My mainboard is K8M800-M2, while POST started "BIOS checksum error". Two option are F1 (boot) or Del (Setup) both option always Hang or when I press one of them. Please help me how to solve this problem
  • Barry Parks May 11, 2010
    I would normally expect the prompt to be F1 to boot or F2 for setup, but it could be Del. Have you tried to get into the BIOS setup before the error comes up? If you can get into set up, chaeck the date and time. It will probably be off by a few years and the time will be near midnight. The most common cause for this, that I have seen, is that the CMOS battery is failing, or has failed. Reset the date and time and then save and exit. It should start normally. If it does, you need to replace the battery. It is normally a 'coin' type on the motherboard.
    Good luck, and please let me know what you find.
    ~ Spoem
  • 50 Answers
1. hit Del >>go to setup>> check for boot device menu>>disabled and close floppy drive >>set the 1st bootable device as HDD...issue will be resolved ...this is a verfied solution
Posted on May 11, 2009
Cmos checksum erroe defaults loaded
press del to enter setup.then choose default bios setup. then save and exit.pc will restart.
Nov 17, 2011 | Gigabyte GA-945GCMX-S2 Motherboard
Mainboard GA-G31-ES2C Warning: Backup BIOS checksum error BIOS Auto-Recovering...
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen to press delete to enter setup
Jul 23, 2011 | Gigabyte GA-G31M-ES2L Motherboard
Hello, when I put my pc running it says CMOS checksum error press F1 to enter or Del to enter setup, but I press Del when I save changes "save and exit" the computer restarts, but this time...
The Checksum error basically shows that boot settings which were previously set has been changed or reset. This usually happens when the battery loses its charge and thus fail to retain the CMOS settings. This can also be caused by a power surge or a damaged motherboard. But most of the times it would be the battery problem.
You can try replacing the CMOS battery and enter the values back into CMOS or reset values to default. Then switch off and boot up again.
Hope this works. Good Luck. ~SmokinJoe~
Apr 28, 2011 | EliteGroup KM400-M2 Motherboard
How to enter bios setup, need to change boot option
try the delete key if that does not work try the f2 key
Jan 31, 2011 | EliteGroup RC410L/800-M2 (V1.0)...
I have a compaq presario 5600 / P4-1.5G/128MB/40GB/C48/M The other day the system hung, and nothing was working. I changed the CPU battery, cleaned the dust. the system started with Intel boot agent 4.0...
You probably need to set your boot order in BIOS (setup) to load from CD first. Reboot the computer and press either F1 or F10 repeatedly until the setup (BIOS) menu comes up, then, using your arrow keys, navigate to the boot menu and set the boot order to CD first.
If you can't get into the BIOS through F1 or F10, try other "F' keys until you get in. Also the "Del" key.
Recovering to factory settings is kind of a drastic measure just because of a system hang. You would be better served to find out why the system hung. IN FACT, understand that depending upon what is wrong, the system may hang during the recovery, leaving you with fewer options for repair.
Post back if you want to try to troubleshoot this further. It will take a while, but we should eventually be able to determine what is causing the hang.
It could be just an application that needs to be removed or re-installed. Have you installed any new software recently? What software were you using when the hang occured? What operating system are you using?
It could just be a virus or a bad memory module. Are you able to boot into SAFE MODE" (press the F8 at boot)?
If you can boot into Windows, go to "Start" > "Control Panel" > "Administrative Tools" > "Event Viewer" > "System" and check for any error entries. Also look at the "Applications" log.
Aug 15, 2010 | HP Compaq Presario PC Desktop
Abit Av8. 2nd post fault on this m/b. post fails to complete and stops at code display 7F. screen displays . mem test OK HDD iodentified CMOS checksum error-defaults laoded F1 to continue Del to...
For that When you power up the computer press F1 or F2 or del or ALt +F2 key to enter in bios .
If still you are not able to enter in bios then open cpu cabinet if you have desktop and if you have laptop open back cover of laptop then pull cmos cell from motherboard for 10 minutes.Reattach the RAM memory .
Then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 03, 2010 | Computers & Internet
I install a sata 160 disk and cant access the bios mi motherboard is K8M800-M2 (V1.0)
Press DEL to enter Bios SETUP
Pressing the delete key accesses the BIOS Setup Utility:
Sep 10, 2009 | EliteGroup K8M800-M2 Motherboard
Hang computer no beep .
Yea... problem with your CMOS battery, try to replace it and update you BIOS.Updating BIOS can be done through the Internet, download the latest firmware to update your BIOS.
Save and reboot your computer.
Hope this Helped!
Sep 07, 2009 | Computers & Internet
Computer wont boot up
first reconnect your keybord and mouse jack in computer then power up the compter then press del or F1 or F2 to nweter in bios setup then just press F10 and save settings .
Feb 07, 2009 | Dell Computers & Internet
Press (F1) to resume, (F10) to setup
I need a bit more info to try to give you an accurate solution
Does the screen change after you press "F1" ?
Do you have access to an external keyboard, if so try plugging that in while the computer is off and then using that to press "F1"
Nov 15, 2007 | Compaq Presario M2000 Notebook
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
