Question about Acer AC713 17" CRT Monitor
My acer monitor won't light up anymore i've tried two very good computers on iy and nothing makes it work i am now using an old monitor loaned to me by my son's office.
  • 20 Answers
Im assuming you have tried a new power cable?
Posted on May 11, 2009
Why is the power light on my Acer monitor flashing?
See this.. http://www.techsupportforum.com/forums/f25/acer-monitor-is-blank-and-power-light-flashing-green-318760.html
Also, here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 26, 2014 | Acer Computers & Internet
I have an acer aspire m3400 is start but no sound, no display graphics plz help me.
Try another monitor. If that works, download the latest drivers for your OS here... http://us.acer.com/ac/en/US/content/drivers
If the old monitor still doesn't work, here's some tricks I would try...
Jun 28, 2014 | Acer Aspire M3400 PC Desktop
Acer Aspire 5536 only gives black screen when i connect power supply
  • Nothing is more annoying than a monitor that refuses to turn on. Make sure your Acer monitor is plugged in to a functioning outlet. If it's plugged into a power strip, try replacing it with a new one or moving the plug to a different outlet. Ensure that both ends of the power cable are plugged in firmly and securely, and that the connection to the monitor is not loose.
Cable Issues
  • Your Acer LCD monitor will usually accept DVI and VGA inputs. If you have an older computer, a VGA cable should work fine. If it doesn't have a VGA port, you'll need to obtain an inexpensive DVI to VGA adapter at your local computer store. A DVI cable, however, is compatible with most modern computers and offers superior picture quality over VGA. Make sure you're using the cable that's compatible with your system, and that you have the proper conversion adapter, if necessary.
Jun 19, 2012 | Computers & Internet
My acer monitor p191w will turn on acer logo comes on goes black then a screen comes out saying no signal then turns of light turns yellow ...tried restarting monitor nothing
Connect the monitor to a different computer, to see if the monitor works at all.
Connect a different monitor to your computer, to see if your computer really is "sending" a video-signal through the "data" cable. If not, then either the data-cable or the video-card inside the computer is faulty.
Jul 13, 2011 | Acer P191WBD LCD Monitor
I have a Acer X203H Monitor. Everything is connected I've checked a million times. When my computer turns on it displays fine on the monitor, but the first or sometimes second time the computer goes to...
I would try this monitor with another PC first to verify that it is not PC problem.
Most common failures in the monitors are due to bad caps in the power supply/inverter board, we want to find out first if it is the monitor or the PC problem.
See examples of failed ACER due to bad caps here:
http://s807.photobucket.com/albums/yy352/budm/ACER/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 24, 2011 | Acer X203H Monitor
Acer monitor will not work, not light no
The capacitors are good, no bulging top/seal? Pictures? see example of failed monitors: http://s807.photobucket.com/home/budm/allalbums
Pictures will help a lot.
Mar 19, 2010 | Acer AL1914 19" LCD Monitor
The acer aspireone screen wont light up when i turn the computer on. the power light comes on, but nothing else happens.
The screen looks to be bad.
Usually the internal lamp burnt out.
If you need to use it, change monitor and try it.
This way you make sure that the video card is working properly.
Don't forget to rate this answer if it helps
Dec 24, 2009 | Acer 22" X223w LCD Monitor
Dell Inspiron 531 (desktop) won?t turn on/boot
You've either got a bad motherboard or a bad processor (I'd lean to the motherboard being bad). I would honestly take this into a computer repair shop and have them check both.
Oct 22, 2009 | Dell Computers & Internet
I VE GOT ACER X221W HAD IT SINCE 1 YEAR .. MY
I have acer aspire the mouse will not work
Aug 19, 2009 | Acer X221WSD Monitor
Acer AC713 17" CRT Monitor Logo
437 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
