Question about Char-Broil Charcoal Water Smoker 4654301
Not enough heat
I own the Char-Broil Charcoal Water Smoker 465430. Had trouble keeping the temp. high enough to BBQ, was cooking tri-tip and veggies on the bottom rack, ribs on the top, about 3 1/2 hours past before I decided to remove the water pan and let direct heat be applied to the food. By the time food was finished kids were asleep, wife pissed. Now I'm Considering drilling holes in the bottom charcoal pan but I'm wondering if this mod. will allow air to flow considering that the charcoals will be sitting on the holes, should I consider installing a small grate that the coals will rest upon to create some clearance between the holes and the coals need more heat, Brian
  • funkinerd May 24, 2009
    I can not get this smoker to heat up enough. Right not I have hotdogs that won't cook. I have placed a charcoal grate over the charcoal pan to increase circulation around the briquets.
    Problem Solver:
  • 15 Answers
That's the problem with water smokers. The energy from the heat source is being absorbed by the water to heat it up to the boiling point. The cooler the water, the more energy is absorbed. You can start with hot water, or just not use any water. And yes, getting the coals off the bottom on the pan with a grate allows for the coals to heat more evenly. Also, I would not slow smoke veggies with the meat, they turn out best cooked directly over a hot fire (a little olive oil, salt, and pepper first)
Posted on Apr 09, 2015
    Habit-Forming:
  • 191 Answers
Time and temperature.. I consider my firebox my carburetor, my pit is the engine and the smoke stack is the header. You have to tune those to have a working machine. If you picked up a stainless doggy dish from walmart vented it your next step is the air intake which could be checked before holes if your temp gauge is working then check for adequate exhaust. I cook at 300...
Posted on Apr 02, 2015
I have not gotten a solution from FixYa, but some of the responses to other questions have revealed my plan of modification to the unit. No i would not like the Premium Assistance Plan, yet.
Thanks
Brian
Posted on May 12, 2009
I just got a Char-Broil H2O Smoker from a friend. I do not have a manual to tell me how to operate it. Also one pan is for charcoal and one pan is for water. Which pan is for which thing? One pan is solid...
Debbie, since you didn't have an Owner's Manual with your smoker. Rather than me go thru a lengthy process of explaining all there is to know and how to use the H2o Smoker.
Here's a link to the Owner's Manual, that you can download and print for future reference.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/06701289%20assembly%20manual.pdf
Hope this helped you and enjoy your smoker.
Jun 19, 2011 | Char-Broil Charcoal Water Smoker 4654301
Is meat placed in main grill or in attached box
The "offset" box is your firebox. This is where you will put your charcoal. The meat goes in the larger chamber on the grill. This type of cooking is known as indirect cooking where the heat source is not directly under the meat. A grill cooks direct with the heat source coming from charcoal or gas burners located directly under the cook grills. Smoker can really deliver some great tasting food. Be patient and learn the ins and outs of cooking with a smoker. The most important thing is to cook low and slow. try to keep your temps in the cook chamber around 225. I hope this helps.
Jun 29, 2010 | Char-Broil Sierra Offset Smoker
NEED BASIC COOKING INSTRUCTIONS. HOW TO COOK ON A CHAR-BROIL H20 CHARCOAL SMOKER. I PICKED A NEVER BEEN USED ONE AT A GARAGE SALE. IT DID NOT HAVE ANY INSTRUCTIONS WITH IT. PLEASE PROVIDE.
You can find your manual here.
http://www.brinkmann.net/products/details.aspx?item=810-5301-C
It should explain the process. I use a smoker a lot so my tips are, keep the temps as close to 225 as possible, reload your charcoal as soon as the temps start falling, don't peak, and patience will make for really good cooks.
I hope this helps.
Jun 04, 2010 | Char-Broil Deluxe Charcoal H2O Smoker
Tried everything but I never could get the temperature above 200
grill wok replaces charcoal bin
Confirming that it works well. Super idea and very effective tool for keeping the fire consistently hot. Roughly $12 for one at local depot. This takes the frustration factor out.
Temp will stay nicely for an extended period of time. You will use less charcoal, but you do need to check on it every 1 1/2 to 2 hours to keep the temp constant.
