Question about Microwave Ovens
I NEED LATCH FOR HALFPINT MICROWAVE 1993 - Microwave Ovens
  • Microwave Ovens Master
  • 9,098 Answers
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Posted on May 12, 2009
My microwave
The latch mechanism (specifically the bottom latch which is tied to the sensor) is not locking in place. Try lubricant on the latch and receiving side first (I used wd-40, but it smells horrible, so try maybe bike grease or even veggie oil to see if it helps). Main problem is that the latch panel is attached w/thin metal which I bet was designed to fail after the warranty has passed! You basically need a T-20 torx screwdriver to open the microwave all the way up and bend the metal bracket back. I ended up taking a long wire and tying it through the bottom latch assembly (there is a hole) between a top and bottom hole on the frame of the microwave to keep it from ever moving again. You want to pull the entire assembly (black plastic) towards the microwave cavity.
Jan 31, 2015 | Panasonic Inverter Countertop Microwave
Door latch on Emerson microwave oven
u will need new door asemble to relly fix it ok thx nick
Feb 10, 2008 | Emerson MW8987B/W Microwave Oven
Frigidaire Mod: FGMV174KFB Door won't latch
Good Morning Friend,
I understand the door will not latch on your Frigidaire microwave, model# FGMV174KFB. Typically, this would not be a do it yourself repair, as you are working with your microwave, and there are no step by step repair instructions. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to fix the latch on your door with ease. Hope this is helpful.
-Best Regards-
WP
Jun 30, 2014 | Frigidaire Microwave Ovens
Latch doesn't always catch so microwave won't run
Well I think you need to clean and pray the latch area with silicone spay lubricant and work the catch a few times to work it into the mechanism and see if that makes any difference but make sure you wipe off any surplus silicone spray
Jan 02, 2018 | Microwave Ovens
Inside door latch broken on my Sanjo microwave EMD9552
Hi, For any repairs involving door latches on microwave ovens, I strongly urge you to get a certified service technician to replace and adjust the door for you as he should have a leak detector to verify the fix. Not performing the leak test could expose you/your loved ones to harmful microwave energy if not setup correctly
Dec 08, 2012 | Sanyo Microwave Microwave Oven
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Samsung microwave door won't latch
You will need a Samsung dealer repairman, the inner mechanism will need to be serviced because for some reason it is jammed or there are broken parts.
Apr 08, 2012 | Microwave Ovens
Microwave will not cook/start when start button is pressed.
You can get the latch itself from either partstore .com or repairclinic .com
Apr 19, 2010 | Emerson MW8168B Microwave Oven
Replacing door latch pawl
how do I replace door latches on a spacermaker XL microwave oven? thanks
Oct 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
20 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
