Question about E-Machines eMachines W2686 PC Desktop
Emachine 2685 no power up
The three wires from the start power on switch are not connected to the mother board and I do not have a manual that tells me where to connect these wire to the mother board
  • AnOldGuy Nov 11, 2007
    I accidently pulled the front panel wire loose and i am lost without the manual, this is my daughters computer please help.
  • 661 Answers
From the spec of the motherboard it should be one of the pin headers near the Bios battery (looks like a coin on the mobo)
hopefully (if you look close enough) it should be marked pwr
Posted on Oct 13, 2007
I have emachine t seris t2862 desktop and I donnot know how to connect power swich in mother board please help me
On the motherboard there will be a small set of connectors marked FPANEL, next to each of these will be a set of letters (usually PW, RES, HDD, MSG) and an earth pin, From the power switch you will see a two wire set normally black and white ending in a connector, this connects to the PW pins on the FPANEL
Jan 06, 2011 | E-Machines eMachines Refurbished EMA...
Emachine d2880 power on switch is bad. How do I work around? Is there a way to short the pins on mother board to turn on my PC? In words do you have connection details for power on switch wires to mother...
In your computer you have a power switch located on the PC chassis, you will find two wires coming off of it. At the end these two wires you should find a black 2 pin push plug. This should be connected to your mainboard. On your mainboard, the header for LEDs, hdd, power etc, you should see two pins labled power. Switch push plug goes over these two pins or these two pins labeled power can be shorted with a screwdriver, however this can be risky as it is very easy to touch other pins in the process and kill the mainboard. Rather use a push plug!
You can also read my guide as your computer my not be POSTing, my published guide is entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
All the best!
damnor01
Nov 22, 2010 | E-Machines eMachines Desktop PC
Power Button wire to mother board power led power sw HDD Led . what pin connects to the three wires from power button. Led Power wire to what pins, HDD Led to what pins and power SW to what pins on the...
There are may motherboards, but most have writing on them as to what is suppose to plug where. For example, for the power switch, the lettering might be "Pwr" or "Power" or "Pwr sw". The pins are usually together and should fit the plug on the end of the wire.
Nov 25, 2009 | E-Machines eMachines Desktop PC
Need picture of mother board for Emachine C2825
I've built a PC myself, each connector had text on it to say what it was and one arrow on it in relief, don't know wether that indicated plus or minus anymore.
Anyway, I recommend you just plug them in, and try to boot the PC. If it doesn't boot, switch the Power SW connector around, then it should boot. Do the same with the LED connectors, and it should work just fine!
Good luck,
Yannick.
Jul 13, 2009 | Intel D845GVSR Motherboard
T6410 EMACHINE TRYING TO CONNECT START BUTTON
The motherboard in your computer is an MSI MS-7145, which is also called RS480M. You can download a copy of the manual here. The front panel connections are on page 2-20.
Looking at the header JFP1, pins 1 through 9 (odd numbers) are the front row, pins 2 through 10 are the back. Pin 10 is the missing pin. The power switch connects to pins 6 and 8. The power LED connects to pins 2 and 4. The HDD LED connects to pins 1 and 3. The reset button, if used, connects to pins 5 and 7.
May 13, 2009 | E-Machines eMachines Desktop PC
NO POWER TO THE MOTHER BOARD OF MY EMACHINE
The Wires goes on the motherboard, check your motherboard manual for reference
Mar 17, 2009 | E-Machines eMachines T3830 PC Desktop
Emachines computer not turning on
IS ALL CONNECTION CORRECT, TYPE IN
EMACHINE COMPUTER DOWNLOAD DRIVES
ENTER
SEE IF ANY OF THIS INFO CAN HELP YOU
THE MAIN SWITCH FROM THE PANEL ON THE FRONT OF YOUR COMPUTER DIDNT MATCH YOUR NEW MOTHERBOARD CONFIGURATION
START BY REMOVING ALL WIRES AND CONNECTORS EXCEPT POWER ONE, SEE IF SYSTEMS TURNS ON, THE POWER SWITCH MAYBE THE PROBLEM, RESET SWITCH, ANY EXTRA CARD YOU PLUG INTO YOU MOTHER BOARD
*********REMOVE ANYADD ON CARD ANY ADAPTER DEVICE ALSO,
ADD ONE WIRE AT A TIME UNTIL ALL WIRES ARE CONNECTED
CANDYMANCANDY
Jan 27, 2009 | E-Machines (308714) Motherboard
Emachine W3400/ front panel connections
they have to be plugged in horizontally although it is possible to plug them in vertically because the pins are evenly spaced either way. they are color coded just not like you would expect for example one plug has a green wire and a white wire the green side goes to the green pin and the white side goes to a green pin with a white cross you have to look close because there are several green pins which is what threw me off do this with all three plugs
Apr 19, 2008 | AMD eMachines Desktop System w/ 17'' CRT...
Emachines problem... PSU works but comp doesnt turn on
Hi, Did you just add the second CD? If you did you may need the driver for the mother board? Make sure the power cord for the cd has voltage plug it into the DVD drive also check the cable make sure red stripe is on the correct side of drive. You can download the driver at http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T-Series&model=T2672 User guide is there as well. The start button has a pair of wires with a small pin connector on it. This will connect to the motherboard if there is a 3 pin set you might try moving to the other pin. The new power supply also has to provide a start voltage? Your power supply may not be compatible or it may put the voltage on the third pin.
Aug 22, 2007 | E-Machines eMachines Desktop PC
E-Machines eMachines W2686 PC Desktop Logo
134 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
