Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Getting started with MP730
Don't know how to hook up; have Windows XP running on Dell Latitude laptop. Please help !!! I want to start using the printer, fax, etc... Is it possible to have someone talk me thru the problems of starting up? Ph # 518/732-7480
  • Bob Kitaji May 11, 2010
    Do you have the install disk, user manual and a USB cable?
Tech support from cannon.
Posted on May 13, 2009
Dell latitude d600 can't click my start button
I would suspect , 1, you have to many startup programs, use CCLEANER at : http://www.filehippo.com/download_ccleaner/ This freeware program will remove the junk from your Dell and in the TOOLS section, STARTUP section, disable ALL unnessary startup programs. 2, Download MALWAREBYTES freeware at : http://www.filehippo.com/download_malwarebytes_anti_malware/ Run a FULL Scam , Delete ALL results , Reboot. If you are using Windows XP use these tips: http://www.wikihow.com/Speed-up-a-Windows-XP-Computer You could consider more Memory, your machine supports up to 2GB's.
Feb 20, 2013 | Dell Latitude D600 Notebook
How to bypass Windows password for dell inspiron D630
If you're talking about the Windows Password for a user account try this: Turn the laptop off then turn it back on and immediately start hitting the F8 key repeatedly until you see an option for SAFE MODE. Take the Safe Mode option and let the computer boot up. When it gets to the login screen it will show you the Administrator account and the account for the user that you don't know the password. Select the Administrator account and hopefully it's not password protected. When you get into the windows desktop click Start/Control Panel/User Accounts. Under user accounts select the user for which you don't know the password then select the option to Remove Password. Click OK and reboot the machine.
Mar 19, 2012 | Dell Latitude D630 Laptop Computer PC...
When I turn on my Dell Latitude D600 PC, the windows xp loading page appears. After it has loaded the screen turns black and does not make any further progress.
It appears that your display works fine until Windows XP loads. Try tapping the key when powering on the laptop. Select boot in safe mode and see if the laptop works.Here's a description of safe mode by Microsoft.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
If your display works in safe mode then you have a video driver issue or virus or software issue.
Jun 20, 2011 | Dell Latitude D600 Notebook
I can not setup windows xp in my dell latitude e6400 laptop.I set BIOS (F12), select "System Configuration", "SATA Operation" and i change it from "IRRT" to "ATA. But no work.When i start windows xp setup...
Try this hints:
1.Press F2 to enter BIOS on start up
2. Expand Drive section
3. Go to SATA Operation
4. Check and change from Raid Auto/ AHCI to Raid Auto/ATA
Good Luck
Apr 11, 2010 | Dell Latitude E6400 Laptop
Start up problem in dell laptop
I am thinking that either spyware or a virus might have currupted one your booting files. You need to run anti spyware software and/or antivirus software. Try Windows live one care software this have a 90 free trial version, run it in safe mode and see what happends.
Let me know if it works.
Apr 10, 2009 | Dell Latitude C610 Notebook
Virus
Don't reformat it just yet. Tell us what OS you are using, and I can try to help.
I will assume you are using WIndows XP or Vista - what you can do, assuming you have kept your PC up-to-date, is try to run the inbuilt Microsoft anti-malware program.
Click Start, Run, type MRT and press Enter or click OK.
You should get the February 2009 version of the Microsoft Malicious Software Removal Tool.
Do a quick scan and see what comes up. If anything is found, reboot and repeat the process doing a full scan (can take several hours).
That should fix and remove the most common virus infections. Let me know how you get on.
If you still need to reformat, you need to use the Dell recovery CDs that came with your laptop. These were a blue recovery/drivers CD and a purple CD for Windows XP sp1 or a green CD for Windows XP sp2. Not sure about other versions of Windows. There is no magic button to reformat with Dell laptops.
Feb 16, 2009 | Dell Latitude D600 Notebook
Dell latitude 600 running windows xp wont defrag
MATE I WUDNT SAY IM AN EXPERT BUT IF I WAS IN UR POSITION I WOULD JUST REINSTALL THE COPY OF WINDOWS XP
Dec 05, 2008 | Dell Latitude D600 Notebook
How to upgrade a Dell Latitude CPX - Intel P3 500-650 laptop
I have a CPX H500GT. To get it to run XP Pro to run right, max out the ram. And get a larger harddrive. Xp uses a substantial amount of space.
Sep 22, 2008 | Dell Latitude CPX Notebook
Dell Latitude c640 Disable BIOS memory
Just use recovery console of windows xp bootable media and use the following command.
chkdsk (to check the volume).
fixmbr
fixboot
It happens due to improper shutdown methods which has caused the system volume to corrupt the MBR.
Dec 13, 2007 | Dell Latitude D600 Notebook
Windows. file missing or corrupt system32 config
If you're running XP, boot to the XP cd, if available (if not, mail me and I can send you a dell XP disc)
Pass the first repair opportunity, press f8, then it should allow you to do a windows repair. Do that. You will keep all your files, but windows will be completely reloaded. Will need to get updates, but that's it.
Good luck
Nov 22, 2007 | Dell Latitude D800 Notebook
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
62 people viewed this question
old marine
old marine
