Submit.
Aug 29, 2011 | Toshiba DKT2010SD Phone
How can we transfer phone in internal office call
You could press the HOLD button and tell the other person to pick up...making sure that you only press it once. You could press the TRANSFER key and dial the 3 digit extension of the other phone, or you could program a DSS button (PROG button 1+ext STORE) on a left side button (the ones with lights) and just press that button without pressing HOLD.
Three choices. Pick one.
Carl
Apr 21, 2010 | Panasonic KX-T7730 Corded Phone
How do I transfer calls to someone else in the office using Norstar T7316 phone?
If your telephone doesn't have a transfer button programmed press feature *3, the button you want the transfer button to be, and enter feature 70. While on the call press the transfer button (or press feature 70) and the extension you want to transfer to.If you want a screened transfer, wait til the extension called answers,and ask if they wish to talk to the caller on the line. if they dont, pick up the caller off hold. if they want to talk to them hang up and they'll recieve the call. If you want to blind transfer, hang up after youpress transfer and dial the extension and they'll get the call without screening.
Sep 28, 2009 | NorStar T7316E Corded Phone
Extension call
You need to page an extension.
To program this on a button:
press feature 00
press the intercom you want to change (EX: ext 10)
press the right intercom and *10
press feature 00
To use, just press the button you just programmed. It will grab intercom and dial *10. Conversly, you can press intercom *10 to do the same.
Aug 05, 2009 | Avaya Corded Phone avaparp18d
Nortel T7316e need to change extention # on phone
You can go to any T7316e phone and do this , press feature 983 when you see log on the screen enter 102 0000 to log on with or 12 0000 this is the default admin password for the voice mail system . it depends if you have a 3digit extension of 2 digit . when you get in you will see three options on the screen above the three buttons , from left to right it will be mbox aa and other press the mbox button then it will give you three more options again from left to right they will be add delete and change press change , it will ask for the extension number , enter the number of your extension . the thing it will ask you is if you want to reset the password , press yes and the press the the red rels button your password is now reset to 0000 . good luck .
Jun 19, 2009 | NorStar T7316E Corded Phone
Incoming calls ring on intercom rather than appropriate line.
Somehow you might have taken the lines off the extension. I would double check that under line appearance, that extension is set to "appear and ring" for each line.
Dec 08, 2008 | NorStar M7310 Corded Phone
How to establish extensions?
The extensions start at 10 , and if you press the speaker button and hold it for a second or two it will show the extension number in the LCD display . If you do not have any phones with a display you have to find it by pressing the intercom button and try dialing the extensions one by one .
Jun 19, 2008 | Comdial Impact 8012S Corded Phone
My internal Extension
try
feature
the *0
then if you press the last button on the right coloum (line 10)
mine shows up when i try this
hope it helps
May 02, 2008 | NorStar M7310 Corded Phone
NorStar M7324 Telephone Logo
63 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Jose Ma DM.
Jose Ma DM.
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
