Question about Refrigerators
Refrogerator not cold
Ice buildup on back of bottom freezer and refrigertor part is not cold at all
  • 1,543 Answers
You do not list a model number, so this will have to be very generic. You have a defrost problem. The most common reason is a bad defrost heater, but a bad defrost terminating thermostat or a bad defrost timer / control board, or an air leak, such as a bad door gasket or a door which did not close can also cause the frost build up. Remove the cover at the back of the freezer compartment and defrost with a hair dryer. Determine cause and correct to prevent a re-occurrence in under 2 weeks.
Posted on May 11, 2009
Why is Refrigerator warm, Freezer is cold
This seems to be a common problem with bottom freezers.
Usually there is ice buildup in the cold air passage from the freezer to the refrigerator. There are videos on Youtube that will help.
Link below.
bottom freezer refrigerator not cooling YouTube
Jul 31, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Can feel cold air coming out of bottom of freezer but it is not cold inside
Do you see ice buildup on the back of the freezer wall about half way down?
Dec 28, 2013 | Whirlpool GS6NBEXR Side by Side...
Not getting cold
Do you see any ice buildup on the back wall of the freezer or behind it?
Is the compressor running?
Dec 10, 2012 | LG LFC23760SW Side by Side Bottom Freezer...
I( find a puddle of water on floor at front left hand corner on freezer side..I took the freezer drawer out and found ice build up under it ,could this cause my problem.. this happened about every 24 hours...
The problem with your refrigertor is that the defrost drain is plugged up. After you get the ice buildup out of the freezer section you will have to locate the drain system. It is in the back of the freezer at the very bottom.It needs to be cleaned out. Hope this at least leads you in the right direction.
May 27, 2011 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator is not getting cold
Unplug it and let the freezer thaw for a day - there is likely ice buildup between the freezer and refrigertor side - which is not letting cold air get to the refrigerator side. Remove all food from the freezer and the refrigerator, and let the freezer totally defrost (allow 24 hours with the doors open) then plug it in and you should see a noticable difference. If that does not work, the fan could be bad. There are two fans, one in the back of the fridge down low on the outside, and one in the freezer behind a back panel on the inside down about half way. Try the defrosting first which should be the solution, and the easiest fix.
Aug 15, 2009 | Kenmore 53642 / 53644 Side by Side...
Top Freezer works fine but there is no ice building up in freezer the bottom fridge not cooling properlyThings are not as cold as they should be
Remove the back panel from the freezer to verify no ice behind the freezer panel. Look inside the air vent on the freezer panel for ice buildup. Make sure the freezer control is set to minimum not coldest freezer.. Make sure the freezer fan motor is working.
May 28, 2009 | Electrolux Refrigerators
Refrigerator part not cold,ice on back of freezer
low gas level in the system needs a bit of top up of 134 a gas
May 11, 2009 | Refrigerators
Refrigerators Logo
81 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
