Question about Maytag Legacy Series Top Load Washer
Goes through cycle, but doesn't drain. Will drain manually
I have a Maytag Legacy Series Model # sav405deww. It will run through the entire cycle and when you open the lid, there is water in the tub. I used another setting, and it worked fine for a few days, but it now has water in the tub. When I set the cycle to spin, it will drain, so it is not clogged. Is this a timer issue?
    President:
  • 1,136 Answers
Hi, Sounds like it could be timer. Does the timer advance to the off position? There could be a partial plug in the hose or pump also. You can add water again and then go to spin cycle. Lift the drain hose out of the drain pipe just enough that you can see the water flow. You should see water draining out with a bit of force and the stream should be the sizt of the drain hose.
I hope this helps you. Please let me know if I can be of more assistance.
Thanks
Vic
Posted on May 11, 2009
I have a Legacy SAV405DEWW machine wont run
I just had the same problem. The washer would stop about 2/3 through the spin cycle and not start again. Replaced the timer. That did NOT solve the problem.
Jul 20, 2009 | Maytag Legacy Series Top Load Washer
Maytag Legacy Series Washer. Lint settles on
Lint is in majority flushed out in drain cycle. make aire the tissue and match books aren't in any pockets. the lint is then deied and separated in the drier , Well so I was told . good luck
Jun 07, 2009 | Maytag Legacy Series Top Load Washer
Maytag legacy series tub wont fill
Your drain hose is too low or there is no air gap where the hose enters the drain line.
This causes the water to siphon out as it fills.
Mar 08, 2009 | Maytag Legacy Series Top Load Washer
Out of balance
Installed no slip carpeting underneath machine, worked fine.
Feb 15, 2009 | Maytag Legacy Series Top Load Washer
Maytag legacy series washer not holding water
Same problem here. But according to Maytag Service, the draining pipe may be too deep inside the draining tube on the wall, thus creating a siphon effect and not allowing the tub to fill.
Their suggestion is to ckeck the pipe and make sure no more than 6-8 inches are inside the draining pipe. This should take care of the suction. We'll see, Imma do that when I get home.
Jan 06, 2009 | Maytag Legacy Series Top Load Washer
The grinding (bearing) noise on "spin", now leaking rusty water under machine... 3 1/2 years old "Legacy" ??? NOT !
maytag has rear rollers and front drum glides when goes out sound like sand paper scratching, also inspect belt idler same noise
Aug 14, 2008 | Maytag Legacy Series Top Load Washer
Washing Machines Logo
398 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
