Question about Whirlpool 3.2 cu. ft. Plus Washer
Whirlpool Washer stalls out on rinse cycle
I have a Whirlpool model LSR844LQ1 Washer. I have replaced the timer, but when it reaches the rinse cycle, the washer will occasionally stall and not drain.
If I mess with the time advance after a short time it will drain and cycle through the reat of the wash cycles.
Some times it does itthree or so times in a row, then it wont do it for several washes.
  • dyoung5229 May 18, 2009
    I got it figured out. It was the 2 speed motor.
    Scholar:
  • 85 Answers
This is likely a lid switch problem. They tend to get weak and work sometimes and sometimes not. When it stalls like that try pushing down on lid and see if it kicks in. If so you need to replace the lid switch
Posted on May 18, 2009
Whirlpool wont spin on rinse cycle
What is the model number??
Jun 28, 2013 | Washing Machines
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Whirlpool washer stops after agitation cycle
Maybe check the belt is it cracked worn or fibers showing if so replace it
Jul 26, 2009 | Whirlpool Washing Machines
Whirlpool ingis washer will not engage rinse cycle
make shure the cold water is on and also if it worked before then it cold be two parts 1 the timer is bad or 2 the water inlet valve
Jan 17, 2009 | Whirlpool Inglis IP4400 Washer
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Whirlpool top Loading washing machine won't spin on spin cycle
    If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
    Sep 21, 2008 | Whirlpool LCE4332P 2.1 cu. ft. Top Loading...
    Ultimate Care II - Rinse Cycle does not start
    sounds like a lid switch problem. is there a clicking noise when you open and close the lid?
    if not then the lid switch may need to be replaced; inexpensive.
    this could also be caused by a bad timer.
    also try a different speed for the rinse cycle, it may be a bad motor and it is not going into a certain speed. instead of gentle or slow speed try fast or normal, something like that.
    Jun 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool 3.2 cu. ft. Plus Washer Logo
    761 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
