1999 Volkswagen Passat Logo
Anonymous Posted on May 11, 2009
Front door locks on a 99 passat
Iv just bought a 99 tdi passat.the interior lights dont work,fuel cap doesnt work,mirrors dont work,i cant lock the doors with the key but if i use the fob both the back doors lock and so does the boot.any ideas?
  • 2 more comments
  • Anonymous May 14, 2009
    the fob i use is for the alarm.the key doesnt even go in the passenger door.it does go in the ignition tho.isee theres a little light on the key but it doesnt light up when you press it and it does othing when i press it.you think the batteries dead and if so how do you change it.thanks for your time by the way.ps do you know how to turn of the airbag one one of these?
    the key does nothing.but theres another fob thing for the alarm that locks everything except the 2 front doors.i want the airbags of so i can have my wee boy up front with me.the key doesnt even turn in the drivers door im hoping if i change the battery i can just use the remote.
    aha.iv just been told its an aftermarket alarm.and this could be causing problems.
  • Anonymous Mar 27, 2014
    petrol flap interior lights & windows not working
James Williams
Level 2:
Scholar:
  • Expert 115 Answers
  • Posted on May 14, 2009
James Williams
Expert
Level 2:
Scholar:
Answers
115
Questions
Helped
84655
Points
250
You have the wrong KEY if it won't turn any locks.
You can use the KEY fob from another Passat.
The one you have was most likey not the original
and the car was reprogrammed to except that FOB.
The Fuse panel Is inside the DRIVES side.
Open the Driver door. Look at the side of the DAShboard.
THat Giant "B" Shapped plastic cover pops off.
Check the fuses...IF any are broken,black or no good.
REplace them
Hope this helps
Sketchlab.com
MugShot Collection.
  • James Williams
    James Williams May 14, 2009
    Well, I assumed incorrectly....
    Yes the RED light should light up when pressed.
    You will have to use a tiny screw driver or thin dull butter knife,
    On the opposite side of the buttons. About 3/4 up on the FOB.
    Their is a thin ****. That slides back. And you should be able to get
    to the battery. I don't know the size as my key is lost at the moment.
    But I am confused as to how you use the FOB for the alarm.
    If the batt is dead.
    You can dis-sable the Airbags by removing the Fuse.
    Located on the side of the dashboard.
    Open the Driver door and look on the side of the dash.
    Remove the Giant "B" looking piece of plastic.
    Their should be a white card showing the locations for the
    fuses. One will have the airbag symbol.
    Remove it. Not sure why you want to remove the Airbags.
    Please only leave the fuse out while working the car
    and replace it for safety reasons.
    Hope this helps..
    Sketchlab.com
    Mug Shot Collection
My interior lights wont work in my vw passat 2.0 tdi sport 2007
  • There is a fuse box on the drivers side either under the dash or on the aids of the dash. One of them fuses could be blown.
  • The other thing that could be going wrong is the harness on the driver side door. If you open the drivers door you will see a harness stretching from the frame to the door. You can get into that harness and look for broke, bulged or rusted wires and splice in new ones. This is common with aged vehicles because of the amount that door is used.
Interior lights stay and alarm goes off every time i lock it
Your car thinks a door is open , thus the light stays on. When you lock the doors with the remote it activates the alarm system. 10 sec later it senses that the a door is open and alarm sounds.
I have a 99 passat as well and I just went outside to see where the switch on the door is. Can't see one anywhere , it must be inside the door (part of the latch mechanism). I tried to arm the alarm system by locking the doors with the remote while the door was still open , sure enough the alarm went off about 15 secs later.
1helpful
VW Passat 1.6l 2000 (UK) Electrical failure
fuses are usually in the glove box or under the drivers dash or under the drivers side hood either physically inspect every fuse by pulling them one by one or the aid of a test light and a good ground to the test light
3helpful
2answers
VW Passat 1.6l 2000 (UK) Sudden failure of
check under seat, there are 3 sets of wires, they could be coroded, these wires run all the windows door, any thing that is for useing the power, i know just had it fixed 245, 00 later,,
4answers
Engine won't crank, module problem?
It seem like a bad ignition switch the way you describe it, does the dashboard lights up when you turn the ignition switch on?
Electrics on my VW Passat TDI 2001
check all the fuses on the fuse panel (located on the end of the dashboard). Behind the plastic door, drivers side. Then see if all the windows will go up and down; locking and unlocking the door with the key in the door lock. You have to hold the key in the unlock position to make this option work.
1helpful
2answers
Central locking on 1998 passat 1.9 tdi not fully working
the flasher dont working whene i give right or lift flash but if i open 4 flash togather its working can u helpe me ples to find the problem .
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
