The chassis was recewntly rebuilt. I have a picture, but no sound.
Mitsubishi WD 62525- I recently had the chassis rebuilt. The picture is fine and the set is working properly except I have no sound.
ctf1800
  • 4402 Answers
SOURCE: Mitsubishi WD-62525 DLP has no picture
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Posted on Feb 11, 2008
SOURCE: Mitsubishi Projection TV Power Supply Board assistance - Model # WD 62525
Mr.Marxxx you need to let one of your friends fix it for a small fee.Just like everyone else does.
Posted on Jul 29, 2008
SOURCE: mitsubishi wd 62525 chassis
I was told there was a bad batch of capictors so we reaplaced all of them and still the blinking green light ,and no tv still help bagelbaker77@yahoo
Posted on Aug 09, 2008
rulds2008
  • 3866 Answers
SOURCE: cannot turn tv on
Check power supplly make sure its not the fault in wht this will not turn on.
Unplug tv from wall wait 30 secounds and plug back in.
If that does not work you will need to have someone look at the powersupply.
Posted on Jul 01, 2009
carwhiz
  • 9 Answers
SOURCE: im getting error code 34 on my mitsubishi tv wd
If the caps are not pregnated looking they are good. I had the same code and I changed the caps anyways and still did not work. I found out that it was the colorwheel. Or it could be the cap that is on the light ballast(if the cap is not pregnated its the color wheel and you can find that on ebay for about a 100 bucks).
Posted on Jul 10, 2009
Wd-62525 dlp: I get the following message: TV
how long does the set run before you get the message?
Dec 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
My timer light keeps blinking on my Mitsubishi-TV not watchable
tv is not locked up, you have a lot of capacitors that have gone bad on the boards that make up the chassis. We have been sending the chassis in to Mitsubishi to be rebuilt. Some people have been doing the capacitor changing themselves but, this is a very involved job.
Dec 03, 2009 | Televison & Video
My TV wont turn on and the timer button keeps flashing on and off. I don't believe I have the remote anymore either.
You have a bad chassis . The good news is if you call
Mitsubishi and tell them , Thay may cover you.
if not the chassis needs to be sent to Mitsubishi it take about 3 weeks to have it rebuit . it will cost you about 200 to 300 to get it rebuilt + labor from you local service person
Nov 18, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Blinking Green Light Mitsubishi TV
I had the power supply replaced, but didn't solve the problem. Turns out multiple issues were at play. Only thing that solved the problem was to the have the chassis pulled and rebuilt by Mitsubishi. If you are insistent enough they should do it for free, minus the labor for removal and re installation (approx.$300)
Oct 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Chasis was replaced 5 months ago. Set turns on
Contact Mitsubishi immediately. They will warrant the chassis for 6 months.
Sep 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
MItsubishi DLP HDMI HDTV WD-62525 Steady RED Status Light Indicator/ after system reset, no sound/picture
  1. Call Mits. and see if they will cover the main chassis rebuild then call an authorized service center to pull the chassis will take 4-8 weeks for it to be rebuilt but you will be resposible for labor
Aug 25, 2009 | Televison & Video
Where is the chassis fan location in a Mitsubishi wd 62525?
thats the fan thats directly mounted to the top of the Chassis's metal case
Feb 05, 2009 | Mitsubishi WD-62525 62" Rear Projection...
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Vertical lines on Mitsubishi 62" DLP
the DM and/or the FMT board are going bad. the chassis needs to be rebuilt. check out www.tv-techs.com
Jan 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
