Question about Maytag MZD2766GES Side by Side Refrigerator
FREEZER KEEPS WORKING NOT REFRIG
Twice now we have changed the heating element in the freezer. The same thing each time. Could it be something else that is heating the element to hot and burning it out?
  • Maytag Master
  • 4,655 Answers
Yes, the defrost thermistat turns the element of when temps reach about 50 degrees F. The adaptive defrost tell the fridge to go into defrost. When the ice melts the defrost thermistat turns the element off.Whe can check the defrost thermistat if you like.
Your refrigerator has a adaptive defrost board inside the fresh food compartment hiding behind the control panel. That would be the first thing to consider that may be bad. But you also said you manually defrosted the refrigerator and it began doing this again about a month later. Take the model number and enter it in the search feature for model at it will take you to a page so we can look at the same refrigerator and work together to fins the answer. Below is a link click on that to look over your model. The adaptive defrost part number is 61005988
Let me know when you are ready, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
It is also possible the defrost thermostat is defective or a problem with a defrost element. Did you cange both element whith new defrost thermistat? Part number 61006199
Posted on May 16, 2009
My refrig and freezer wasn't working good, i replaced the heater that goes underneath the coils. now my problem is the freezer is on 0 degrees and the refrig is on 60 degrees, i noticed the flap that...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Refrigerators
I have a Kenmore side by side refrig. and the freezer side keeps getting full of frost, and the refrig. side is barely cold, and keeps spoiling food. I've had a tech come out and check things out and...
Either your defrost element or timer is bad or your fridge is low on freon. Frost is a sign of outside air getting in but it can also be a sign of the defrost heating element not kicking in and the defrost timer turns it on for a few minutes each day and a defrost limit keeps it from getting two warm during the defrost cycle. good luck hope this helps
Aug 17, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrig. not cooling properly
if the timer is working the most likely problem is the bi-metal(also called defrost thermostat)it is the disc shaped piece that clamps to the coils behind the back panel.you could also have a problem with the heating element,these items require a multi meter to check
Jan 25, 2010 | Amana ABB1927DE Bottom Freezer...
Frigidaire top-mount refig. freezer won't get cold ,temp.stays around 26 degrees, refrig. don't keep milk cold enough
check that the evaporator fan motor ,located in freezer is working.it circulates the cold air.also check that the coils behind freezer back panel are not iced up,this would indicate a lack of defroting due to,timer,heating element,or bi-metal.lastly when the refrig is running those coils should get frost over them all,if not you may be low on refigerant
Jan 20, 2010 | Frigidaire FRT17G5CSB Top Freezer...
Melted plastic floor in Freezer
The refrig is possibly a Magic Chef . This refrig has the coils AND defrost heater , under the freezer floor . If the defrost thermostat sticks , the heater will eventually burn thru the aluminum coil cover and melt the freezer floor . However , with the freezer floor burnt thru , the freezer fan is not pulling the complete air flow , over the coils , which in turn , a lot more electricity is being used , to try to keep the complete refrig cool . To repair , you would need 1 ) defrost thermostat , 2 ) freezer floor , 3 ) foil coil and heater cover , 4 ) a few hours or days ( if not done before ) .
So , no , not an easy fix .
Oct 05, 2009 | Refrigerators
Freezer keeps freezing up
You must change the defrost heater element, located in the back of the freezer compartment at the bottom. You have to remove the four screws, two on each side of the panel on the back wall of the freezer. The heating element located at the bottom has two wirers connected underneth on both sides of the element. The wires have female connectors which slide onto the male spades on the element, and can be easily removed. The single element heaters are now being replaced with a dual element heaters at the manufactures request. A refrigerator which I have repaired twice failed again when I replaced a single element with another single element heater after two years. I was informed only after a second trip to the same store to replace the part that General Electric suggested the dual element after they realized there were so many problems with the single element. I think G.E. should have factory recalled these units after they knew there was a problem. I also think I should not have to pay 38 dollars twice, and I should have been given the dual element the first time I had this problem!!!!!! I am a electronic and appliance technician and didn't have to pay for labor,But I am going to contacting G.E. about a refund for atleast one of my part replacements. I should been givin the dual element the first time. I recommend that anyone that reads this post that has had this problem do the same. My refrigerator was less than two years old when this problem first occured The dual element doesn't have to work as hard and will work much Longer!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 07, 2009 | General Electric GSS22JET Side by Side...
Freezer not working properly
Your heating element has failed and needs to be replaced, the heating element keeps your coils from icing up and in return when then go bad cause this problem.
May 16, 2009 | GE Monogram ZISB360DR 36'' Trimmed For...
Refrig not cooling, freezer is not cooling.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Apr 19, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Bottom section of refrigerator not keeping cold.
Nope it will not solve the problem. I am pretty sure your defrost element is faulty and needs replacing. This element assists the unit to melt the ice and clear the tubing and fins for better airflow which is then pushed into the fridge compartment.
Mar 03, 2009 | Refrigerators
Ge refrigerator model gss22wgph bb
Carben,
I have the same problem and I am able to resolve it by defrosting the element which is behind the inside rear panel of the freezer. I use a hair dryer to melt the ice build up. It happbed a couple of times so I know that there is a cause for this which may be the defrost heater but I am not sure how to confirm this. Let me know if you have any ideas.
Aug 20, 2008 | Danby (DAR604BLS) Refrigerator
Maytag MZD2766GES Side by Side Refrigerator Logo
199 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
