Question about Canon imageRUNNER 3035 Black and White Copier
No network printing
I have a iR3035 on a network can contact the machine via RUI can scan send from the machine but cannot network print to the machine. Have two 6020i's that work no problem, same basic network config.??
  • Christopher Barone
    Christopher Barone May 11, 2009
    Have tried direct standard tcp port in Windows using Canon network print device as the network card type and the latest Canon PCL6 drivers from the website.
    Evidently we need to purchase from Canon
    UFR II/PCL Printer Kit-S1
    and
    PS Printer Kit-S1
    Problem Solver:
  • 10 Answers
Press the counter button and scroll through the options to see what is and what is not installed. A Canon can network scan, but not print. Scanning is free, printing requires a license. If you do not see pcl or ps or ufr listing the system does not have a license.
Posted on Dec 25, 2009
  • 135 Answers
You need to add orinter to printers and faxes folder via IP address if you can contact me via phone i can walk you through it
Posted on May 11, 2009
  • 1 more comment
  • brian martin May 11, 2009
    I understand but I install canon's and i can tell you that part of your issue is that you downloaded the pcl driver, canon machines dont allow for pcl printing unless turned on in service mode.
    1ST download UFRII (setup.exe) from canon
    http://www.usa.canon.com/opd/controller?...
    2nd run setup and when you get to port you need to select manually set port.
    3rd get ip address from machine, make sure DHCP is off
    4th enter ip address on computer after selecting standard tcp/ip port
    go through rest of setup using your default settings
    that should work,if not please repost or call and i can assist you further
    1(850) 877-9486
    no if you are able to send scans to pc or to emailyou have network print already
    if you are willing to i can call you, i promise though if you can hook a cat5e cable to the machine then you have ability to print
MY canon iR3035 ccd scanner position is faulty..
Re: canon ir 3035 copy not lined up 1/4 inch higher it scans but configuration page i
service mode > copier > adjust > adjust xy > adjust Y input the value from the label on the front cover
This is all I could find. Try adjusting by 1/4 inch. Thank you Santosh
Jun 25, 2016 | Canon imageRUNNER 3035 Black and White...
USB connection faulty
That model should come with standard network connectivity. If, in fact, the usb port is out then you can connect the unit via ethernet on your LAN and regain your print and scan functions. Keep in mind that network scanning protocols (SMB, FTP, SMTP) require some IT knowledge to set up.
Dec 15, 2013 | Kyocera FS-1118MFP Laser Printer
How do scan a item and send it to my computer
you need to have the scan option. the nic option . print option. you need the the machine being able to print. after that create a folder that is shared on the pc. get the name of the pc. on the machine browse the network, find the pc and search for the folder. this is the shortend version. now you can scan to the pc
Aug 26, 2009 | Lanier Office Equipment & Supplies
Cannon Image writer 2870 -trying to retrieve a confirmation log for the past week (todays date 5/22/09)
At machine you can select 'monitor'from the bottom of the screen and select the log for copy or print. If you have network access to the machine you can use the RUI, it's much clearer. Just type in the IP address of your machine and the RUI interface will be displayed. You'll find print, scan and copy logs easy to find there and print.
May 22, 2009 | Canon imageRUNNER 2870 Copier
RemoteUI Contents is Not Found
Remote UI probably has not been installed on copier. Get a technician to come out and use SST to load RUI onto your copier. They should upgrade firmware to latest version at same time.
Don't forget you can also pull scan over the network using Canon Network ScanGear Tool in case you would like to scan.
Oct 18, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Ir5570 losing network connection on sending only
Is your firewall on the router or on the server? Are any of your computers using Windows firewall, McAfee, or norton security software?
Oct 06, 2008 | Canon imageRUNNER 5570 Copier
We buy canon copier ir3035 with all acces,every thing is don but we cant install properly pdl kit,because its not accepet printing from networking or we tray to print through usb port as will after install...
(This is for your information)First ur problem is not mentioned clearly. You are mentioning network printing is having problem (this is ok) but it is not clear that printing from USB is having problem or not. And you did not mention the type and version of your operating system(OS) and the nature of your network. Installing driver is very crucially depend upon the OS and the type of network that you are having.
Let assume that you are having genuine MS Windows 2003 Server as the backbone of your network and genuine MS Windows XP SP2 as the OS of the client PCs. Some basic knowledge of networking is required to understand and execute the remedy mention below. And you should read completely first before trying out this.
For network printing problem of Canon ir3035, first check the physical network cable(UTP) if it is properly crimped & properly connected, then check the connectivity by pinging the IP of the copier (which is needed to set manually if there is no DHCP server in the network). If the copier is responding properly. Check again by pinging the server from the copier (which you will find under MENU and NETWORK OPTIONS of the copier). If both the way is responding properly uninstall the printer driver totally and restart the system. Re-install the USB driver first and then re-installed the network driver (before re-installing the network driver first check whether it has got the required IP from the DHCP server, if not assigned one according to your network). If there is no error message during the installation of the USB driver(normally USB installation does not show any error), USB printing should be ok. Thus USB case is close.
Then check the network by using the same procedure mention above. If everything is ok, you can carry out the installation process for network driver. This way there should be no network printing problem. If still there is the problem please check that you are not using pirated copy of OS. Network printing for ir3035 is not ok if pirated copy of OS is used. You have to get a genuine copy and will solved the problem A to Z.
Jul 24, 2008 | Canon Office Equipment & Supplies
Sharp AR-M450 can't scan to e-mail
Check your primary and secondary dns entry.Also a return admin address is required.
Regards Ed
Mar 27, 2008 | Sharp AL-1641CS Laser Digital Copier
Unable to send a print job to the device.
i know what your problem is phone 07764303923
Oct 06, 2007 | Canon imageRUNNER 5570 Copier
Canon imageRUNNER 3035 Black and White Copier Logo
531 people viewed this question
old marine
old marine
