Question about PSC QS6000 Plus Handheld
Windows XP does not recognize the Handheld scanner.
We have a psc qs6000 Plus handheld scanner with a USB connection. Since we didn't have enough USB ports on the computer it's connected to, we bought a D-Link USB hub. The hub works with the machine after we downloaded the driver for the peripheral, but now the PSC handheld device isn't recognized by the computer. Can someone help?
  • 31 Answers
My guess is that the USB hub needs to be plugged in ... if for some reason the usb hub doesn't allow you to plug it in then you need to get one that you can plug in... because I believe the scanner is using more power that the usb port can power. Scanner usually need to be plugged directly into the computer or they need to be plugged into a powered hub.
I hope this helps!!!
cdixon18
The Man Inside the Machine
Posted on May 11, 2009
I have a Dell Optiplex 320 running Windows XP SP2. If I plug in the QS6000 Plus USB Scanner it hangs while booting up. If I wait until Windows has started and plug in the scanner everything works. I have...
Most probably you have only one slot of RAM (a 256MB) if so you will need to upgrade it to more such as 1GB of RAM, the problem seems to be that the OS needs more Random Access Memory to connect with your Scanners drivers and make them part of the system such that you can be able to use it when you log in this becomes a problem as with limited Memory the OS fails to read the drivers and linking the scanner gets interrupted thus hanging on startup as it has other processes using the RAM at the same time and thus sharing it with the Scanner drivers and configurations. After other programs and processes have finished to run and minimal background processes are left after logon then this means more RAM is available so the Scanner can work easily when plugged at this point.
Mar 24, 2011 | PSC QS6000 Plus Handheld
Escanea 1 vez y que como apagado
If it doesn't scan anymore you must reprogram the interface (usb or serial) if it's bleutooth then it is not communicating correctly with the host, check the bind if it must be bound . You cans download the manual from www.datalogic.com psc has been bought by datalogic
Sep 04, 2009 | PSC QS6000 Plus Handheld
Ive got a second hand psc qs6000 plus barcode scanner. where do download its driver.
If you are looking to program your scanner:
USB Interface
Keyboard Interface
If you are using the USB interface, make sure you are plugging the scanner either directly into the computer, or if you are using a USB hub, it is a powered hub.
I hope this helps.
Aug 20, 2009 | PSC QS6000 Plus Handheld
QS6000 Plus with USB programing question
The document below programs the QS6500 Plus Scanner
R44-2805A Rev C
Available from
http://www.scanning.datalogic.com/sitefiles/manuals.aspx
Jan 27, 2009 | PSC QS6000 Plus Handheld
Obtain setup documentation
Here you go, hopefully this will work for you:
http://www.scanning.datalogic.com/html/manuals.htm
Specifically:
http://www.posguys.com/download/6000.pdf
If it does, please rate this as FixYa!
Thanks!
Dec 11, 2007 | PSC QS6000 Plus Handheld
Programming a USB PSC QS6000 Plus
Everything you need is came from your system mechanism. The only way to control your requirements is came from your programm coding.
at the start of the string sending must be filtered and rearrange from your program mechanism.
From what system you need to used barcode scanner? Are you using POS?
Hope you like my solution please rate me Solved.
best regards,
Philip
Nov 04, 2007 | PSC QS6000 Plus Handheld
QS6000 Plus barcode scanner
you can not change a qs6000 from ps2 to usb by just changing the cable. the interface inside the unit needs to support usb, to check this look at label with the serial number and if it says "I/F=KBW/RS" your our of luck, and can only use ps2 or rs232. if it says "I/F=UW" then you can just scan 3 barcode from the manual to set the interface to usb
Aug 28, 2007 | PSC QS6000 Plus Handheld
IBM Powerd USB not working
Are you using a USB 2.0 port?
Try a different USB cable.
PSC QS6000 Plus FAQ
Nov 28, 2006 | PSC QS6000
PSC QS6000 Plus Handheld Logo
1,616 people viewed this question
Top PSC Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Jax Planet
Jax Planet
Electric Dime
Electric Dime
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
