Question about Dishwashers
Water remains in bottom of tub after cycle is complete.
I have a new built in Hotpoint dishwasher. After the cycle is complete and drying cycle is done, there is 2" of water remaining in the bottom of the tub. Every dishwasher I have had always pumps out the tub and is dry on the bottom. Please advise--all lines are hooked up properly--This is A Hotpoint built in-- Model # HDA 2100N10WW The control knob shows "Hot prewash option" Could this be the reason for the water present in the bottom of the tub ??
  • 27 Answers
SOURCE: water level
Some water in the tub after the cycle is complete is normal. most dishwashers are time filled with a float switch as a safety device. the actual level depends on the fill time and the water pressure. what exactly is the d/w doing (or not doing) to make you think there is a problem?
Posted on Nov 01, 2007
aborcass
  • 2651 Answers
SOURCE: dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Posted on Feb 22, 2008
SOURCE: Maytag 300 Quiet Series Dishwasher
Unit will not turn on..had this unit for 6 months..worked fine..all of a sudden wont turn on now..checked power and connections..all were good..im stumped..just wont turn on.
Posted on Feb 26, 2008
  • 93 Answers
SOURCE: Premature drain on Hotpoint HDA 3400 dishwasher
hello my name is gilles the problem you have their is something stuck in your drain valve causing the valve to stay open remove the valve clean out reintall every thing should be fine thanks
Posted on Mar 15, 2009
SOURCE: Hotpoint Aquarius SDW60 Dishwasher
i have had this dishwasher sdw60 for 18 months and it just keeps beeping, i have cleaned it ,turned it off at the mains it just dont wont to work. please help.
Posted on Feb 08, 2010
Why will my dishwasher Electrolux model #EIDW5905JS0A, not drain completely at the end of its cycle.
Good Morning Friend,
I understand your Electrolux dishwasher, model# EIDW5905JS, will not completely drain at the end of the cycle. It is not normal for water to remain in the bottom of the tub at the end of a cycle. If water remains in the bottom of the tub at the end of a cycle, the dishwasher may not be draining properly. Please follow these troubleshooting tips:
    1)If unit is hooked up to a garbage disposal, make sure the disposer is empty.
    2)If unit is hooked up to a new food waste disposer, check to see if the "knockout" plug located inside the disposal inlet has been removed.
    3)Check to see if drain hose is kinked.
    4)Make sure cycle is complete, not in a pause.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
Jul 03, 2014 | Electrolux EIDW5905JS Dishwasher
Why does my dishwasher not drain completely at the end of its cycle.
    -Best Regards-
    WP
Dirty water standing in the bottom of the tub
There is probably some debris that is blocking the water from getting to the pump.For More information please visit Kenmore Parts.
Oct 04, 2012 | GE Nautilus 24" Built-in Dishwasher
The drain is not clogged or blocked and the line is not kinked. The hoses are not blocked & the air gap clean. The disposer has not been replaced recently. The drain hose from the disposer to the air...
their will some water that always remains in the pump below the fliters is should never be visible in the tub once cycle is over but it must always be there to keep the seals moist to prevent them from dry rotting
Aug 26, 2011 | Hotpoint 24 in. HDA3400G Built-in...
I have a brand new whirlpool DU1055XTV5 dishwasher, installed two days ago. After the cycle completes there is about 1/2" clean standing water left in the bottom. It is not just down in the well area,...
Ensure the outlet pipe is below the level of your floor and straight to a drain or plumbed into the waste pipe directly with no chance of syphoning from standing water in your drain/waste pipe.
Apr 04, 2017 | Whirlpool DU1055XTS Built-in Dishwasher
There is a smell in the dishwasher and on the dishes when clean
I suspect stagnant water is laying in the bottom areas. You will have to lay the machine on it's back to access the pump.
May 27, 2010 | KitchenAid KUDK03ITBK Built-in Dishwasher
Water left in compartment
You need to elevate your dishwasher drain hose under the sink. The water going down your disposal side is running down the hose into the dishwasher.
Nov 05, 2009 | KitchenAid 24 in. KUDS25 Built-in...
Suds in dishwasher after rinse cycle
sprinkle some cooking oil in tub this will desolve the suds apperantly u used reg. dish deg.
Oct 27, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Dishwashers Logo
64 people viewed this question
Top Dishwashers Experts
