Question about Onkyo HTR500 Receiver
Reciever shuts off
When I turn my receiver up to about half, it clicks and then the sound goes out. It doesn't shut off, the sound just goes out. This is with 2 speakers hooked up. When I have 1 speaker hooked up, it's perfectly fine.
  • camaroguy722 May 11, 2009
    yea I think one of my speakers is messed up. When I hook up just my left speaker it does the same thing as if I hook both up.
    Problem Solver:
  • 7 Answers
You may have a loose wire in the back, your receiver is going into protection mode.
Posted on May 27, 2009
  • 3 Answers
Hi there
May I ask how many watts can your reciever handle ? And how many watts does your speakers need in order to be powered up (input). The two speakers you have installed might be too powerful for your reciever to handle. You might have to down grade to less powered speakers. All in all you have an excellent product there good choice...
Posted on May 11, 2009
Reciever shuts off after turning the volume up
You will have to change the volume controller and its circuit board.
F150 Accessories
Aug 12, 2012 | Audio Players & Recorders
Reciver turns on then rapidly turns off
the click is a protection switch. one of the power transistor or protection tranisitor is defective.
Aug 22, 2009 | Audio Players & Recorders
HTR-5280 Receiver Fuse Blown
the fuse rating should be printed at the back near the fuse holder itself. If it opens the fuse again and again probably you have a circuit loading problem in the receiver...either one of the amps is failing.
Aug 10, 2009 | Yamaha HTR-5280 Receiver
System shuts off when the volume is moderate to high, now the system shut off and will not turn back on.
unplug the reciever for at least 15 minutes. then replug in all of your speakers making sure there is no bare wire showing. if the reciever doesnt ower on replace the fuse inside(make sure unplugged from wall)
May 17, 2009 | Yamaha RX-V661 Receiver
Pioneer VSX-3800 shuts off
I have this same problem mike. have you founf any solutions yet?
I have a heck of a time turning my reciever on and when it does turn on I try to change the channel only to have my unit shut off on me! any help would be great.
Spriggs032@gmail.com
Mar 29, 2009 | Onkyo TX-DS575 Receiver
Denon AVR 3600 sound gone
this happened to me once and I found that my reciever would just shut down. make sure that you have plenty of space above the amp. it may be over heating and shutting down on you and when it cools down, it turns back on. there will most likely the "overload" light will be lit when it shuts down the audio.
hope that helps
Dec 31, 2008 | Denon AVR-3600
The reciever just shuts down
The manual suggests disconnecting inputs and outputs and power, letting it sit for an hour, then plugging it back in and turning volume to max to see if it still shuts off. If it does, the problem is with the unit. If it doesn't, the problem is elsewhere.
Judging from some other sites, this is a common problem. If you take it to a dealer, suggest they check the AC input. Before anything else, make sure that there are no stray wires on your speakers connecting the positive and negative clips, which will cause a short and activate the amp protection.
I had the same problem with an Onky502 and replaced it today with an Onkyo606. It worked fine for an hour then started shutting off automatically. I'm following the manual and letting it cool off now for an hour, and meantime I'll check my speakers.
Dec 30, 2008 | Onkyo TX-DS777
Should I just Buy a new one?
You have a bad power supply or the audio output circuit has a short in it. You are correct by saying its probably betterv off getting a new unit. Most likly cost you more then a brand new shiny unit would . Good Luck PS Please do not forget to rate this thread
Dec 10, 2006 | Yamaha HTR-5740 Receiver
Onkyo HTR500 Receiver Logo
298 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
