Question about Poulan Pro Chain Saw 46cc 20"
Throttle adjustment for john deere chain saw
I have an old john deere chain saw.It was running fine a few days ago and i can not get it to start now.I am thinking it might be a fuel problem.I took the carb apart and cleaned it up.It has 2 adjustment screwsI am thinking they have to be backed off 1 and a half turns.Can someone tell me if that is correct.I did all this but I have not tried it yet, because I want to get some fresh fuel.If anyone has any tips for me I sure would appreciate it.
    President:
  • 2,559 Answers
The H is for high rpm (Main mixture) and the L is for Low rpm (Idle Mixture). First turn in both screws all the way in and then turn them both out 1 and a half turns. Pump the primer bulb if the equipment has one. Start the engine, once it is idling, turn the L (Idle Mixture) screw out (counterclockwise) from the preliminary setting until the engine speed decreases (rich). Note the position of the needle. Now turn the adjusting needle in (clockwise). The engine speed may increase, then it will decrease as the needle is turned in (lean). Note the position of the needle. Set the adjusting needle midway between the rich and lean settings as in the picture below. Don't touch the throttle during this procedure. Once you have found the best idle speed for the engine then you need to adjust the high rpm. This process is the same as with the idle rpm process but you need the to hold the throttle wide open while you are adjusting the H (Main Mixture) needle on the carburetor.
Please rate this a fixya
Posted on May 11, 2009
How do i adjust oiler on a john deere CS46 chain saw?
From the image in the parts list the adjustment screw appear to be on the bottom side of the case under clutch area.
Feb 11, 2015 | John Deere Garden
Tried charging john deere battery no good after 4hrs.whats up
Walt
Does this mower have a Briggs and Stratton engine with overhead valves? If so, (and this will sound really weird) you need to adjust the valves. After a few hours of running, the intake valve will go out of adjustment so the decompressor won't work. It acts like the battery is dead when this occurs.
Mar 24, 2014 | Garden
Saw wont idle, runs wide open
Some saws have a throttle lock that locks the trigger to aid starting. Get a look at the carb to see if it opens when the trigger is pressed and closes when the trigger is released. If it stays open the lock may not be releasing or the throttle linkage is bound up or disconnected from the carb.
Dec 13, 2013 | John Deere 28 30 40v 50v 55v 60v 70v 80ev...
1970 John Deere 4020 Diesel, Engine speeds up by its self, I goose the throttle and then it will idle down. pretty sure it is a govenor problem. How do I fix this?
spring is broken/stretched out on govenor linkage bar that runs from air damper flag to injector pump and i would expect a 1970 to be needing a new spring about 5 years ago
Dec 12, 2013 | John Deere Steel Chain/farm/tractor/john...
I have less then 1 hour on my cs52 john deere and each time it runs for a short time, shut it off and well not restart untill I pull like crazy. I ran a bit the other day and now I can't start
I have the same model..had to replace the housing due to the bolt breaking loose that holds the bar and cracking the bar oil tank wall. Been apart for a few years. Once back together. It fired first time and ran great...the second day of heavy use I had this same problem. Turned out it was the on/off switch. It was not fully engaging when in the on position and I had to flip it a few times. once started it would idle ok..then just stop.. I replaced the switch and the problems went away. and it I may add. I replaced the original bar and chain with an arbor pro from Baileys. The bar and chain are slightly thinner then the original and man did that make a difference on cutting speed!!
Aug 28, 2012 | John Deere Garden
What part number oregon chain do i need for a cs-52 john deere saw. They keep sending me the wrong john deere chain witch is three links short. thanks Vern.
Hello Sam;
I cannot find anything by Deere (probably an efco 152) about your saw. Oregon does list some particulars here:
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
I input:
John Deere; CS52; *see below; All (0.325"); All (0.050"); All (yours is likely green - low kickback).
*16" - 66 drive links (the part that fits in the bar).
*18" - 72 drive links.
If your saw does not use either 66 or 72 drive links I suspect the bar, drive sprocket, or drive sprocket and bar nose in use are not what the the saw was originally supplied with. Any local chainsaw seller/mechanic given your chain as a pattern can fabricate one in about 5 minutes. Often a local chain is less expensive (no shipping).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
efcoPower.com
http://www.efcopower.com/indexPri.jsp
Sep 07, 2010 | John Deere 16" Chain Saw Chain (Oregon ...
John deere chain saw CS 56 idle adjustment
check the choke lever rod possable loose or off
Feb 11, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chain Saw 46cc 20" Logo
1,239 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
