Question about Konica Minolta Office Equipment & Supplies
Clearing a service code ''C0400'' on a Minolta CS Pro 6001
What is the cause of the service code C0400? The Konica Minolta wants to charge me over $200.00 just to look at it.
  • 469 Answers
C400 is exposure lamp fails to come on, on start up the main exposure lamp should come on and do a scan.
If the lamp is not detected by the sensor, then you get the code.
Restart the machine, watch for the exposure lamp. if it does not come on before the code occurs, then the lamp or thermal fuse is likely gone.
if the lamp comes on then the code, the AE sensor is likely gone.
Hope this is of some help.
Ed
Posted on May 11, 2009
Mesin fotocopy
The C0400 deals with the scanning lamp not turning ON. I would check the fuse for the scanning lamp and check the lamp to see if it is blown. You will most likely need to replace one or both of the parts. Good Luck
Oct 30, 2013 | Minolta EP4000/5000 CS/PRO Copier
Minolta ep4000 error code c0400
C0400 -Exposure lamp failure to turn ON
C0410 -Exposure lamp turning on at abnormal timing
Turn OFF the copier,remove the glass,Work a screwdriver trough the hole in the frame at the left front side of the copier and remove the screw that secures the scanner unit.Move the scanner to rhe right hand side of the copier.Remove 3 screws to free the scanner.(To remove the scanner turn it counterclockwise).Remove 1 screw and the wire guide,remove 1 screw and the ground wire.Unplug the exposure lamp terminal connector,unplug the thermal fuse connector.Remove the scanner from the copier.Verify the continuity of the exposure lamp and thermal fuser.If is defective change.
Jan 02, 2013 | Minolta EP4000/5000 CS/PRO Copier
Error Codes
Well the C0500 code is the code that is given when the fusing unit is bad (THE HOT PART) to reset that code need to go to the rear remove top rear cover and press the small black button on the control board lower left. The C0400 is Exposure Lamp the bright lite under the big glass. Might need to get a new one try web site below as for the C0500 if it comes back do not reset get Konica Minolta rep to look at the fuser unit. IT can catch on fire and that would ruin a perfectly good day. If parts required see the web site below for a start Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Feb 16, 2012 | Minolta EP1083 CS/PRO Copier
Detaile of Code of Minolta Ep 6001 coper
pleas send me cs pro 6001 code 611 salvation
Feb 12, 2011 | Garden
Problem c0400 for Minolta
Exposure lamp to reset open front door to your upper left remove the access cover press the trouble reset, if the code comes back replace the bright light under the big glass
Oct 31, 2010 | Minolta EP4000/5000 CS/PRO Copier
Code C0400 contact rep at certain phone #...# out of service.
c0400 is exhaust fan code. Open the front door to clear. Make also all covers are closed front and both sides.
Jul 02, 2009 | Minolta EP4000/5000 CS/PRO Copier
How to clear M2 on minolta EP 4000/5000 cs/pro copier pls send solution to michofolasenterprises@yahoo.com
clear web or drum count and developer,you will not effect the the machine aporation,by clearing count
Sep 16, 2008 | Minolta EP4000/5000 CS/PRO Copier
746 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