Additional information: Source:
http://www.smoker-cooking.com/cant-get-the-temp-up.html
Going online and reading the reviews on my smoker from Home Depot I found out that everyone has this problem with this smoker. Without making any adjustments it doesn't get enough air to the coals to make the temp go up. Most people drilled holes into the coal pan and that works fine.
Oct 06, 2009 | Char-Broil Deluxe Charcoal H2O Smoker
MY LID DOES NOT FIT TIGHT?
Where are the 3 holes at? I have one like the one you purchased and my lid didn't hold on tight either. You have to really try and force it on and after using it for a while it will fit snug. The heat helps it set better after a while.
Aug 21, 2009 | Char-Broil Charcoal Water Smoker 4654301
Need help smoking briskett on Char Broil Grill with smoker box
wood chips in the fire box. very low heat. around 200 degree.
maek sure the wood chip is wet and produce smoke. you need to monitor this through out the process.
briskette in the grill side without any heat. depends on the sixe and the thnikness of the meat, you need approximately 12-20 hours before meat become tender.
here are few web site you can get some information
http://www.smoker-cooking.com/howtosmokeabrisket.html
http://bbq.about.com/cs/brisket/a/aa111503a.htm
http://www.wyntk.us/food/smoking-brisket.shtml
http://www.bbq-fyi.com/how-to-smoke-brisket.html
May 29, 2009 | Char-Broil CharBroil 4637318 Grill
For got how to setup and smoke
http://bbq.about.com/od/barbecuehelp/f/f060604a.htm This about the best instructions I can find, better than I could explain it myself....good luck.
Dec 24, 2008 | Char-Broil Deluxe Charcoal H2O Smoker
Don't know where to put wood chunks in a Char-broil electric h20 smoker!!
Dip wood chips/chunks in boiling hot water for a few minutes if you're in a hurry or allow to to soak in tap water for about an hour if you have plenty of time. Either way, place the soaked chips around and under the heating element at the bottom. Don't throw out the water; heat it up and pour it in the water pan. Heating it up to boil will give your smoker a good head start. I've been doing that on my char-broil smoker for years.
Jul 02, 2008 | Char-Broil Electric H2O Smoker
Tripping the electrical Breaker
I have used the charbroil bullet electric H2O smokers for years (wore 2 out - currently on my 3rd). I won't use anything else (having used many, many others - HOWEVER - as with every product made there are things to watch or overcome. Learn to use it properly and look forward to many years of great BBQ.
Ambient (outside) air temp below 70 (depending on wind also) will affect these smokers drastically - highly recomend getting or making a "smoker blanket" (got mine at cabelas years back - if you can't find one welding blankets from an industrial supply store can be made into one) to insulate the sides - this drastically reduces heat loss and reduces the electrical load.
Another MAJOR mistake many people make is extension cords - avoid the use of them at all if possible - if not possible then purchase the heaviest gauge you can find.
Always pre-heat your smoker - Always use boiling water (or other liquid) in the H2O pan added after smoker is pre-heated - Always minimize opening the smoker once cooking has begun.
The heater element can be cleaned when cold with a very mild detergent and room temp water.
If you have the large 2 rack but are only smoking enough to use a small amount of rack space on only one rack remember that you are heating a whole lot of air - i have a couple (different size) wood boxes wrapped in foil to take up excess air space - this means less air volume to be heated and better heat control - DO NOT use cardboard boxes or other low temp combustable items in the box construction!
Make sure the house outlet you are plugging into is a 3-prong GROUNDED outlet on a 20 amp breaker.
Finally, make sure your smoker is level and remember there can be up to a 20 degree cooking temp swing in temp between the bottom rack and top rack (top rack 5-20 degrees hotter than bottom).
The heater element will cycle on and off during normal use.
Good smoking and enjoy.
Apr 28, 2008 | Char-Broil Electric H2O Smoker
Char-broil water smoker
first, a charcoal fire in bottom tray, then a pan filled with hot (boiled) water above it, then the meat on top tray, then keep lid on a long time (hours) without peeking and remember to keep charcoal topped off. you should also soak hardwood hickory sticks in water for a day or 2 and wrap in aluminum foil with small holes punched through and place on top of charcoal to provide smoke. usually a large chicken is done in about 4 hours.
Oct 12, 2007 | Char-Broil Charcoal Water Smoker 4654301
Char-Broil Charcoal Water Smoker 4654301 Logo
656 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
