Question about Indesit WA 125 Front Load Washer
Indesit evolution 1200 we 125
Shows errror code f7 have cleaned filter and switched mains off and on again machine tries to work some times but wont complete cycle
  • 641 Answers
SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
Posted on Aug 16, 2007
  • 64 Answers
SOURCE: Indesit Washing Machine not proceedding with the cycle programme after filling with water.
Cant understand how the machine will revolve on the 'spin cycle' & yet you can hear the motor on the 'wash cycle' but yet it doesnt revolve!!
Nomally if the water fills, & the tub revolves without the programmer advancing, its because the heater is not working. ie faulty thermostat, heat element, or maybe a wire burned off in the 'heater circuit'. Check if you have 240 volts at both ends of the heat element, with a meter or 240 volt bulb
                         !! BE CAREFUL OF 240VOLTS!!
Posted on Oct 31, 2007
  • 76 Answers
SOURCE: I have an indesit evolution
Try and unplug it for 30 min and see what happens then
Posted on Jun 22, 2008
SOURCE: washing machine
did you reset the machine after you checked the filter? if not put the selector switch to any of the stop positions the switch on wait till the on/off light flashes rapidly , then switch off and try again.
Posted on Aug 16, 2008
  • 1462 Answers
SOURCE: Indesit wil 103 filter
stale smell may be due to using liquid detergent - change to powder.
filter may be of two types. if in the front, unscrew cap and just pull. may be difficult is a foreign object like a bra wire is stuck inside.
other type of filter is in the large diameter pipe from bottom of machine to pump. take off small back bottom panel and undo this pipe at the machine end and filter is inside this pipe. pull out and clean
Posted on Sep 04, 2008
  • 3463 Answers
Pressure switch not sensing correctly, this being the case, you will need an engineer.
Posted on Nov 18, 2008
0 characters
1 Points
Indesit pwe 8148 w with error code FO5 Is the problem usually either a blockage or the pressure switch? I am going to try to fix it myself but how do i get to the pressure switch to see if it is stuck on...
F05 means that the pressure switch shows full all the time:
F05 - Pressure switch jammed on full
The fault is usually fixed repairing or replacing the pressure switch. Before replacing the switch check for draining issues that can trigger F05 and clean the hose connected to the PS. The PS is located inside the appliance in the control panel or at the right side of the cabinet. The part is reached removing the screws holding the top and lifting the top. Power must be disconnected before starting.
Here how the switch looks like:
Sep 14, 2011 | Indesit W 123 Front Load Washer
Code F-05 showing on INDESIT WIXE 127 washing machine. Not emptying or spinning.
Error code F05 means that the pressure switch is jammed on full.
Remove lower rear cover of washer.
Locate and remove the large black fastened to bottom of the drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hope this helps you.
Jan 03, 2011 | Washing Machines
Indesit Evolution W16s washing machine H20 error code
if there a advance cycle button push it an see if the timer will advance to spin if not turn the power off to washer an wait a couple mintue an the door will open
Apr 24, 2010 | Washing Machines
Error codes f1 + f7 on washer
Error code F01 indicates a short circuit motor triac.
Chek all connections on and to the motor, motor plug and control module.
Code F07 indicates heater relay stuck.
Check all connections to and from the heater and control module.
Jan 05, 2010 | Washing Machines
Indesit evolution we 123
the error code means that the heater relay is not working.
You will need to call an engineer.
If you call hotpoint, it will cost you over £100-00.
Better to call a independant if you can find a good one.
Nov 19, 2008 | Indesit W 123 Front Load Washer
It's aWIA121 front loader- Indesit
Its just a problem with one of the components on the control board - it wont do any harm to the machine, or affect the wash so I wouldn't worry about it
Oct 01, 2008 | Indesit W 123 Front Load Washer
Washing machine
Aug 16, 2008 | Indesit W 123 Front Load Washer
these machines will do this if the timer dial has been moved during a cycle, they have a memory chip on the main circuit board.
they also do this if the machine has a fault with the exception that they dont stop, the doorlock light flashes and the timer just keeps clicking.
try setting the timer to a dot on the settings then switching the power on, the doorlock light will flash a few times, turn off again select program then switch back on, machine should now be reset and work ok, if not then count the flashes of the doorlock light as this indicates a fault code.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 04, 2008 | Indesit W 123 Front Load Washer
Indesit washing machine, wil103
from the looks of it, this is called an f12 lights 1&2, communication error
which seems to be quite common. I've got the same problem.
If there's nothing in your filter, it could be the pcb (apparently, according to the research I've done so far).
Quite expensive apparently (£200?), but these machines don't seem very reliable, lots of people on the web having problems.
Dec 19, 2007 | Washing Machines
Indesit WA 125 Front Load Washer Logo
290 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
