Question about Compaq Presario R3000 Notebook
Problem with my screen
Hi i have problem with my laptop presario r3000. i'm turnin it on but my screen doesn't react. it's black and i can't see anything. any shortcut don't work. please help maybe its something wrong with motherboard ?? i didnt use my laptop 2 months. before everything was fine. what can i do ?
  • Compaq Master
  • 32,281 Answers
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 11, 2009
I have a Compaq Presario R3000 laptop. Is it capable of burning DVD's and if so, do I need additional software. I have made a video with sound on Kizoa and I cannot burn it to a DVD as the program...
According to epinions Your Notebook is NOT capable of burning DVD's. It can only burn CD's.
http://www.epinions.com/specs/pr-Compaq_Presario_R3000_Refurbished_dz338ur_aba_PC_Notebook
Jul 11, 2011 | Compaq Presario R3000 Notebook
My screen is cracked. I need a new one, but i need to know how to take the screen apart
Hi
if you click on this link it should take you to the disasembly manual and it will show you how to replace your screen you may need adobe reader installed ( free download ) if it is not already installed
also ebay is a very good place for screen replacements
http://www.insidemylaptop.com/disassembly-manual-compaq-presario-r3000-notebook/
good luck
Mar 09, 2011 | Compaq Presario R3000 Notebook
My laptop Presario R3000 won't turn on
let it sit for awhile. then try to power it on. if it powers up and then suts off again, the processor fan is probably bad and needs to be replaced.
Also, take the battery out and tryy to power it up.
Aug 13, 2009 | Compaq Presario R3000 Notebook
My compaq preasrio r3000 black screen cant conect to an external
have you any other A/V ports out ie Svid etc if so try that via an A/V lead, if that works reset your bios settings to minimal settings, if that doesnt work search the 'net someone somewhere has had the same problem! try shining a flashlight/lamp onto the screen whilst booting up, if you see anything on the screen then your inverter is definatly gone and yes it could still be your inverter! your laptop may have software/hardware issues with an external monitor?
Mar 09, 2009 | Compaq Presario R3000 Notebook
Compaq Presario R3000 dim screen but not dark
Sounds like the auto-dim in the BIOS is set too low. Fortunately the Compaq R3000 allows you to adjust the brightness right from the keyboard. Hold down the [FN] function key while tapping the [F8] key will brighten the screen, while [FN]-[F7] will dim it. The settings are different for running on AC power and battery, so you must do each individually.
Dec 31, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario R3000 PC
Hi Tom,
It appears without looking at the laptop you have removed or dislogged the cable that goes between the motherboard and the screen. This is not hard to do they are very delicate. The only thing you can do is take it to a qualified service tech. i get these periodically in my shop too. Check the cable before you do so to see if you can reconnect it but be very carefull.
Be mucho blessed,
Mark
Jul 18, 2008 | Compaq Presario R3000 Notebook
COMPAQ PRESARIO R3000
Greetings Myname is Mark and I'll be glad to assist you.
I need some information so I can do some research for you.
1. What is the make and model of your laptop
2. Did you use a cleaner or water at any time.
3.What was the reason for removing the back panel.
Please let me know and I can follow up for you,
Be mucho blessed,
Mark
Jul 13, 2008 | Compaq Presario R3000 Notebook
Compaq Presario R3000 Black Screen with flashing cursor
Lines are the BGA RAM Or VRAM Needing rework.. This will also cause boot issues on these models. Do you ever see the Compaq Logo? Weve repaired a ton of these and class settlement happened for the R3000's regarding the jacks but we could repair the other issue as well. (As well as install a new jack while its here).. HP's reimbursing for these outside repairs.
Feb 01, 2008 | Compaq Presario R3000 Notebook
Laptop wont power up.
LS-120 SuperDisk drive help Next, connect the power and boot the computer and install the software ... as the computer beeps or pressing and holding CTRL as the computer is booting up.
Good Luck, Read and folow instructions/Please dont for get to Vote/Thank You.
Dec 25, 2007 | Compaq Presario R3000 Notebook
Compaq Presario R3000 Notebook Logo
172 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
