Question about GoVideo Go Video DVD/VCR Combo
Not reading Cd. Have to turn unit off and on again several times with drawer coming out.
  • 432 Answers
Get a cd laser lense cleaner something similar to the following :
http://www.amazon.com/Allsop-56500-CD-Laser-Lens-Cleaner/dp/B00000J1QK/ref=sr_1_2?ie=UTF8&qid=1242070074&sr=8-2
If that does not help and it still wont read a clean cd that has no finger prints, marks or scratches then that indicates that the laser lense for your cd player is broken / burnt out and you can either try and take it to a repair shop or buy a new one.
I would not attempt to repair it yourself as it is very intricate and delicate especially the laser lense.
Posted on May 11, 2009
  • Shane Russell
    Shane Russell May 13, 2009
    how come no feedback ?
The display flashes "closed" and I can't open the cd drawer when pressing the open/close button. Is there a reset please ?
Try removing power from the unit, let it set two minutes without power and power it up again. See if the problem continues.
Make sure the cd drawer is complete closed and flush with the front panel. If not, something could be stuck inside.
Turn off power and remove cord from wall for next step:
There is a small hole generally on the flat face of the cd drawer through which a bent straight paper clip can be pushed gently until you hit a mechanical stop. Pushing slightly harder at this point should cause the cd drawer to move open mechanically. Gently pull the cd drawer open until you can remove any CD still inside.
Gently push the drawer closed again and restore power to the unit and see if the problem returns.
Would be nice to have manufacturer and model number of the CD player.
Apr 08, 2015 | Audio Players & Recorders
Fisher paykel dd603 - both drawer units just come on and won't turn off - turn off power several times at breaker - tried reset - turns off briefly then comes back on -
There is water collected at the base of the dishwasher which is tripping flood switch. Will need to disconnect power and take the bottom drawer out and dry out the base. Need to find source of the leak. Most likely the lid seal or hoses.
Oct 17, 2013 | Fisher and Paykel 24 in. DD-602 Built-in...
Sony CD player CE-415 Drawer will not open.
This will require a professional, the more CD'S this unit can take the more complicated the loading bay will be. The most common problem is gear timing where the system is knocked out of sync and often locks down the device to prevent further damage. Sometimes the gears will strip jamming whole mechanism.
Mar 15, 2012 | Sony CDPM400CS 400-Disc MegaStorage(r) CD...
My CD drawer is stuck and has caused the complete unit to shutdown. Digital display reads : ' DRAWER ERROR '. How do I get things up and running again ?
ok i had this same problem happen to me this is what i did to Fix the problem.
i fully shut down the computer removed the power cord from the CD player and reinstalled the unit also make sure nothing is in the CD player.
if this doesn't work give me some more info on how this problem happened.
Jan 23, 2011 | Computers & Internet
When I press the button to open the cd drawer, the drawer doesn't open - any suggestions??
Just solved mine, turn the unit over and give it a shake and knock the underside a few times. I know you shouldn't be treating a delicate piece of hi-fi like this, but the tray comes out of the guide so you're just shakin it back in.
Apr 26, 2010 | Teac PD-H300 CD Player
I have several NUMARK CDN88 dual cd players with door opening issues. One player set the doors open and close too fast and dislodges the discs. On the other I have to power the unit up and down several...
Going through this problem myself. I've diagnosed that the drive (motor) unit should separate from a magnetic disc that sandwiches the CD between it and the motor. For some reason the mechanism isn't powerful enough to pull it away when the drawer wants to open, so it sticks. It seems to be a mechanical, rather than and electronic issue. I'm looking at replacing both drives rather than a fix, for reliability issues. I've got a number of CDN models and it's only the CDN88 that has this issue !
Apr 29, 2009 | Nu Mark Numark Cdn36 Dual CD Player CD...
Cdr20 drawer is jammed ERROR message
Try taking the unit apart it mostlikly jamed or jumped track try re ajusting it that would prob work, another thing is to try messing with the gears that could aslo work
Oct 18, 2008 | Harman Kardon CDR20 CD Player
Kenwood RXD25 CD player intermitent??
Hi jenoss
Sounds like the unit has either a failing load belt to the cd drawer mechanism,not allowing the transport to fully load the cd. Give the unit a gentle tap just after the drawer closes and see if it resolves the problem.
OR a faulty spindle motor, you will have to take the lid off and after pressing play, give the disc a gentle "kickstart". If it then begins to run, then the motor is the problem.
If you find it is neither of these, get back to me here and I we shall go further
regards
Graeme
Mar 16, 2008 | Audio Players & Recorders
GoVideo Go Video DVD/VCR Combo Logo
48 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
