Possible air con related, but happens if air con os on or off
Ask any mechanic. we cant here it here.
or if really a DIY person, are you? the use a rubber hose to ear
and find the source. then post a better post.
see here, my finger, pointing to this object( photos) it makes knows, when I , xxxxxxxxxxx
also , it might be normal, or a noisy, heater box damper motor.
if the motor is noisey the labor is huge to pull the dash, are you
up for $$$ just to quite that noise?
SOURCE: water leak
if it is pure water and not antifreeze then i would say the drain is blocked. check under your hood on the firewall around heat/ac for your drain tube
Testimonial: "Thanks "
SOURCE: 1999 grand jeep cherokee limited air con prob
You have a leak in your air conditioning compressor Your system works on the reheat principle All air passing through the system is cooled and reheated before it enters the cabin this sould be dehumidified air but it passes through the heater core and sence the air is not dehumidified you are getting condansation as the air flows the heater core that is heated by the engine heat and the water is from condencation because of the leak in the ac compressor The unit is a press fit in the center of it and fials unfortinatly a lot with this disgien of compressor
