Question about MSI nVidia GeForce 7600GS 256MB Dual DVI Fansink P Graphic Card
GeForce 7600GS AGP 512MB card compatibility
I currently have a Geoforce 5700FX LE 256MB gfx card running on my motherboard and I think I will be needing to update it soon. My question is will the Asus P4SDR-VM motherboard support either a GeForce 7600GS AGP 512MB card? (8x/4x backwards compatible)
I have been informed that it might run on my motherboard and then again they may not run at all. Is there anyway to test it, before purchasing either?
  • 3 more comments
  • Simon
    Simon Oct 13, 2007
    I do not know which brand of GeForce 7600GS it is that I can get from a computer store.
  • Simon
    Simon Oct 13, 2007
    2 technicians from 2 different computer stores told me that they may and may not work. I suppose I could buy it since it won't be much and if it doesn't work hold onto it and put it in a custom built system down the track
  • Simon
    Simon Oct 13, 2007
    That could work, but then I would be still in the same predicament as I am in now. It is fine doing everything that I normally, with the exception of running Guild Wars. Installed Guild Wars Nightfall on the 12th October and that is where the gfx go all weird.
    My brother suggested that it may be trying to work harder and faster than it can or take the card out and put it back in to see if there is a difference. This has only ocurred since I got the inside of the tower cleaned and have tried to run Guild Wars since it being cleaned.
  • Simon
    Simon Oct 13, 2007
    Thanks for the help bluegreenash, which would you recommend in purchasing? I really have no preference whether I get a nVidia or a ATI card. I think Guild Wars runs better on nVidia cards
  • Simon
    Simon Oct 20, 2007
    ok thanks for the help, problem is now solved. Just need to get a 500w PSU for the card I am going to get.
  • 661 Answers
It's hard to know,  it may be best to take your pc into a computer store and get them to test the compatability before you take it out of the store,  that way you can be sure that it works
Posted on Oct 13, 2007
  • Gareth Cockram
    Gareth Cockram Oct 13, 2007
    well if you buy it from a store and it doesn't work you can take it back as incompatible.
  • Gareth Cockram
    Gareth Cockram Oct 19, 2007
    I prefer Nvidia myself......although with both manufacturers they pretty much only make the chip used, so it may be best to check the reviews to find a good buy
SOURCE:
Vga card
Look for a AGP x8 graphics card with 512mb memory. Or more.
Jun 18, 2013 | ASUS P4VP-MX Motherboard
Can you suggest an agp 8x video card compatible with a7v880 mobo? thanks! my nvidia fx5200 got busted...
Hello.
Since you have a ASUS A7V880 Motherboard, this means you have a VIA chipset, which does not like ATi Video Cards.
You can only go with Nvidia AGP Video Cards.
Current "Available" Models are
Nvidia GeForce FX 5200 , 5500
Nvidia GeForce 6200, 6600 GS
Nvidia GeForce 7300 GS, 7600GS
The Best Graphic Card available from the Nvidia GeForce series is the 7600GS
http://www.newegg.com/Product/Product.aspx?Item=N82E16814143069
If you just want another card to replace your old video card, please visit:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010380048+1069609639+106790727+1067909563&QksAutoSuggestion=&ShowDeactivatedMark=False&Configurator=&Subcategory=48&description=&Ntk=&CFG=&SpeTabStoreType=&srchInDesc=
Hope that Helps.
Jan 25, 2010 | ASUS A7V880 Motherboard
What AGP is compatible with my ECS KT400 motherboard and AMD Athlon 1900+ processor? I currently have NVIDIA Geforce2 MX 400 64MB and I want to upgrade it to 128MB or 256MB.
Any AGP card is supposed to work. Doesn't matter what spec. Don't expect huge performance increases by just upgrading gfx card. Games might run better visually.
Cheers.
Please rate.
Sep 28, 2009 | Computers & Internet
I have a Geforce Fx 5200 graphics card would like to up grade
the motherboard supports only APG graphic crads, as long as you can get AGP your are fine. there are several brands in the market. so i suggest you have a look at the link below.
1. http://www.ngohq.com/home.php?page=Articles&go=read&arc_id=116
Feb 25, 2009 | XFX GeForce FX 5200, Graphic Card
Video card
Hi ,
Appreciate the direct "Ask me" again.
On your last post, you specified your PC to have AMD Sempron 2400+ 512 Mb DDR2. (). Offhand, I would go for the Nvidia for performance but for durability, the Radeon would be better. Depends on how you want the video card used. Perhaps you may want to consider first is compatibility that is if your motherboard will accept a PCI-E video card. There are some versions that only have provision for an AGP video card.
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
It would be appreciated if you could rate all the solutions that has been provided to you as you see it fit here, here and this one.
Good luck and kind regards. Thank you for using FixYa.
Sep 13, 2008 | MSI nVidia GeForce 7600GS 256MB Dual DVI...
Another question
Hello again,
nowadays asus and Geforce are the markets leader ... I would suggest to go any of these by dependin on the features...
1. Memory
2.Additional features
3.Cost (Expense)
If u Find asus cost a little lower than Geforce then go for it, As it has additional feautures.
Kindly give a feed back to Improve my statistics and to see If it was helpful for you...
Thanks and Regards
Mar 28, 2008 | Computers & Internet
ATI RADEON X1650 Pro, AGP Graphic Card 512MB compatibility
Maybe this post is a bit old, but on last deceber I bought an AGP 512MB ATI Radeon X1650 PRO for my Foxconn motherboard and I must say that it's simply awesome!
I can play most games on mid-high settings on reasonable resolutions (most on 1024x768) with good FPS (except with Crysis... but let's face it, did Crytek bought a time machine to warp a 2010 game??).
So, if you already have it, then congratulations, and if you still are thinking on buying it, then what are you waiting for!?
Also, it's AGP x8, if your motherboard support x8, then it should run perfectly fine.
Also, I have a bit of problems trying to run Prey on the X1650...
It always appears an error... it's not of much importance, as I have much better games, but I haven't tried it with high fancy graphics... :P
Oct 13, 2007 | ATI RADEON X1650 Graphic Card
To upgrade hardware nvidiageforce7100 to 8600 or to any nividia 8series
i assume you have a pci-e slot on the computer. get atlest the geforce 8600 with 256. would cost you around 6000 bucks.
Oct 10, 2007 | Computers & Internet
MSI nVidia GeForce 7600GS 256MB Dual DVI Fansink P Graphic Card Logo
212 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
