Question about Panasonic Palmcorder PV-GS15 Mini DV Digital Camcorder
Samsung dv-d361 . i dont have any driver software plz help me
I have data cable but when i connect to my pc its say unknown usb device. plz tel me what i have to do ...
  • 661 Answers
You have to install the drivers,
usually you would install the CD that came with this device first, then when you plug it in it will recognise the device.
here is a link to the manufacturer's website
I am assuming this is a VP-D361
Posted on Oct 13, 2007
Can i connect my vp-361 direct to a usb port ?there is a cable where it need a special connection to the pc
Hi Willy, i have the same problem. Im trying to connect my Samsung VP-D361 Mini DV Digital Camcorder to my laptop (Windows 7) but I cant. Is the problem with the O.S driver compatibility?
Mar 16, 2011 | Samsung VP-D361 Mini DV Digital Camcorder
I have a digi cam vp d 381i from samsung and my computer is not recongnising it. Do I need the driver software? I've got a dv-usb cable.
First you should install the driver of the camera according to your operating system, it's better to get the latest from the manufacturer web site, in this case Samsung.
Feb 08, 2011 | Samsung VP-D361 Mini DV Digital Camcorder
I have a SAMSUNG mini DV camcorder (model SCD27) and want to find a cable that can download my videos to the computer. I need a DV to USB cable that will be compatible with this camcorder. Please help...
There isn't really a DV to USB cable. They are different standards. There is apparently a converter for this, but the chat on the forums is that it doesn't work properly with video cameras.
If your Windows PC did not come with the Firewire (DV) interface (most don't), you will need to fit an add-on Firewire interface card to the internal PCI bus. This will come with a driver for the card. This can only be done on desktop PCs, not laptops. You can buy the card cheaply on eBay or Amazon. You can get a cable there too, but I expect you got a Firewire cable with your camera.
Dec 07, 2010 | Samsung VP-D361 Mini DV Digital Camcorder
My samsung phone is not connecting through data cable with my pc. i bought a new samsung set of beat addition 2 days before for using internet through data cable. but my phone is not connecting with my pc...
run again your pc studio cd software installer..
by default, it will play and give the swf home page where there is an option for install usb driver. select install usb driver in order to install your usb driver but before installation disconnect your phone from pc and remove the usb cable. once it's installed, right click your PC studio and select open automatically when device is connected.
>>on your phone, select settings,select settings for your pc connections, check ask for connections and reconnect your phone.
Feb 21, 2010 | Samsung Beat SGH-T539 Cellular Phone
Cant transfer videos from samsung vp-d361 pal
Check if it has the firewire port. If so, you can get a 4 pin firewire cable and connect to the PC.
Switch on the Cam.
Open Windows Movie Maker and import video from device.
4 pin firewire would look like this:
You can use the Movie maker to burn it to the Disk
Mar 08, 2009 | Samsung VP-D361 Mini DV Digital Camcorder
Samsung VP-D361
looks like you need a new camera
Aug 28, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
the samsung website has a vista update driver for this problem
Jan 25, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
Yes it might be the problem..First try a different cable..Also check the data transfer port(wher you connect the cable)on your phone for bent/broken pins..If the pins aredamaged you will have to get a new data port and dont worry its very cheap..usually 5$ or less..
Oct 19, 2007 | Samsung SYNC SGH-A707 Cellular Phone
I need a DV cable so I can download my movies from my JVC Camcorder, but my laptop has the USB interface only. Can someone help me find a DV Cable with a USB Interface at the other end? My laptop only...
your camera has a usb connection : wal - mart has general purpose camera to pc cables ( bring your camera to confirm connector size ) also on ebay can get accessory kit for jvc dv cameras .
Aug 05, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Connecting analong camcorder to computer
The only Analog camcorder that has a USB Connection for transferring pictures or video is the SC-L770. The SC-L770 can transfer video (live or recorded) and still photos through the USB connection. You can also transfer audio using the audio cable provided. After installing the driver and software, you can begin transferring data using the software provided. Connecting to a PC 1. Connect a USB cable to the USB port on the PC. 2. Connect the other end of the USB cable into the proper terminal on the camcorder. (USB jack) 3. Connect the audio cable to the Line input jack of the PC. If the PC has no Line input jack, connect the audio cable to the MIC input jack. In this case, however, a noise may be produced depending on the PC. Notes: * If you disconnect the USB cable from the PC or the camcorder while transferring, the data transmission will stop and the data may be damaged. * If you connect the USB cable to a PC via a USB HUB or simultaneously connect the USB cable along with other USB devices, the camcorder may not work properly. * In this case, remove the other USB devices from the PC and reconnect the camcorder. Some other Analog Camcorders have a snapshot mode which allows you to take a still photo with your camcorder. However, you cannot transfer these to a computer unless you purchase additional hardware such as a capture card. Some capture cards have analog a/v inputs which will allow you to use the a/v outputs on the camcorder to connect to your pc and transfer images and video. You can purchase a capture card at most computer and electronics stores. Samsung does not support capture cards.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Panasonic Palmcorder PV-GS15 Mini DV Digital Camcorder Logo
401 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
